Question about Netopia ADSL 2+ MODEM 10/100 EN AND USB FIREWALL SECURITY Router (2241NVGX)
Netopia adsl modem
How do I unlock the usb port on my netopia modem?
  • 12,061 Answers
I don't understand what you mean by "Unlock" the USB? I presume you perhaps mean how can you "Use" it? The USB Port. What needs to done in this case, is to Install the "Driver" that will allow the "System" to "See" the USB Device.. When you plug the Device into the PC, with ya USB lead, the PC should "See" it, beep twice, and if it hasn't been installed B4, will, if it cannot find any "Generic Drivers", then, "Ask" for "Drivers". (These may be on CD etc.) When windows has installed the USB "Drivers" your device will be ready to be used. Some Modems have Both an Ethernet connection & a USB one too... this allows two (2) ways to connect it to your "System" OR two (2) ways to be connected to the modem for two (2) PC's simultaneously. The Ethernet one generally has the address 192.168.0.*. Whereas the USB one is generally 10.0.0.*,or 10.1.1.* You can also "Bridge" these two together.
Posted on Aug 18, 2007
SOURCE:
How to update sagem [email protected] 2804 stc modem
default STC password for Echolife HG532b a.k.a. Afaq shamel 007 :
address: 192.168.1.1
username: Afaq_Shamel
password: Stccpe_2009
for Echolife HG532b
Jan 24, 2013 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
How do i set up my wireless router
you can go to this website below
http://www.netopia.com/support/hardware/technotes/NQG_110.html
follow the directions below to setup your wireless network.
Mar 20, 2011 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
Why do my Ethernet and Internet light keep blinking?
Some routers blink to show there is ACTIVITY on the ethernet and internet ports, For example you broadband modem is connected to a port on hte back of your router this has a light it would blink on some routers to show activity, and likewise with the ethernet side.
If you have internet access and have zero issues this is NORMAL.
thanks for your question please do rate your answer, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 05, 2010 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
I need to get port forwarding info from a retired netopia 4541 adsl router. does it have a web interface or do I need to use telnet?
Telent is usually not an option these modems but will depend on the service provider if this feature was set up. Plug in and connect a PC to the LAN side of the modem. Refresh the network connection on the PC you connected to get the IP address from the modem. Once this is completed, open a web browser up. In the address enter http://192.168.100.1 and this should take you to the modem's management page as this is what most DSL modems use. Make sure to have your old user name and password as most modems will prompt for this.
Feb 05, 2010 | Netopia 4541 ADSL Router
I hv a netgear wireless adsl modem and i m using bsnl broadband connection can send me the settings to configure the modem at my email id [email protected]
TYPE-I Modem Configuration - Huawei SmartAX MT880 Modem / SmartAx MT882 ADSL Modem Configuration
SmartAx MT880 ADSL Modem has One ethernet Port.
SmartAx MT882 ADSL Modem has One ethernet Port and one USB Port.
Set your computer IP address as 192.168.1.2
( If you are using USB port, install USB driver first)
Open Internet Explorer in the Address bar type the URL http://192.168.1.1
You will be propted for Username and Password.
Username: admin
Password: admin
Click on Home
Click on WAN setting
Your WAN Setting should be as follows:
PVC No.: PVC0
Wan type: PPP
Connection Type : PPPoE
VPI / VCI : 0/35
Default Route : Enabled
Username: [email protected]
Password: yourpassword
Use DNS : Enabled
Click on Apply.
You will be asked to save and reboot.
Select Yes
Once your modem is rebooted , the summary page will be displayed .
The "Green" status of PVC0 status indicated that you are now connected. (in Summary page)
SmartAx MT882 ADSL Modem ADSL LED will turn 'Orange' from 'green' when succesfully connected
Sep 15, 2009 | NetGear WGR614 Wireless Router
AT&T Netopia DSL modem not opening ports for web servers
Try to open the required ports of your web server on your router.
Mar 05, 2009 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
Setting up linksys adsl2 modem
The ADSL, Ethernet, and USB ports are located at the back of a Linksys modem. These ports are where the phone cable and computer will be connected. The ADSL Line should be connected to the ADSL port and the computer either be connected to Ethernet or the USB port., If u r using a ethernet cable no need to run the setup cd just connect the ethernet cable and contact ur isp..
do not worry about ur sagem modem, let it be inside.. just connect ethernet cables alone..
To setup a Linksys ADSL Modem with usb cable you need to perform two steps:
  1. Connecting the Devices Together
  2. Installing the USB Driver
Step 1:
Connect the phone cable to the wall jack with ADSL service and then connect the other end to the ADSL port of the modem.
Step 2:
Make sure the power adapter is plugged to an available power outlet.
Step 3:
Connect the USB to the USB port on the back of the modem and then connect the other end top the USB port of the computer.
Step 4:
Power on the modem. After connecting the device together, install the USB driver. For instructions, follow the steps below.
Step 1:
Power on the computer.
Step 2:
When the Hardware Update Wizard window appears. Click Install the software automatically (Recommended).
NOTE: Windows XP has pre-installed drivers for the ADSL2MUE and will automatically install the USB driver for the modem.
Step 3:
Click Finish.
Nov 06, 2007 | Computers & Internet
Netopia 2241 Modem losing sync?
If your modem is losing sync with ADSL 2 that means that your line has a problem. Try having your DSL provider move you to a new Cable and pair.
Sep 11, 2007 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
Netopia modem
Go to control panel press on add/remove hardwear and when promted to search for new hardwear press on next.And continue as if installing a new hardwear and you will reenable your USB port.
Aug 18, 2007 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
Netopia ADSL 2+ MODEM 10/100 EN AND USB FIREWALL SECURITY Router (2241NVGX) Logo
263 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Ekse
Thomas F. Schneider
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
