Question about Fujitsu Siemens Lifebook N5010 Notebook
Power jack removal and installation
Hi there everyone.Please need help taking apart my Fujitsu lifeboook N5010,remove the power jack and install a new one. Can anyone help please? Thanks. PS: I remove all screws in the back of the laptop but still cant find the way to take it apart to get to the power jack !!!
  • 883 Answers
Most laptops use a combination of screws and tab/slots clamping to keep the clam shell halves together. The tabs fit carefully into the mating slots, so it is up to you to find them. Carefully press in on the sides where the clam shell halves mate and find locations where it is more difficult to press inward. This area will be a place where to find a tab/slot mate.
Posted on Aug 18, 2007
  • Marty marty Sep 03, 2007
    do you still need help with this?
SOURCE:
Install new power jack in asus u50f rbbago5
You need to have it done with an experienced technician... but if you really want to do it yourself, Please download the service manual of the Laptop model you have.
You gonna open the laptop by removing multiple screws, locate the power jack and do some repair or replace the power jack.
Please follow service manual on how to unscrew and open your laptop.
Feb 23, 2015 | ASUS Computers & Internet
Show me how to replace power jack
LOL, you've go to take the laptop apart because in most cases the DC Power Jack is soldered onto the motherboard. That means once you get the motherboard out of the laptop be prepared to spend an hour or two trying to desolder and remove the one that is bad. This is like being a surgeon. You have to be very careful or you will damage the motherboard. Once you've got it off, then you have to solder the new jack onto the motherboard and put the thing back together.
Apr 19, 2012 | Fujitsu LifeBook A6010 Notebook
Where i can buy, power socket for my amilo pro v2010?
Just one example,
http://www.laptopjacks.com/view_part/For-Fujitsu-Amilo-Pro-V2010-DC-Power-Jack-FJ41420.html
The power socket in the laptop that the AC adapter (Charger) plugs into is a DC Power Jack.
Type Amilio Pro V2010 DC Power Jack in your browser search bar, press the Enter key.
To add:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Nov 07, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
How do I replace fujitsu 2727 power socket
Get it fixed by going to jackfix.com , replacing the dc power jack requires taking apart the entire laptop, then removing the motherboard, and finally desoldering the power socket, and resoldering the new jack, and putting everything back together, its no job for a beginner. Not being rude at all, but if you have to ask how, dont attempt. http://www.jackfix.com , they have replaced many power jacks for my laptops, as well as my companies, they give a lifetime warranty, and will ship the laptop back to you within 24hrs. believe me, I have tried different companies, and they are def best.
May 11, 2010 | Fujitsu AMILO PC Laptops
Hi Mu c1020 have prover problem , it seems that
It sounds like the DC socket has either worked itself loose from the motherboard or it has broken off. Either way this problem can be repaired.
You have 2 choices available to you, you can take the laptop to reputable computer repair store and have them fit a new DC socket for you, or you can purchase a DC socket from places like eBay for example and disassemble the laptop to solder it in yourself.
In both cases the cost should be fairly inexpensive.
Please post back if you require anymore assistance.
Regards.
Jan 06, 2010 | Fujitsu Lifebook C1020 Notebook
Fujitsu lifebook n5010 notebook won't reboot i let the battery run out while working. next day, turned on three loud beeps, then three loud beeps then fan runs but no display on the screen. power off,...
Okay, sounds bad.
However, take out the battery from the laptop and remove mains lead. Go and make tea! Then, drink it. Once you have complete this task.
Plug in the AC lead ONLY into the laptop and then try to power it on.
You should see lights on the Hard Disk LED or hear a beep. If you see them but nothing on the screen at all when booting then the capacitor pack has probably gone on the screen. This is not an expensive part, but you do need to know what you are doing to replace it. Think it time to give it to the workshop or ask IT bod to look at it for you.
Oct 26, 2017 | Fujitsu Siemens Lifebook N5010 Notebook
DC power jack on a Fujitsu N6420
you can try take apart but when i did it was a night mare.i say take to shop.if it was a desktop i say you could fix it easy,but a laptop
take spacily tools to do it right
Jul 30, 2009 | Computers & Internet
Replacing power jack for hp tc4200 tablet - need manual
I do jack replacements. It requieres soldering and completely dissasembling the laptop. Do not attempt unless you know what you are doing and have the proper tools and work setup. If you still want to do it yourself (at your own risk of course) you basicaly need to take the laptop apart, remove the brokem jack (de-solder) and put in the new one. Use maximum of 15Watt soldering iron. You can get all the tools you need at a local radio shack or electronics store. Good Luck.
Jun 24, 2009 | Compaq tc4200 Tablet PC
Toshiba Satellite 1415-S173
Hi
DC jack replacement is easy however requires a bit care since its mounted on the mainboard. Desolder the old DC jack. Solder the new one firmly. Dont keep the soldering iron too long on the PCB as it will damage the lines and will deform the DC Jack. You can get DC jack very low cos from local repair stores or you can order from Toshiba parts depot (800-524-8338)
Please post your question if you need further assistance.
Good Luck
Feb 09, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Fujitsu Siemens Lifebook N5010 Notebook Logo
470 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Ekse
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
