Question about Fellowes Powershred 220CC Shredder
Shreader won't turn off.
Only way to stop it is to touch the hand guard.. works fine just won't turn off.
  • Anonymous Nov 29, 2007
    Fellowes Home office shredder will not shut off after shredding papers.
    Scholar:
  • 41 Answers
The paper sensor is stuck, actually a pretty common problem with many auto shredders. Basically the sensor for auto shredding thinks that there is still paper in the unit so it won't shut off. This can easily be caused by shred debris. Shooting some compressed air into the unit may help but usually it requires a bit more effort. Sadly, these guys can be quite hazardous to repair so I would not really suggest trying to open the unit unless you really know what you are doing.
Posted on Aug 30, 2007
THe air worked great!
Posted on Oct 07, 2007
SOURCE:
How can I get my Seville desk fan to stop squeaking? When I called their toll-free number, they said their fans don't squeak. Talk about a company being in denial!! Their only suggestion was to take it to...
Remove the guard, remove the fan blade. Lay the fan on its back and drip 4 drops of 3 in 1 Oil down the spindle. Turn the spindle by hand about 6 turns and leave it overnight with the spindle upwards. The next day, run the fan with the blade off and see if the squeaking has stopped. If it has, replace the blade and guard.
If it is still squeaking, it is the bearing at the other end of the motor. That one is not quite so easy to lubricate and usually the motor would need to be fully stripped down, cleaned and lubricated.
Aug 24, 2015 | Dryers
Chainsaw chain sprocket won,t turn
this seems to be a chain brake that's applied , try turning off chain brake by pulling back on hand guard till a click is felt
some folks moving up from an older saw to a more modern saw are not so familiar with chain brakes and don't understand them and how they work
May 25, 2014 | Ryobi Factory Reconditioned 18" 40cc...
My chain won't run on my 240 eseries when I try to release it ti cut
The hand guard on the machine should control the chain brake, you should be able to firmly pull the guard fully back to the top hadle to load the brake, if the saw has been run for any time with the brake on there may well now be some melting of the plastic cover, this will mean a new brake complete required, you will have to lever the brake off the saw as best you can, it will be tight because the band will be clamped around the drum, this should only be done as a last resort if pulling the hand guard back does not work
Oct 03, 2012 | Garden
Hand held vacum suction stopped after 1st use. Was working fine, suction does work if onfloor but won't once turned to tool
go to the web page and see instructional video and maintenance help
http://www.bissell.com/how-to-videos/
God bless you
Jul 19, 2012 | Bissell 2X Proheat 9200 rug cleaner
Why won't the chain mechanism turn
It may be because the chainbrake is on, grab the hand guard and pull it firmly back to the top handle until it clicks and loads the brake.
Aug 05, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have tried numerous times to undo a nut on my Black and Decker circular saw without success. which way do I turn the nut to undo it and take the circular saw blade?
Am I correct that this is a hand-held saw? Want to make sure of the terminology.
If so, the bolt holding the blade has right hand threads -- meaning it loosens by turning counter-clockwise.
Is there a blade lock? Are you using it?
Apr 30, 2009 | Saws
Won't turn over
RESET THE GUARD AT YOUR LEFT HAND. THERE IS A GUARD AT THE TOP OF THE HANDLE THAT KICKS WHEN THE CHAIN COMES OFF.THAT SHOULD DO IT. GOOD LUCK.
Apr 28, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Jan 24, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Fellowes Powershred 220CC Shredder Logo
297 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
midnightmove
Level 1 Expert
quennie732
gggg
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
