Question about Canon PowerShot A630 Digital Camera
Dark image....even using flash.
I'm having a problem with my Canon PowerShot A630 Digital Camera. In the Auto mode and other mode except Manual mode the result of my pictures are dark even i am using a flash? Please help me with this problem. Thank You.
  • 8 more comments
  • mjmaura Mar 18, 2008
    same problem here....the flash fires correctly but the image comes up dark. Nothing found in the settings file or menu.
  • tracyr321 Sep 02, 2008
    I have a Canon Powershot A630. I suddenly noticed a change where every single picture I take in auto mode is very dark no matter how bright it is outside. I followed some tips on other posts about checking settings, but can't find anything that could be changed to resolve this problem. If there is a way to fix this, I appreciate step-by-step instructions or does the camera just need to be repaired?
  • ckhogg Sep 16, 2008
    Same here. It worked perfectly fine for a few years, then all of a sudden, despite confirming correct settings on everything - multiple times, all pictures with flash are extremely dark. Stark contrast to what it should be.
  • RyansInFL Oct 03, 2008
    I also have this problem on A630 and have checked the settings. Is there any other solution if these are correct?
  • mycamerawoes Oct 26, 2008
    Yup, same thing here. Thought I'd messed something up one night taking outdoor dark photos so I reset everything back to original settings, but didn't seem to help problem. Flash may be going off just before shutter release which would be a problem but I don't know how to fix it. Love the camera otherwise for the most part.
  • babaoriley7 Nov 07, 2008
    the Flash Sync is out of wack. From everything I've heard from different camera shops is that Canon would have to fix this. If your warranty is expired that would be a significant chunk towards the price of a new camera.
  • simonej Dec 22, 2008
    I have the same problem: even using flash, the picture is too dark now. The camera bought two Christmas's ago was working fine but in June 2008 began having a yellowish tinge to the indoor photos, seemed to work fine again in August 2008 indoors while we were on vacation, but then since October 2008 has been producing too dark photos even with flash. We've tried using nighttime setting but then the pictures are blurred. Any help would be much appreciated.
  • jana_h8 Jan 02, 2009
    Same problem here...after 1 year of great operation...dark exposures with flash in AUTO and SCN modes. Tried resetting to defaults...no change. Somebody mentioned checking menu settings...which ones? If the flash is in fact "out of sync" is there any way to adjust?
  • svsk98bt Mar 16, 2009
    yea, have the same over here. worked fine till it started giving problems. In auto mode, flash and photo are out of sync. Manual modes things work fine. But its irritating to change setting every time for point n click camera.
  • jessoxina May 17, 2009
    Mine have the same problem.. any updates?
That doesn't really answer the question. What settings are you checking? In our case, the problem happens in different settings not just the auto mode.
Posted on Oct 24, 2008
  • 407 Answers
Go to the menu & open setting file.properly check the settings of auto mode
Posted on Feb 03, 2008
I have a canon powershot a630. It suddenly won't take pictures in auto mode. Orange light in front stays lit and arrow on display screen flashes. It will take pics in some other modes (P, Tv, Av,...
See this blog article. If you don't notice any gaps, and tightening all the loose screws doesn't help, then the next likely problem is the flash unit itself is burned out. If so, this would require professional repair to correct.
Dec 30, 2010 | Canon PowerShot A630 Digital Camera
How do I turn off the flash for the canon powershot a630?
First of all, the flash can not be turned off in "Auto" mode. You can turn it off in any mode other than Auto. Would recommend Program "P" mode, which is very similar to Auto, but allows you to modify certain minor items such as flash and white balance.
Rotate your mode dial to "P", then press the button on the back with the "lightning bolt" icon. Press until the lightning bolt with a slash shows up on your LCD screen. The flash is now turned off in Program mode. Try taking a picture.
Remember, if in low light conditions you'll need to keep the camera extra steady without flash to get a clear picture. Recommend placing the camera on a table or chair (or even better, use a tripod), then using its autotimer to snap the picture.
Nov 01, 2009 | Canon PowerShot A630 Digital Camera
A630 Indoor pictures are too dark in Auto, Flash
try using night mode indoors. otherwise, simply get into setup and go back to factory settings, and use AUTO mode. hope it helps
Oct 07, 2009 | Canon PowerShot A630 Digital Camera
Same as posted - picture is way too dark when using flash. Help!
Try a camera reset. Go into the setup menu and scroll to "reset" and follow the on-screen instructions.
Sep 23, 2009 | Canon PowerShot A630 Digital Camera
Pictures too Dark
Try resetting the camera. Go into the setup menu and find "reset".
Sep 21, 2009 | Canon PowerShot A630 Digital Camera
Canon S3 IS - Images are darker or underexposed even in normal ambient light. Started happening just recently
If you are shooting using AUTO mode, maybe the settings were changed to a manual modes. If so, check for settings. Flash fires automatically only in AUTO. On manual modes you must force the flash to fire.
Aug 09, 2009 | Canon PowerShot S3 IS Digital Camera
Almost same problem
Hi!
It looks like the flash capacitor cannot be charged - could be a dead flash fuse. You should contact your local Canon service center.
Tom
Jul 27, 2009 | Canon PowerShot A630 Digital Camera
Canon Powershot A630 - dark image in auto mode
Could it have something to do with "white balance"? http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=145&modelid=14108#SupportDetailAct
When the shooting mode is set to (Auto), the white balance will be applied automatically. However, with the (Auto) mode, the camera may not reproduce the natural color of the subject.
If this don't help, try their website and see if you can troubleshoot it. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=145&modelid=14108#SupportDetailAct
If all fails, buy a newer Canon Powershot. I've tried the newer models and they seem good.
Jun 01, 2009 | Canon PowerShot A630 Digital Camera
The problem here is likely the auto setting. Put it to sunny, clear day instead of indoor picture and you should be ok. Also, point it at neutral colored objects when you take the picture and allow it time to adjust by holding the button in partway before depressing it fully.
Jul 26, 2007 | Canon PowerShot A630 Digital Camera
Canon PowerShot A630 Digital Camera Logo
406 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
