I have a 47LG70- UGAU80LVM. I bought it either 2008 or 2009. It is turning itself on by itself and speeding through all the channels. I have been reading this is not an uncommon issue. Is it the circuit board or capacitors if it turns itself on? Can I order and change this myself? Is it super hard? I'm in Canada and repairs are really expensive and I can't afford it! And its not the remote, HDMI, Cable box or anything else remote bc I've disconnected and unplugged them all. Thank you so much!
SOURCE: LG tv turns on by itself
this problem is with the inner small micro-swtches ,the side buttons inside are getting intermittantely short...changing of those switches will solve the prob. tc--
SOURCE: lg lcd tv remote code
HI,
BUY A NEW REMOTE FROM E-BAY OR PARTSTORE.COM,TRY A UNIVERSAL ONE IF STILL DOESN'T WORK TV INTERNAL IR INTERNAL RECEIVER IS FAULTY,THANKS.
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
SOURCE: 52LG70 sometimes turns off and on periodically
I had the same problem. I changed the 4-3 setting on the motorola cable box. Turn off your cable box and press menu. My 4-3 setting was set to auto. If you turn it off, you lose the 4-3 aspect on most channels. I changed mine to 480p and so far it seems to be working. Worth a shot.
SOURCE: "No signal" sign on TV screen using HDMI selector
it sounds like a refresh issue, double check you selector and make sure it fits the refresh of the tv. i had this once with a sharp where the tv was 120hz and the selector was 60 and it created a no signal and when it did come in it was jumpy. if you have a 120 tv then selector should be the same.
