Samsung Blackjack SGH-I607 Smartphone
Problem for Samsung Blackjack SGH-I607 Smartphone
Samsung Blackjack display error
By kimlegacyh on Aug 18, 2007
Error says, " The layout you have selected cannot be loaded. Please select a different layout using the Home Screen item in Settings." The screen is white with black print reading this, and shows nothing else. It just came up with no warning. When I try to go to the home screen settings, there is nothing for me to choose from anymore. All the categories are blank. Help!
Same Problem
Sep 17, 2008
-   my home screen says the layout you have selected cannot be loaded. Please select a different layout using the home screen item in setting. but there is nothing to choose from.-   cjsbabygurl
Sep 17, 2008
-   i have a same problem-   samsad
Sep 05, 2008
-   Hi,
I dropped my samsung blackjack 3 days back in water and immediately took it out and dried it with hair drier, luckily everything is working fine but when it goes into powersave mode the light instead of going off the screen turns white instead.
Please let me know if there is any solution for this problem.
Thanks for your help in advance-   Guest
Aug 28, 2008
-   i deleted some inages out of the HOME file located in The APPLICATION folder of my phone and now the SAMGUNG POPUP layout doesnt work-   Guest
Aug 12, 2008
-   will restore deleat # or important system files? -   Guest
Best Solution
posted on Aug 11, 2008
Very Helpful)
stitchgumby
Rank: Apprentice
Rating: 100%, 1 votes
to reset the blackjack 2 when it was frozen i pressed the power ke and up key at the same time it reboots your phone a master reset
Was this helpful?
Yes
No
Solution #2
posted on Nov 25, 2007
Very Helpful)
ExtraVecchio
Rank: Guide
Rating: 93%, 47 votes
This is a fairly rare problem, but it does happen with the Blackjack and other Windows Mobile devices.
First thing to try is:
Start -> Settings -> Display -> Home Screen -> (your carrier) Default
If this option or no options are visible, attempt to move right or left a couple of times (if you are in the list mode, move up and down) and then hit 'OK'
If this does not work, you will need to do a factory restore on your device:
WARNING - Restoring the factory settings on your device may cause the loss of all of your data that is not stored on the memory card or backed up elsewhere. Please back up your data before doing a factory reset and remove your memory card during the procedure:
From within the Software:
1. Start -> Settings -> More -> SECURITY -> More -> Reset
2. Enter '0000' and hit 'OK'
From the Powered off state:
1. Power off the device
2. Hold down the 'UP' navigation arrow while pressing the power button.
3. You will be presented with a 'format' menu, hold
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #3
posted on Mar 13, 2008
Helpful)
FixYa Honey
Rank: Apprentice
Rating: 94%, 4 votes
Don't RESET just yet.
I have a MOTO Q with this problem. I was getting a device almost full error for a few days. After I got the above message I looked everywhere. Could not sync with my phone, etc. Could not change the homescreen. I finally deleted a bunch of programs and voila! My home screen came back!
Try this before you reset.
Comments:
May 31, 2008
- This worked for my MOTO Q with full memory. I have too many emails so I set the device to download ONLY the last 30 days of email and it now works without filling up.
Was this helpful?
Yes
No
Solution #4
posted on Sep 04, 2009
Not Rated)
linhy2693
Rank: Apprentice
Rating: 0%, 0 votes
How do i get my Blackjack 2 to unfreeze
Was this helpful?
Yes
No
Popular Solutions for Samsung Blackjack SGH-I607
Questions and Unsolved Problems for Samsung Blackjack SGH-I607
Do you recommend Samsung Blackjack SGH-I607 Smartphone?
Answer
Answer
my micro phone is not working... how do i replace it if I need to?
Answer
My on/off button on my Samsung Blackjack SGH-1617 doesn't work. Pressing it does nothing. Battery is... (More)
Answer
my samsung is extremely slow and won't open anything, how do I clear the memory or fix it?
Answer
how to cHANGE text message from silent to sound
17 Other Users Have The Same Problem - Continued
Comment by ty41091, posted on Jul 04, 2008
phone locks up as soon as its turned on and then error message comes on
Comment by Guest, posted on Jun 28, 2008
Please Help
Comment by marlo27, posted on Jun 04, 2008
White screen saying install a valid home screen layout
Comment by Guest, posted on May 14, 2008
No home screen layouts can be found. Install a valid home screen layout and then select it using the home screen item in settings. Please help.
Comment by tiff-02, posted on May 10, 2008
white screen with black letters
Comment by Cathy Q, posted on Apr 13, 2008
white blank screen
Comment by madman3131, posted on Mar 23, 2008
homescreen setting
Comment by Guest, posted on Mar 22, 2008
the same problem
Comment by rEMOtigue, posted on Feb 25, 2008
I have the exact same problem. How do i restore it?
for a layout, it says "the layout you have selected cannot be loaded. please select a different layout using the home screen item in settings."
Comment by oso_hustla, posted on Nov 25, 2007
the same thing happened
Comment by chela6790, posted on Nov 20, 2007
Its all the same as the other 2! its very frustrating!!!
Comment by Austin978537, posted on Nov 17, 2007
The screen on my Samsung Blackjack SGH i-607 is totally white, however it says "The layout you have selected cannot be loaded. Please select a different layout using the Home Screen item in Settings." I have tried pulling out the battery and SIM card but nothing changes. Everything else works fine. But the message is irritating, HEEELLLPPP!!!!!
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung Blackjack SGH-I607...:
Top PDA Experts
Rank: Guru Guru
Solutions: 562
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
