Question about Archos 704 WiFi Digital Media Player
Broken Touchscreen Does anyone know how to replace the touchscreen on an Archos 704 Wifi Mobile DVR? I have a replacement screen, however I can not figure out how to take the old one out and replace it with the new one. Help!
  • 1 more comment
  • dimiV Feb 11, 2009
    If you're good with tools and small parts, and are really careful, you should be able to take it apart. Keep careful count of where each screw came from, and if you want to be really cool, take pictures of the process so you can help others.
    Also, PLEASE let us know where you got the screen. I'm trying to replace one for a friend, and can't seem to find one anywhere...
  • zazenbushido Feb 12, 2009
    Took archos apart to fix seems to be a problem with a connection does anyone have pictures of a torn down archos 704 and knows how to repair?
  • jillyfirkins Feb 14, 2009
    I have just discovered the screen is broken on my 704 TV would love to know where to obtain a replacement. I have a treasure who could probably replace it.
Can't help but would sure like to know where you got the screen from desperate for one....Itemcat
Posted on Jan 12, 2008
SOURCE:
My Archos 604 wifi only play a few minutes after charging.. I have used the dvr, usb and wall charger and nothing helps.. is my battery kaput? also since messing with it the touchscreen isn't working......
it must be the battery..While charging is pilot lamp lightning ?
To verify,just plug the USB cable to see if device battery charging circuit is working..Device should work normally..
If it does,either your battery is dead or its charger needs to be changed.
Kazim
Sep 13, 2009 | Archos 604 WiFi Digital Media Player
MY ARCHOS 704 TURNS ON BUT JUST SAYS ARCHOS ON SCREEN AND WONT DO ANYTHING ELSE
Try pressing and holding the TV/LCD button just after switching on, you should get a recovery mode screen. Select repair disk.
Jul 04, 2009 | Archos 704 WiFi Digital Media Player
Headphone socket broken on archos 704
Depends if the circuit board is damaged. If not and competent technicial should be able to repace the socket. If the board is damaged it will need replacing, unfortunatley this is coded to the hard drive so it is only possible if it is performed by Archos
Jan 26, 2009 | Archos 704 WiFi Digital Media Player
I cannot figure out how to put movies on my Archos 704 Mobile DVR. The previous owner just gave it to me without any instructions. I just want to know if there is any way I can download movies off of a...
Go to archosfans.com support group. I found it the other day and was quite impressed.I a considering purchsing one but there are a lot of glitches. Hope it helps
Staci
Nov 30, 2008 | Archos 704 WiFi Digital Media Player
New Hard drive for 704 WiFi
No. Period. End of Story. I know that's not the answer you want, but that's the truth.
Sep 04, 2008 | Archos 704 WiFi Digital Media Player
Archos 704 wifi not starting up
If you enter recovery mode then connect to a computer, you can then use windows drive checker to verify the drive. If all is OK, copy firmware to the root then disconnect and reboot
Apr 09, 2008 | Archos 704 WiFi Digital Media Player
Archos 704 WiFi Digital Media Player Logo
248 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
 Mike M
Mike M
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
