Question about Nokia 6030 Cellular Phone
Hi i just wanted to check weather my battery is fine or not my battery number is O670400363563 N295613102355
  • Anonymous Mar 18, 2008
    MY PHONE
    MY PHONE IS AUTIOMATCLY SUICH OF
I just want to know that when ever accessing my web connection it is asking pocket data connection not available, what should i do for this
Posted on Aug 28, 2007
Can a bendix freeze in cold weather
Not really. Check the starter connections. Loosen the nuts for the ignition wire and battery cable at the starter. Then retighten.
Jan 07, 2017 | Cars & Trucks
What could be a possiable reason my Hyundia want crank in the cold weather, but will crank fine when it's warm weather
Temperature plays a big role in electrical connections. Start with the battery cables and check them for corrosion and tightness. You may also have an issue with loose corroded connections at the starter motor itself or dirty/loose ground connections from the battery to the engine or engine to the body
Jan 04, 2016 | 2000 Hyundai Elantra
Cool mornings it doesn't want to start ,i have to turn the key to start and let it off several times and it will eventually start after that it starts fine all day and starts fine on warm days
How to Start a Car in Freezing Cold Winter Weather
www.wikihow.com > ... > Cars > Car Maintenance and Repair
wikiHowFreezing cold weather can take a toll on car batteries. ... It's much more difficult to start a cold car with a mostly-empty tank, so do yourself a favor and gas up ...
Why is it so hard to start a car in the winter? - HowStuffWorks
auto.howstuffworks.com/car-driving-safety/.../start-car-in-winter.htm
To start a car in winter, your engine has to work extra hard. Learn the top 3 reasons your car is hard to start in cold winter weather.
Debunking 5 Cold-Weather Car Myths - Popular Mechanics
Nov 21, 2015 | Cars & Trucks
I have model 00606TX. I had to replace the batteries on both components but cannot get the outside temperature to register on the display. I checked that the batteries were installed correctly and t
Hi Stephanie!
We would need the model number of the main display unit to give full instructions or you can visit; http://www.acurite.com/kbase
and enter that model number for troubleshooting tips and steps.
Nov 22, 2014 | Measuring Tools & Sensors
Acurite wireless weather will not work new last season all new lithium batteries in right and were checked no picture #'s on screen
Hi Jerry,
While lithium batteries are recommended for the outdoor sensor it is not recommended they be used in the indoor display unit. Try using a good quality, fresh alkaline batteries and you should find your display turns back on.
Nov 01, 2014 | Acu-Rite Acurite Wireless Weather...
Want start in cold weather
battery when you get cold wether the battery uses more power to crank the car over causing it to get week if its a diesel could be the heaster plugs hope this helps
Oct 20, 2012 | 2002 Ford Explorer
92acura legend fuel pump reset switch
There isn't a reset switch for your vehicle like a Ford would have. If you are not geting power to the fuel pump or even the injectors, a common problem in Honda/Acura is the PGM-FI relay. I have found them to not work in hot weather but work fine in cooler weather. Below is a picture and location of this relay. Also did you check the 20 amp fuse under the dash in the fuse panel. The fuse you want to check will be the number 22 fuse (see picture of fuse layout below). Hope this helps.
Dec 05, 2011 | 1992 Toyota Previa
The rain gauge will not record the rain fall. It displays 0.00 on everything except last month. I now have it in the house have checked the batteries(they were fine) have cleaned it (it wasn't dirty) and...
You say 'the batteries were fine'. How did you check? With my weather station, the main station will not display the outside temperature when the battery gets to a certain point. The display on the weather station is fine, but it doesn't have enough power to pick up the data from the outside sensor, despite not being very far away. Replace both sets of batteries to be certain.
Nov 22, 2017 | Honeywell Professional Weather Station...
My 89 mazda mx6 LX was starting up just fine....but now it isnt. it only wants to turn over sometimes. more often than not it wont even try to turn over...could this be a fuel problem? or could this be a...
this cold weather were having is badly affects the car battery's. you may need a new battery. battery life is shorted by short journeys, cold weather, dampness and age.
Dec 22, 2010 | 1989 Mazda MX-6
I have a 53 plate BMW X5 Diesel. Recently with the cold weather it wount start in the am? I have had the battery checked and it seems fine?? When the car is started it runs fine all day and will switch on...
A very common fault with them in cold weather is the lift pump, an in-line torpeedo like pump situation half walf between fuel tank and engine under the car.
Part number is 16146767383 however buy off BMW it'll be expensive so order the exact same one off Land Rover under part number WQB100482 and save £££s ;o)
I am 99.9999999% certain this is your issue.
Dec 02, 2010 | 2001 BMW 5 Series
Nokia 6030 Cellular Phone Logo
49 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
