Question about GE WBSR3140DW Top Load Washer
Water inside the drum
Just a little bit of water remains inside the drum, it is not visible though and it smells afterwhile
  • 883 Answers
There may be a foreign object that is partially blocking the drain from the outer drum. open the back and remove the drain hose connection from the drum. Using a long screwdriver as a test prod, carefully try to feel this foreign object. Also try to look up into the drain outlet using a flashlight and mirror.
Posted on Aug 18, 2007
  • Marty marty Sep 03, 2007
    do you still need help with this?
How do I stop the old water smell (earthy odor) in my LG front load washer?
All washers keep a certain amount of water in them, though front loaders, especially the newer ones, are prone to odors. This is because the are more energy efficient and use less water. That can result in more residue being left behind on the outside of the wash drum where you cannot see it or access it to clean. Some things that are helpful:
  1. Do not close the door of the washer after use. It will allow the interior to vent and dry out, reducing odors.
  2. Use only the recommended detergents, and in the amounts recommended. Many people use too much soap in HE washers. A tiny bit goes a long way.
  3. Use a front loading machine cleaner - they are sold in most grocery stores. These help clear the residue from the drum, reducing odors.
Sep 01, 2015 | LG WM-2277HW Front Load Washer
LG WD12020D Inverter Direct Drive 7.5kg front loader. Has never had visible water level in the drum. I have even stopped the machine, turned off the power, waited for the door to unlock, pushed the wet...
No water that high. But you may have an extra water button that allows you to add slightly more water to each wash load. Water should be just above bottom of inside drum in the back of the drum as it rotates
Jul 01, 2017 | LG Washing Machines
When empty, I can turn inside and sounds like there is water sloshing inside
This is not a problem actually. That is quite normal for top load washers. What happens is when the pump comes on to expel the used water it only runs long enough to empty the inner drum. The outer drum still has a little bit of water inside to act as a pea trap of sorts. This keeps undesirable smells from reentering your pipes and causing bad Oder's in your home. As long as your cloths come out clean and partially dried from the spin cycle then your washer is working correctly. Hope this helps. Good luck.
Mar 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer, buring rubber smell, drum won't turn
the drum should run free if not the bearing have gone and seized they will need to be replaced. hear is a video there are others you can find the bearing kit on line using the model number https://youtu.be/WGolkFlgl3Y
Jun 22, 2017 | Maytag Washing Machines
Bosch dishwasher is not draining all the water at end of cycle. In the bottom of the dishwasher under the mesh trap there is about a cup of water remaining after each cycle.
This is normal with a Bosch. They don't really vent out when they heat, and use a type of evaporation technology to dry the dishes. Best bet is to make sure first that the filter in the bottom is clean, (the little circle thingy on the bottom, turn it a quarter turn and pull it out, run it under cool water till it's clear, then put it back in the same way.) If the water is bothering you or is beginning to make a bit of a smell in there, leave the door cracked a little after you empty the dishes out. unfortunately though, it'll always leave water in the bottom. European technology.
Sep 06, 2009 | Bosch Dishwashers
Water remains in tub after spin cycle
Have you tried to clean the drain hose on the back of the washer? It may have build up inside that you are loosening up by using bleach.
Sep 06, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a Hotpint Aquarius CTD00 Condenser Tumble Dryer, it has stopped drying the clothes. It occassionally works on the high setting (but makes my clothes smell a bit burned out and shrinking) but it...
it could be blocked up with lint, take out the condenser (silver fin bit) and clean run under a tap if necessary, this is the most important bit of the condenser if this is dirty it reduces the efficiency of the dryer. clean all filters with a vacuum cleaner even remove them and clean where they sit in the machine with the vacuum cleaner.
for the reservoir remove a check the inlet is clean and clear. look inside the machine where this is located and again clean and clear this area, then using something long and thin press open the valve that the reservoir mates with (this can often stick with lint and water residue) be-careful though when opened the valve will **** out water so have a few towels to catch it all. and finally raise the front feet a little this will help the water fall to the reservoir.
if this does not work the internal tank may have fluff and this would be a big job to get to this and clean it you have to strip the drum out which can be a pain.
Jul 22, 2009 | Hotpoint Dryers
Not enough Water in Washing machine
i think the problem came from a rins water is little
1- you will check the pressur of water inlet it is easy throuw the soap drawer
2-try to clean the inlet water filter by teeth brush
good work thanks
Jun 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dirty washing
Does your washer smell? Is your rubber door seal gungy too?
If so then use 1/2 cup of Washing Soda Crystals (50p for a 1kg bag from most supermarkets)
set washer to 60 degree wash and run machine for full hot cycle with no clothes in it... just the Washing Soda.
I did this with my washer which literally reeked, and my friends have since done theirs and the results are amazing...
Go and check your drain when you finish too... mine sparkles now and it was gunged up before.. I now add a desertspoon of Washing Soda to every wash.... I place it in the crease of the door seal and little by little all the mould is disappearing, even though the hot wash cleaned the gunge the black spots remained. My washer smells so clean now and no more black flecks on the clothes either... (these are loose gunge from the outer drum, right inside the works of your machine...)
All the best
Sue
Aug 02, 2008 | Hotpoint WF430 Front Load Washer
Filling
have u got the echo-fill button on if it is it will only fill up with very little water other than that without seeing it cant say
Aug 12, 2007 | Zanussi IZ12 Front Load Washer
GE WBSR3140DW Top Load Washer Logo
102 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
