Water Heaters Logo
Posted on Mar 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a digistat scr with a flashing red light and no heating there is nothing wrong with the batteries, this only occured after a poweer cut.
  • razzzzzor379 Mar 21, 2009
    After turning off then waiting 5 seconds then switching back on the red light starts flashing immediatly and won't stop
Donni Steen
Level 3:
  • Master 687 Answers
  • Posted on Mar 21, 2009
Donni Steen
Master
Level 3:
Answers
687
Questions
0
Helped
446634
Points
2142
Try this first before condeming the unit.
1. Turn off the power supply to the Digistat SCR (receiver unit)
and leave for 5 seconds.
2. Turn on power to SCR unit and check red light is on.
3. Press override button No.2 and check the green light comes
on and boiler fires.
4. Press & hold down button No.1 (Keep depressed), then
press No.2 and keep depressed. {The Red LED light will flash
a couple of times and then it will go out}
5. Now release both the buttons – {the two LED lights should
come back on}
6. Get the Digistat+2RF/+3RF unit and stand two metres away
from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
7. Remove the battery cover and fit the batteries.
8. The Red LED light on the SCR will now flash for approx. 7
seconds.
9. This confirms that the radio signal is being sent and
received.
10. The Digistat+2RF/+3RF and the SCR are now successfully
linked by a dedicated RF address.
  • Donni Steen Mar 21, 2009
    It sounds as though the power outage may have damaged the electronics. You will have to call a service tech in your area. Sorry I can't be of more help.
What could be the problem when red ligth is flashing on the hot water tank control?
If its 1 blink every 3 seconds its normal operation.
Otherwise, this is the meaning of the various blinks:
No blinks = no poilet light (not enough power (in millivolts) to keep it lit.
2 flashes = insufficient voltage (in millivolts) to gas valve.
4 flashes = high water temperature (over heat sensor activated.
5 flashes = water temperature sensor failure.
7 flashes = gas control valve / thermostat failure.
8 flashes = Only occurs if the gas control valve or Temperature knob has been turned off And the thermocouple continued to produce electric power.
9 flashes = Combustion chamber temperature sensor open or shorted.
10 flashes = LDO occurrence was detected in the combustion chamber (contaminants).
2answers
My heat tape around my water pipes light is flashing. Is it not working
It has failed, 2 options do nothing or replace it. Heat tape is disposable item and they fail regularly
1helpful
2answers
Unit won't operate and there are 4 flashes on the red light.
Two things- Clean the sensor rods or replace(cheap and easy with YouTube instruction video) and at the same time replace the main program chip (also a easy plug in chip). The whole repair takes two hours for a homeowner and costs about 50 bucks for a chip. These are easy an generally the flame sensor rod is the culprit. The code may also be the limit switch but try EZ and cheap first. See You Tube..
https://www.youtube.com/watch?v=npxcVo7RK2c
No heating and hot water
sounds like overheat stat easy job to replace and do,nt cost the earth best of kuck
2answers
Red alarm light on constantly and heating wont work unless over ride system
Have you tried turning one of the thermostats off.? They are both talking to the same unit and they may be arguing with each other.
5helpful
Siemens central heating control
I have a Siemens "Radio" Room Stat - the receiver has switched itself off. How do I restart it. I have pressed the restart button and the reset - nothing happens except for red light flashing and then off. I do not have the instructions. Where might I get them?
J W-K
Top Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Water Heater Expert? Answer questions, earn points and help others
