Home | Mitsubishi | WS-65807 65 in. Rear Projection Television | Apple tv
Mitsubishi WS-65807 65 in. Rear Projection Television
Problem for Mitsubishi WS-65807 65 in. Rear Projection Television
Apple tv
By cindyb on Aug 18, 2007
I've spent the better part of a day trying everything twenty times to get appletv to display on screen. Am using the component 2 input, Y/Cr-Pr?/Pb cables/jacks. Audio via analog to receiver.
I've tried Apple's advised solution - trying to adjust resolution, using the apple remote to request from the appletv unit. I hear these cute little bleeps (almost tivo-like) every minute or so - for about half an hour - but never see anything other than the bright blue screen.
Have unpluged, upgraded, restarted. Three times.
Everthing's snuggly plugged in - and using cables that work on the dvd player - and the same component input that worked for the dvd player.
Have the right input for viewing - any ideas - known problems?
Known solutions?
thanks
Cindy
Same Problem
Dec 22, 2008
-   nothing happen when HDMI conected from ATV to TV. no signal at all NOTHING. Plis Help me
-   PACCINNO
Best Solution
posted on Aug 22, 2007
Very Helpful)
TVtechmaniac
Rank: Guru
Rating: 93%, 402 votes
The component 1 and component 2 inputs only go to 480i and 480p. The Apple TV must be plugged into the DTV input which will accept a 1080i signal.
Was this helpful?
Yes
No
Solution #2
posted on Jan 07, 2009
Not Rated)
brainded
Rank: Guide
Rating: 100%, 1 votes
TVtechmaniac is spot on. I own this unit and it has one DTV input which is 480p/1080i. Plug your component apple tv into this and you should be good to go. Im assuming the atv auto configs? If not, set to 1080i and you should be good to go.
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WS-65807 65 in.
Questions and Unsolved Problems for Mitsubishi WS-65807 65 in.
Do you recommend Mitsubishi WS-65807 65 in. Rear Projection Television?
Answer
Answer
I have a Mitsubishi WS-65807 and I'm getting 1-2 code on the diagnostic. The TV won't power up.... (More)
Answer
I'm working on a ws-65807 that had a convergence problem, but is now blowing fuse. I originally just... (More)
Answer
We have a Mitsubishi WS-65807 rear projection television that stopped working all of the sudden.... (More)
Answer
we have a mitsubishi HD 1080 series rear projection tv made in fall of 2000. the DVD player thru... (More)
Answer
I want to know how to fix my WS-65807 tv, but can't seem to figure out what to change and where it... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WS-65807 65 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1476
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
