1996 Dodge Grand Caravan Logo
Posted on Mar 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stalling on our 96 Dodge Caravan
Car starts and runs fine - until a few miles have passed - then stalls- barely idles, dies if you touch the gas. Today I have atttached a test gauge to the injector supply manifold. 60 psi at start, after a few miles drops away to 10psi or less, and then stalls. Does this confirm fuel pump failure?
  • nick_thiry Mar 21, 2009
    Thanks for helping. The car will restart and pressure will breifly come up again after maybe a 5 minute wait. We can get underway but then pressure drops again and the car stalls.
    Am I right in thinking that it would be unusual for a filter to intermitantly clog?
  • Anonymous May 11, 2010
    It could also be the fuel pump relay or fuel filter.
Anonymous
Level 3:
Genius:
  • Master 1,118 Answers
  • Posted on Mar 21, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1118
Questions
Helped
517521
Points
3680
Once a filter plugs its pluged. You drop that much pressure its time for a new fuel pump.
2answers
96 Benz ran out of gas other day, got it filled up & drove home (20 miles). Next day drove about 40 miles, left car running in park for about 15 min, when I left car was stalling like it was running o
You never leave a car running, as it will
overheat the Exhaust Converter
When you run out of fuel, you sometimes
ruin the Fuel Pump
It depends on gas to lubricate it,as strange as it sounds
Check fuel pressure & volume at the motor with a gauge
Its a 115000 btu multi fuel.it starts up,runs a few seconds,then shuts off.it doesnt smoke or anything wierd,it just shuts off.
It can be low fuel pressure issue or clogged fuel pump. Or its engine related issues,---------------
Check the help link mentioned below to troubleshoot the problem: ------
Engine stalls when gas is given?
http://technoanswers.blogspot.in/2012/01/engine-stalls-when-gas-is-given.html
Car stalls when MAF sensor is connected?
http://technoanswers.blogspot.in/2012/01/car-stalls-when-maf-sensor-is-connected.html
Car Engine Stalls While Driving?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-stalls-while-driving.html
Car stalls and throws white smoke from exhaust?
http://repairhelpcenter.blogspot.com/2012/01/car-stalls-and-throws-white-smoke-from.html
Stalls And Dies At Stop Sign?
http://www.howtobyme.blogspot.com/2012/07/stalls-and-dies-at-stop-sign.html
GMC Sonoma Stalls and idles low
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
Nissan Pathfinder stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
1992 Chevrolet stalls and shutdown?
http://schematicsdiagram.blogspot.in/2012/04/1992-chevrolet-stalls-and-shutdown.html
Stumbling and stalling at idle after engine rebuild?
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1990 mazda 323 stalls and quit running?
http://technoanswers.blogspot.in/2012/02/1990-mazda-323-stalls-and-quit-running.html
2000 Toyota Camry: Idling and Stalling Problem?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-idling-and-stalling.html
1995 Toyota Corolla: Stalls, Sputters and Pops Through Intake Manifold?
http://whatisbyme.blogspot.in/2012/05/1995-toyota-corolla-stalls-sputters-and.html
1999 Toyota Camry: Erratic stalling and high engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
Dodge Dakota stalls, stumbles at idle. Has low fuel flow and runs hot?
http://schematicsdiagram.blogspot.in/2012/03/dodge-dakota-stallsstumbles-at-idlehas.html
1994 Toyota 4Runner: Stalls and Stops While Driving?
http://whatisbyme.blogspot.in/2012/05/1994-toyota-4runner-stalls-and-stops.html
1997 Toyota Camry: Erratic Idle and Intermittent engine stalling?
http://technoanswers.blogspot.in/2012/04/1997-toyota-camry-erratic-idle-and.html
Ford Maverick: No Idle and Stalling issues?
http://schematicsdiagram.blogspot.in/2012/04/ford-maverick-no-idle-and-stalling.html
These details will help.
Thanks.
Our 1995 Dodge caravan starts fine dies.
Do the following
Here are the most common causes of idle surge, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake
Runs about thirty miles then acts like flooded or exhaust plugged
try checking your cadlist convert on your exhusted
91 volvo 240 - keeps stalling out, shakes a lot when idling
for the cheapest TEMPORARY solution get some fuel injector cleaner and get on the gas fo about 5 mile at like 100 - 120 miles an hour thats what idid to mine last week hasnt wanted to die out since. good luck.
3answers
Stalling at lower speeds
either fuel filter stoped up , air filter, the egr valve stuck open ,or a vaccum leak
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
