Question about MSI MBOX PM8M2-V (MBOXPM8M2V) Barebone
Loss of power to onboard USB and PS2 ports
The Vcc supply of one of the onboard USB ports was shorted, there is now no power to any of the onboard USB ports or the PS2 ports. I assume the is a fuseable link on the motherboard somewhere ?? I have have reset the drivers etc and it appears to be hardware issue
    Brigadier General:
  • 6,966 Answers
Hi, I checked a known good spare motherboard with a VOM (continuity tester): pin 4 of the KB PS2 port, pin 1 of the rear USB, pin 1 & 2 of the front panel USB onboard connector, pin 3 of the infrared, pin 4 of the speaker connector, pins 4, 6,21 & 22 of the ATX 24-pin Power Connector are all interconnected (+5VDC). If that is an indication of the general +5 supply layout, you can probably hard wire a new +5 supply line to where the +5 is gone from where it is still available. Of course without a schematic, I might be off. Determining the actual component position of the surface mounted fuse (or fusible link) might not be that easy since manufacturer do not publish such information loosely. A shotgun approach (test all) would be time consuming but of course challenging. Your best bet would probably be as mentioned earlier, hardwire and install in series with the new +5 line a low amp (500ma or lower) smfuse. This article describes the power requirement of USB ports > http://pinouts.ru/Slots/USB_pinout.shtml. Hope this be of some help to you. Pls post again how things turn up. Good luck and kind regards.
Posted on Aug 18, 2007
6ya staff
SOURCE:
My computer mouse and keyboard not functioning well. I replace the keyboard but only last a month.
Hi jhunix,
I'm going to need even more information; The devices that use PS2 connections, which device is it, and how many of those devices do you have?
One thing that might be a problem, if the issue you see is intermittent, I would check the PS2 connector and see if the pins are bent or broken. PS2 connector pins sometimes will bend or break and this can cause some connection issues if not completely stop the keyboard/mouse from working... Also given the age of your PC the PS2 port may just be bad, but this is not a fatal injury to a computer.
Replacing the Keyboard and Mouse with a standard USB keyboard and mouse, should resolve all of your issues.
PS2 is an older technology that keyboards and mice used to run on; Now however USB connections are used.
Further more, if this an HP Desktop with 2 USB ports on the front, and 4 USB ports on the back, you will want to avoid using the 2 USB ports on the front, especially on older HP and Dell Desktops, the reason is the power supplies often do not have enough power to run multiple USB devices on the front USB ports.
The back ports should be fine regardless of the number of devices.
Hope this helps.
Dec 10, 2013 | Computers & Internet
My internal power rest ribbon cable is gone is there any way to turn on my ps2 with out it?
Short answer, no. The ribbon supplies power to the motherboard, the disk drive and the usb ports, as well as the controller port. Without it, nothing will work.
Sep 09, 2013 | Sony PlayStation 2 (PS2) Console
Dual shock 2 wire digrem
The pinout is as follows when looking into the cable like this;
__________________
1 ' * * * ' * * * ' * * * ' 9
\_________________/
Pin Name Description
1 DATA Data
2 CMD Command
3 +7.6V
Dualshock and Dualshock 2 uses this for powering vibro-motors. Voltage on PS2 is 7.6V, however many sites says it's 9V. But it will work on 9V too.
4 GND Ground
5 VCC Vcc
6 ATT ATT select
7 CLK Clock
8 N/C Not connected
9 ACK Acknowledge
~KenjiFox
Jan 07, 2011 | Sony PS2 Dual Shock 2 Controller...
Ps2 port doesn't recognize Microsoft Optical mouse
You might think about a USB hub for all your USB devices. ps2 port is more or less dedicated for mouse, which is why your mouse pointer is stuck in the middle of the screen. Go ahead and get an externally powered USB Hub to power other USB devices. To answer, ps2 for mouse needs just a mouse, not USB device.
Sep 28, 2009 | Microsoft Windows XP Professional
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Replaced my power supply, now keyboard and monitor wont work.
Believe it or not, if you have a floppy drive in your computer, try unplugging it and disconnecting the data ribbon. Many times, damaged floppy drives can short out motherboard functions and even prevent computers from powering up. If that doesn't fix it, then get a usb keyboard and mouse set (wireless would be fine) or borrow some, and see if they work. If they do, then the power outage damaged the PS2 ports.
May 25, 2009 | E-Machines eMachines Monitor E15T4
Usb slots in front of d cabinet
Open the case,You can find the cables just attached to the backside of Port on case.Normally they are indicated by vcc,gnd,+,-
Now check if your motherboard had got USB1 ,USB2 written on it .Your pin no 1 is the one which is mark by small square/ small trangle indication / Numeric 1 ,Now you have to attach VCC to pin 1 , Port- on pin2 , Port + on pin3 ,and Gnd on pin4
Mar 15, 2009 | Computers & Internet
Cant connect ALL instruments/mic to PS2 Guitar Hero World Tour?!
Yes, you can buy a PS2 Multitap Adapter. I had the same issue and just picked a mulittap adapter up on eBay for $8.50
Dec 30, 2008 | Sony PlayStation 2 (PS2) Console
Onboard usb problems
i think the capacitor near by the USB port is burned out so there is no power storage or power supply for the USB ports so just have a check with the capacitors near by the USB ports if you are good at recognizing that problem ..
otherwise just contact the motherboard technician ....
he will have a check and if the capacitor is burned out he will replace it ....
any doubts reply me
i am always here to assist you
thank you
bye
Jun 17, 2008 | MSI 865G Neo2-PLS Motherboard
Power failure after connecting the mouse
Hi sambi,
If you are currently, working on PS2 mouse port which is the error occurred as stated in your problem. Try to used other PS2 mouse which working on the other pc maybe there was a short circuit on your old mouse. If the problem persist, You can use the alternative way by using USB port to plug your optical mouse.
Try to look for ps2 to usb port converter in the computer stores maybe you can still used your old mouse.
Hope this will be helpful to you.
Best Regards,
Philip
Oct 24, 2007 | Computers & Internet
Open Questions:
See all MSI MBOX PM8M2-V (MBOXPM8M2V) Barebone Questions
MSI MBOX PM8M2-V (MBOXPM8M2V) Barebone Logo
709 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
