Question about Sony MHC-RV777D 220 Volt Hi-Fi Music System Shelf System
Original DVD plays black and white
Hi, I have a Sony MHC-RV777D 220 Volt Hi-Fi Music system. The thing is that when I insert an original DVD it doesn't play in color.i.e it plays in black and white. Could anyone help me with this plz
I thing Shivi comments r wrong. Sony and most of the dvd player supports ntsc colour system for DVS and pal for vcd. Set ur tv colour system to auto or ntsc
Posted on Nov 03, 2007
It seems that you have get the color system setting of your Tv wrong. Sony uses the Pal(it's a format for the transmission of signals) color system , so check into your TV's color system settings and change it to pal , if that doesnt work then change it to Ntsc.
Posted on Oct 04, 2007
SOURCE:
I can not able to open the dvd tray in sony music system mhc-rv777d
If your system was not used for a long time , then there are more possibilities for failure of belt . I have also faced the same problem. Better get the belts replaced in SONY Service Centres
Dec 25, 2013 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
No Audio on MHC-RV777D
its a commom fault in all the Hi fi system.its a dry fault put soldering in all components. the problem may be solved.
Nov 21, 2012 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
My sony mhc-rv777d is not working when i on my sony within 4or 5 sec it off automatically so i need a solution
MHC-RV777D shuts off itself because of protection mode that is activated to avoid further damage due to defective amplifier output IC in unit.
You need to check/ replace output amplifier IC to solve this issue, if you are not familiar with electronics stuff repair then local repair shop will do this job for you.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Nov 03, 2010 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Not getting high depth of bass sony MHC-RV777d
I wouldn't expect huge bass from those little speakers. Somewhere on there, there's an equiliser, where you 'll probably be able to turn the bass up and down. See if that works. If not, new speakers may help.
Jan 08, 2010 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
How to incrise the bass of sony MHC-RV777d
Is it possible that the speakers are out of phase, where one speaker is moving out, the other is moving in, resulting in zero bass?
Other than checking wires, making sure + on amp is linked to + on speaker, try changing the eq settings, or sit them next to a wall - walls help bass a lot.
Displaying ' protect power ' on the screen.
Replace the audio amplifier IC because are damaged
Aug 29, 2008 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Sony MHC-RV777D 220 Volt Hi-Fi Music System Shelf System Logo
200 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
