I want to tow my vehicle in a dolly and use the existing vehicle lights. I've found a website that sells a diode block for just this purpose. They give the following info as to determining which wiring diagram to use:
Type B: Vehicles with separate amber or red signals (Brake
light wire splits before the lights).
Type C: Vehicles with separate amber or red signals (One
brake light wire comes out of the other brake light
socket).
NOTE: In the wiring systems type B and C, the amber
signals will only operate from the towed vehicles system.
The red brake lights will function as turn signals when
operated from the towing vehicle.
What I need to know is what configuration the Envoy would use (B or C) and exactly where in/on the vehicle that the wiring harness comes together to place the diode block?
Look goto autozone they have a all in connector for towing so much me easer about 40 dollars you go back to driver side rear harnes when you unplug it the pig tail joins all connectors to geather along with your traller pig tail no mus no fus
