Question about Ariston Technologies LL64WNA Built-in Dishwasher
Error message AL 10 on our Ariston LS 620 A dishwasher
When we try to run a load, the error message AL 10 comes up on the screen and flashes, and it won't start. Any ideas? We had a similiar probelm a few weeks ago, but the message was AL 03. It turned out we had to pay a repairman $110 to come and retrieve a chicken bone from the pump. Thanks,
6ya staff
SOURCE:
Dov Dror
  • 641 Answers
SOURCE: Ariston LS 620 A Dishwasher
Since, the pump doesn't stop working, it sound like a water level switch issue. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you will find it easily. Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. Good luck !
Posted on Aug 13, 2007
Dov Dror
  • 641 Answers
SOURCE: Ariston L63 Dishwaher problem
Unplug the power cable, remove the service panel and follow the next steps : - Remove one of the wires connected to the heating element and check with a multi-meter the element's resistance. In case you can't read any result,you should replace the element. - Check the water level switch- The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub.Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. - Control panel - look for loose wires. If you think that your main control PCB timer have failed, you may be able to get it tested, and if faulty, get a re-worked (repaired one) much cheaper than a new one. Good luck !
Posted on Sep 13, 2007
Anonymous
SOURCE: Ariston LL64 error
call 1800 815 589 ariston australia
Posted on Sep 18, 2007
Anonymous
SOURCE: ariston dishwasher
i have a brand new ariston ll-64 and the wash cycle won't start and two flashing lights
Posted on Feb 14, 2009
Bill Johnson
  • 297 Answers
SOURCE: don't have a manual for ARISTON LS 620 A DISHWASHER
light wash
Posted on Jul 15, 2009
Why Ariston lbf 51 lights flash rapidly
24501406-0h3kxpflbez5mdeb5anq3st4-3-0.jpg If flashing any of the 4 LEDs (see picture) means that the dishwasher discovered a malfunction. Depending which combination of LED flashes (one LED, two LEDs, three LEDs or all four LEDs) indicates the specific error code.
Dado
May 25, 2014 | Ariston Technologies Dishwashers
Ariston l63 is not rinsing proper cycle but instead flashing 12hr light
Error messages,
Your dishwasher is equipped with a safety system which is able to detect any operating anomalies. These anomalies are reported by one or two wash cycle indicator lights "G" flashing rapidly.
24463930-0h3kxpflbez5mdeb5anq3st4-3-0.jpg Flashing LED diode above the mark 12h (drying) indicates faulty NTC thermistor. So, could be faulty: thermistor NTC, wiring between NTC and control board, control board.
Dado
May 20, 2014 | Ariston Technologies L63 Free-Standing...
I have an ariston ll64 and it is stopping a the last cycle button which is the picture of wine glasses. It then flashes with a green light.any ideas?
Error messages:
Your dishwasher is equipped with a safety system which is able to detect any operating anomalies. These anomalies are reported by one or two wash cycle indicator lights "E" flashing rapidly.
24432725-0h3kxpflbez5mdeb5anq3st4-3-0.jpgFlashing Led diode below button with the image of wine glasses means faulty thermistor NTC. So, could be faulty: thermistor NTC (defective or not positioned), wiring, control board.
Dado
May 16, 2014 | Ariston Technologies LL64WNA Built-in...
HOTPOINT DISHWASHER BFI 620 ERROR CODE LED FLASHING 1 & 3
Check the end of your drain hose for the clog.
Feb 17, 2013 | Dishwashers
Hi, our ariston dishwasher has stopped before the cycle finished and the water has not drained out. There are 2 flashing lights - the brush emblem and the spray ' on a tilt' emblem (the 2 on the...
Error messages.
The dishwasher is equipped with a
These anomalies are signalled by
the rapid flashing of one of the
wash cycle indicator lights M.
If the indicator light for the soak
cycle flashes (see wash cycle table),
cancel the wash cycle by following
the instructions indicated in the
"Modifying a wash cycle in
progress" paragraph on page 4.
Now check whether there is any
water in the mains supply and that
the tap is turned on; if the error
message persists, then call for
technical assistance, indicating
which message appeared.
If the indicator light for any wash
cycle apart from the soak cycle
flashes rapidly, turn the appliance
off and call for technical
assistance, indicating which
message appeared.
Troubleshooting
You have checked
everything, but the
dishwasher still doesn't
work and the problem
persists?
Call an authorised service centre
near you and remember to mention:
? the type of malfunction
? the model mark (Mod?.) and the
serial number (S/N?.) indicated on
the rating plate located on the inner
door, to one side.
If you need further help, reach me via phone at https://www.6ya.com/expert/kelley_9a924afdf232bd4d
Jan 14, 2018 | Hotpoint-Ariston LI 640 24 in Builtin...
Ariston Dishwasher LD87, error code AL03
for code al03 ,today i resolve the problem it was a pomp like everywhere in sites riding. we open a popm and there have a black lastic and it was inside of the pipe ,so we take it litl bit out and dishwasher work perfect !! it is easy ! dont be afraid to fix it alone .Just be carefull with a lot of water will come out from the pipes. and sore has to be away from electicity)good luck !
Apr 11, 2009 | Ariston Technologies Dishwashers
Aug 13, 2007 | Ariston Technologies LL64WNA Built-in...
Ariston LL64 error
Jul 06, 2007 | Ariston Technologies LL64WNA Built-in...
Ariston Technologies LL64WNA Built-in Dishwasher Logo
486 people viewed this question
Top Ariston Technologies Dishwashers Experts
Ekse
Evan Benson
Evan Benson
Renee Knafel-Bullock
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
