Question about Motorola Mobility L6 Cellular Phone
Keypad locking Is it easy to chang the fascias or should I get an expert to do this (please factor into this that I am a girl!) Also how on earth do I lock th keypad,I am forever finding It has been on browser! Thank you
To turn keypad on press the menu button '-' and then '*'
Posted on Aug 28, 2007
SOURCE:
How do I replace my rear bumper on my 04 pacifica
  1. Open liftgate.
133387935 Fig. 12
  1. Remove two push pin fasteners per side at the liftgate tower area (Fig. 12).
  2. Hoist and support vehicle with safety stands, as necessary.
133387936 Fig. 13
  1. Disconnect the park assist wire connector under the vehicle and the push pin fasteners attaching wire harness under the vehicle (Fig. 13)
  2. Remove the four push pin fasteners attaching rear fascia to reinforcement bumper.
  3. Remove two screws (each side) attaching fascia to rear fascia bracket in the wheelhouse.
  4. Remove the screw on each side attaching the upper fascia in the tail lamp bucket area.
  5. Remove rear fascia from vehicle by lifting sides of fascia up and outboard to release from rear fascia brackets.
  6. Place fascia on a clean surface.
133387937 Fig. 14
  1. Remove park assist sensors, if necessary (Fig. 14).
133387938 Fig. 15
  1. Remove spring clips attaching upper and lower fascia together (Fig. 15).
  2. Using a trim stick release locking tabs and separate the upper and lower fascia.
133387939 Fig. 16
133387940 Fig. 17
  1. Remove move the bright chrome molding from the upper fascia (Fig. 16). Using a trim stick, starting at the out edge of the fascia release the locking tabs (Fig. 17). Grip the molding and pull outward from the fascia while releasing the locking tabs.
  2. Remove molding from fascia.
INSTALLATION
  1. Place bright chrome molding in position on the upper fascia.
Jan 06, 2012 | 2004 Chrysler Pacifica
I WANT TO CHANGE MY Housing Fascia Case Faceplate For Nokia E65 with keypad
Well you need to buy a faceplate or fascia for your Nokia E65. I receommend ebay. Looks like they are about 10 dollars for the set.
Check out the following link for a guide video guide and links showing what is available on ebay.
Change Faceplate on Nokia E65
Jan 20, 2010 | Nokia e65 Cellular Phone
Replacing front fascia on samsung sgh g600
The front fascia is part of the LCD screen you will have to get hold of a complete screen for the colour of your phone.
When taking the phone to pieces the part most people forget is the screws behind the logo and the bottom ribbed cover.
Also underneath the phone there are two screws to remove the reset are easy to find I suggest that you use a magnetic dish as the screws are very tiny and easy too loose, and hard to find replacements.
Hope this helps please rate !!!
Oct 20, 2009 | Samsung Cell Phones
How to change full cover on nokia E71? step by step guide
Nokia E71 Housing Fascia Replacement Faceplate Cover, Restore your ... or alternatively use the corresponding tools to change it by yourself.) Package include: Full Housing Replacement Cover for Nokia E71
Full Housing Replacement Cover for Nokia E71 (Grey) * 1
Front Cover
Back Cover
Middle Cover
Keypads
Accessories as the picture shows
Keypad *1
T6 Screwdriver and an opening tool
Aug 12, 2009 | Nokia 6085 Cellular Phone
I want to change the fascia on mobile phone
how do i change the front cover on a nokia 6500s?
Dec 30, 2008 | Nokia 6500 Slide Cellular Phone
I need to remove front and back fascias of my 6500 classic
I had the same problem. Watch this video for full instructions.
http://uk.youtube.com/watch?v=wmtOn3KhcQI
Dec 08, 2008 | Nokia 6500 Classic Cellular Phone
Key pad lock and unlock Nokia 1200
My local Nokia Care Center provided the easy answer (which does not appear in the
owner's manual):
In the Menu, go to Settings, then select Phone settings, and activate "Keyguard Settings," and "Automatic." That done, you must select the time interval until the keypad self-locks. To unlock,
touch the "select" key (upper left key) and * (lower left). That combination also will relock the keypad.
Sep 11, 2008 | Cell Phones
Sony Ericsson Fascias
u just replace battery cover thats easy and safe.
Jun 02, 2008 | Sony Ericsson Walkman® W880i Cellular...
Jvc cd/radio
bodysnatcher ..make sure your unit has a good earth..do not rely on an earth from aerial..some times when units are installed.and there is bad earth connection it will earth through the aerial only .after a while your aerial may start to loose a good connection and unit is trying to sus an earth somewhere
Feb 08, 2008 | Car Audio & Video
INSTRUCTIONS TO REPLACE NOKIA 6233 FASCIA HOUSING
Yes i own 1 myself and have replaced the case 5-6 times , so here you go :
First you will need a t7 torx screwdriver , and then you remove the screws ( you can find the 2 screws were the battery is )
Once you remove them you can now take the rest of the case of BUT  , you might need a case opening tool for the part just above the battery , after that youve done it except for where the keypad is , replace the keypad and the chrome surrounding the screen you can simply take it off , Hope i helped :D
Oct 18, 2007 | Nokia 6233 Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
76 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
