Print not Responding
Want print want do nothing want print the test page
    New Friend:
    Problem Solver:
  • 11 Answers
The printer sometimes not respond due to the load on your processor due to the problen or infersation in your supply cable
Posted on Jun 03, 2013
SOURCE:
Rain041304
  • 63 Answers
SOURCE: epson c66 will not print black
Do print head cleaning. Contorl panel>right click on c66 and go to printing preferences>maintenance tab>print head cleaning>do it 3 times and then try to print
Posted on Feb 14, 2008
SOURCE: HP PSC 1610 All-in-One not printing anything including test page
try this.. i got the same problem before.. and the main problem is the NO MECH MODE.. try pressing the setup button then take the plug out of your printer.. (still pressing the setup button) and put the plug back.. and it will remove the no mech mode.. then you could print like before.. i hope this helps
Posted on Jul 20, 2009
rajeish
  • 52 Answers
SOURCE: printer will print test page but nothing else
there is a communication failure between the printer and the computer. uninstall and reinstall the printer driver. your problem will be resolved.
Posted on Aug 04, 2009
SOURCE: printer will print a test page but not a document.
set as default printer
Posted on Aug 29, 2009
SOURCE: the network printer will print a test page but nothing else
You need to connect to this printer with a Win 7 Driver installed on the Win 7 machine, and when you finish that, install. Then Go to printers>>ADD PRINTER. When the menu comes up, select, Connect to a NETWORKED Printer, basically navigate to the printer and select. Now Before you can do that,you MUST, be on the Same Workgroup, Must Have a Login Password, Must Have a PC Name. On the Printer, on XP. Sharing MUST be enabled on Printer, also there MUST be a Printer NAME too. After you have st all that up, do as I initially said, install the Win 7 driver, find printer, login, and you'll be printing in no time.
www.microsoft.com/windowsxp/.../networking/.../honeycutt_july2.mspx How to link above, below is a troubleshooting link.
support.microsoft.com/kb/308007
http://h10025.www1.hp.com/ewfrf/wc/softwareList?lc=en&dlc=en&cc=uk&os=228&product=1153481
Above Drivers for printer GET ALL scan manger too Get FULL Version and install.
Posted on Apr 14, 2010
Samsung ml 2010 firmware update, samsung ml 2010 not responding when paper end
Dear
you need not update firmware for this model. Pl. do the printer status monitor(SMART PANEL). Down load from samsung site and run inpc application. when print command given it will display the problem.
Thanks.
Dec 31, 2014 | Samsung Office Equipment & Supplies
Dear
If your printer aged much, pl. check the smps one elctrolytic capcitor 1500mf 10v at sec. may be leaky also the power capacitor at primery(68mf-120mf/400v) replace these. also clean hvps and its contact points.
Thanks.
My printer is not responding to when i ask to print something.
If the printer is not printing, check the cables connecting the printer and the computer. Make sure it is properly connected. Check the settings on your computer if printer is set as a default printer and try printing a test page from the driver page. To do this open printer and faxes, right click on the printer >properties and click the button print test page.
If you are able to print a test page, check the settings of your application and make that the correct printer is selected.
For further assistance, please contact Lexmark Technical Support
Jan 05, 2011 | Lexmark E260 Laser Printer
Can't get my HP LaserJet 4MV to print. It printed yesterday but now it says "Printer not responding. The printer is on and I have checked all cables. Help
Can you perform a test print? Try this:
To print a Test Menu page
Press On Line] to take the printer off line.
2 Press [Menu] repeatedly until TEST MENU appears.
3 Press [Item] repeatedly until PS CONFIG PAGE (or another PS test page)
appears.
4 Press [Enter] to print the page. The page will print in less than one minute.
5 Press [On Line] to place the printer back on line.
Did the printer print? If so, you may have either an nterface or cable problem.
Oct 23, 2009 | Office Equipment & Supplies
CANON PIXMA MX310: printer not responding.
If you go to Start, Printers and Faxes, if it says "Offline", right-click the printer and choose "Use Printer Online." If it says Ready, you should be good to go.
If however there is a problem yet, double-click the Printer there and see if any jobs are in the print queue. You can remove them all buy Right-Clicking and choosing "Cancel All Documents" then try printing a test page. Right-click the printer, go to properties and click "Print Test Page."
If you still have problems, follow up on your question.
Aug 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Wont print Printer is not responding when I try printing something out, I try printing something and it does nothing, I know it's plugged in to the computer, and I know that it should be running...but...
If you are using a Windows system:
1. Turn the printer off then back on.
2. Go to Start > Printers and Faxes (in the Control Panel)
3. Right click on your printer and select Properties.
4. Click on the Print Test Page button
5. Does it print? If not, go back to the printers and faxes window and double click on your printer. This will display your print queue.
6. Do you see your test page in the queue? You should and if it is stuck, there's a column for status. This will often tell you what's wrong.
7. If your printer was working before, we know that it is not a driver issue. Worse comes to worse, reinstall your printer based on the instructions provided by the manufacturer.
Apr 08, 2009 | Brother HL-2030 Laser Printer
HP DESKJET380 NOT RESPONDING WHEN CLICK ON PRINT
After sitting in power save mode for a long period of time the printer might not function properly. This happens when the printer is plugged into a surge protector. Unplug from the surge protector and plug directly into the wall power socket.
Step 1:
Please try to print Self test Print from the Printer (without PC ie. remove the USB cable from the PC)
Step 2:
If the Self test Print is Ok, try to connect your printer to PC
and Print Test Page
Go to Start >> Printers and Faxes >> Select your Printer F380
then Right click Properties and Click on "Print Test Page"
If this prints Ok then all the connections you have made are correct
In case, it does not print then please check your USB cable try to change it
Step 3:
You can uninstall your Driver
and install the new driver, to download the driver for F380 All in One Printer Please click the below link
Choose appropriate Operating System
HP F380 All in One Printer Driver
I hope this will resolve your problem
all the best
Jan 05, 2009 | HP DeskJet F380 All-In-One Printer
Try the HP500Hpgl2 driver, it will work with a USB port.
Dec 13, 2008 | HP DesignJet 450c InkJet Printer
Printer Not responding
pls see if your printer is offline or online first, by double clicking your printer icon, if it is you can go to printer properties and select an print test page if it does print then you should be able to print on all kinds of application or any platform.
Aug 27, 2008 | Canon PIXMA MP150 All-In-One InkJet...
k24674
Marvin
Marvin
