I tried the above steps, but each time when restarting the DVD player, it said 'reset' and asked for the language to be selected again. Pressing the "Fast Forward Fast Rewind Fast Forward Up Down" sequence caused the player to lock up and require powering off at the wall.
I found on another web site that there are different initial sequences. Once I use the one for Region 2, it worked fine.
I found the instructions below on another web site, but it worked for me...
Make sure there is no disc in the player.
Turn on the player (you can use remote control or front panel, it doesn't matter)
Wait for "No Disc" message to appear on the TV screen.
Press the Repeat button on remote (plain, not A-B).
Press the correct sequence of buttons of remote according to the original region code of your player (it's on the sticker on the back panel of the player). FF = fast forward, FR = fast rewind.
Region 2 players: FF, FR, FF, UP, DOWN
Region 3 players: FF, PLAY, FR, UP, LEFT
Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
Region 5 players: FF, UP, DOWN, STOP, RIGHT
Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
If you pressed the correct sequence, a small white number 0 will appear somewhere on the top right of the screen. The white number 0 of the same font and size as the "No Disc" message, so don't confuse with the red "not allowed" sign that would appear when you press a function that's not available.
Turn the player off and on again, then you can pop in a DVD of any region and watch immediately.
After searching the best known region hack databases I have found one process for your make and model. I can not assure you that it will work 100% but it's the only known process.
Turn on the Player with no disc on the tray. The tv screen and the dvd lcd will display "No Disk"
2. Press the "Repeat" key on the Samsung remote control
3. Press the keys: "5 7 5 3 8" on the remote. Number 2 appears on the screen for a short time.
4. Press "9". Number 9 is displayed on the screen.
5. Press the "Open/close" button in the remote. The tray will open. Leave it open for a few seconds.
6. Just press the "On/off" button in the remote.
7. You now have a multi-region dvd player!!
I hope this works for you, thank you for choosing Fixya!
Turn on the unit with no disc in the unit. The No Disc message should be visible Press the following keys in this sequence Repeat (not the A-B Repeat, just the plain Repeat) Fast rewind button (just below the Disc Menu button) Play button Down button Down button Right Button
The number 9 should now appear towards the left of the screen.
Open then close the disc draw
Turn off the unit and then on again. You should now be able to play DVDs from any region
Enter the security code using your Kenwood remote. For the DDX6019 The key sequence to enter the security code KCAR is: on the side of the remote there is AUD, DVD,TV. now enter 55 in the AUD then go to DVD and enter 2 which is fast forward then go back to AUD. Do the same for the rest. 5 5 fast forward 2 2 2 fast forward 2 fast forward 7 7 fast forward
Enter the security code using your Kenwood remote. For the DDX6019 The key sequence to enter the security code KCAR : on the side of the remote there is AUD, DVD,TV. now enter 55 in the AUD then go to DVD and enter 2 which is fast forward then go back to AUD. Do the same for the rest. 5 5 fast forward 2 2 2 fast forward 2 fast forward 7 7 fast forward
the double din kit was restricting it from opening properly, once i removed it from the kit it worked properly. i had to modify the kit for it to work properly!
