Question about Netopia ADSL 2+ MODEM 10/100 EN AND USB FIREWALL SECURITY Router (2241NVGX)
CE-100 Futura Embroidery Sewing Machine
I followed all the instructions that I printed off the website. Windows isnt allowing the program to come on. I disabled the windowsupdate. I went to www.futura-support.com for my instructions. I'm using windowsVista connected to the ce-100 futura embroidery machine by a usb cable. Help if you can genabusch@sbcglobal.net
  • genabusch Aug 20, 2007
    Thanks so much for coming up with a fix. I'll give it a try and see how it goes. Great detail also :). Gena Busch
  • 12,061 Answers
OK you could try Installing & then Running the "Program" in "Administrator mode", & set Compatibility Mode for XP. Ie: Uninstall completely, Install software as Administrator Mode & then after installed, set the main .exe, for Compatibility Mode for XP... and set to RUN with Administrator rights. ONLY THEN after it is all installed.. PLUG THE DEVICE IN... if it asks for "Drivers" point it to ya Install Disk. Also try to use "any other" USB port when you reinstall. Ensure B4 ya do all this that you have the most up to date drivers for your system's USB. Good luck hope this help?
Posted on Aug 18, 2007
What can you do to stop squeaking when I'm winding bobbin
Spray wherever the squeak is coming from with a dry silicone lubricant called 'Jigaloo' or WD40 Dry Silicone Lubricant. It is also great for sliding windows.
WD 40 300014 Specialist Water Resistant Silicone Lubricant Spray 11 oz...
Jan 13, 2016 | SewShop.com Singer Model CE200 Quantum...
Machine will not work on windows 7 64 bit computer will not load singer discs bought new computer old system was X P
First, there's a Windows 7 update available atwww.Futura-support.com. Click on the lefthand side, then on CE100/150/250/350,etc, etc. Follow the directions CAREFULLY. First, be sure the uninstall ALLFutura software you've attempted to install and reboot your PC.
If for some reason this doesn't solve you're problem, I've posted a set ofinstructions athttp://www.fixya.com/support/r8955271-use_machine_windows_7_or_vista that willallow you to run the software under XP on your Windows 7 machine. This is a bitmore complicated a solution, but if you follow the instructions carefully, youshould be fine. Try the Futura update first, though.
I hope this solves you're problem. Happy embroidery!
Apr 26, 2011 | Singer CE-100 Futura Computerized Sewing...
Just bought this machine and installed the software. When I try to use I get a message: Can not run CF_Splash.dll
It sounds like you are trying to use the software on Windows 7 or Vista. There's a patch at www.Futura-support.com you'll need. On the lefthand side of the screen, click on downloads, then choose CE100/150/250/350, etc, etc. Follow the directions CAREFULLY. Be sure to install ALL Futura software you've already installed and reboot your PC BEFORE starting the new instructions.
If for some reason this still doesn't solve your problem, I've posted a solution that's a bit more involved on the CE100 Problems & Solutions home page for running your machine on Windows Vista/7. Basically, it allows you to run any XP program on Windows Vista or 7 using your old XP software. The Futura patch works for most people, though, so you will hopefully not have to go that route.
Happy embroidery!
Feb 15, 2011 | Singer CE-100 Futura Computerized Sewing...
Need Software, Singer Futura CE-100 Embroidery Machine,lost cd evelyn.hardy@hotmail.com
Unfortunately, the only place I found after searching and searching months ago was to go back to Singer itself and pay for a new CD. The cost was $100 as of January, 2011. It doesn't do any good to copy someone's CD or for someone to get it to the internet for you to download, because when you go to install the software the program asks for you to put the CD in the drive, and the program knows to look for an original CD.
Jan 15, 2011 | Singer CE-100 Futura Computerized Sewing...
Is there an alturnitive program for singer futura ce-100 embroidery machine?
No, there isn't. Wish there was. The only place you can get it is from Singer by purchasing a replacement CD from them.
Dec 12, 2010 | Singer CE-100 Futura Computerized Sewing...
I have a Futura CE-100 and got a new laptop with Windows 7 and can not get the software to install. Gets to 100% and won't complete. How can I fix this?
First, there's a Windows 7 update available at www.Futura-support.com. Click on the lefthand side, then on CE100/150/250/350, etc, etc. Follow the directions CAREFULLY. First, be sure the uninstall ALL Futura software you've attempted to install and reboot your PC.
If for some reason this doesn't solve you're problem, I've posted a set of instructions at http://www.fixya.com/support/r8955271-use_machine_windows_7_or_vista that will allow you to run the software under XP on your Windows 7 machine. This is a bit more complicated a solution, but if you follow the instructions carefully, you should be fine. Try the Futura update first, though.
Nov 23, 2010 | Singer CE-100 Futura Computerized Sewing...
Singer futura ce-100 wont start
Do you still have the embroidery arm attached? If you do, the sewing function of the machine won't work.
Mar 24, 2010 | Singer CE-100 Futura Computerized Sewing...
Original cd that came with machine will not download. it gets to 93% then and error message comes up.
Jan 31, 2010 | Singer CE-100 Futura Computerized Sewing...
Futura 100 Embroidery machine...Need to cancel previous transmit
Had the same problem. Singer rep. solved this mystery in just min. after talking to her.
You can call singer company at 1-800-4SINGER. It will take a long time to get through, but they can talk you thru to resolve this matter. Or just visit singerco.com and go to F&Q section, #7 question.
Or you can email talktous@singerco.com (that's talk to us @ ...)
They answered my email the same day!
Hope this helps!
Jun 19, 2009 | Singer CE-100 Futura Computerized Sewing...
My software won't run on the vista windows
I had the same problem. I called a singer service center and he told me that was a major issue with the futura....no software made for Vista. I was determined to find a solution and finally found a patch. Here you go: http://www.futura-support.com/downloads/patch.htm#
May 12, 2009 | Singer CE-100 Futura Computerized Sewing...
Netopia ADSL 2+ MODEM 10/100 EN AND USB FIREWALL SECURITY Router (2241NVGX) Logo
62 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
