Question about Sony Handycam DCR-HC30E Mini DV Digital Camcorder
Code error: C:32:11 tape won't play or eject
The camcorder doesn't seem to reconize that the tape is in or when the door is open to eject.
  • theperish Nov 23, 2007
    Same thing happening with mine. Fell on floor and cracked the LCD screen about 6 months ago. I was still able to record/playback via the remote in easy mode.
    The C:32:11 error just started coming up recently and now it the cartrige tray doesn't want load at all. Upon power cycling, it will eject the tape - but the problem now is that it begins the load process, opens the 'hatch' on the cassette, feeds about 2 inches of mangled tape out and then ejects...
    Think I may just have to go buy a second Canon HV20 now, with a full 'break-it/replace-it' warranty! grr...
    Master:
  • 619 Answers
Warranty is your chance to repair the camera which is not expensive.
Posted on Jan 10, 2008
SOURCE:
Why do I get the error code C:32:11 or C:31:42?
Does it try to eject the tape? Try a gentle help on that. The tape may have gotten snarled in the camera.
Sep 03, 2014 | Sony Handycam DCR-TRV280 Digital Camcorder
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
When i try to play back i get error, take battery a loose and reattach bur=t it does no good
Go down further with the error message and look for the numeric code like "02 or 03 etc". If its '03' try to use another tape, to eject, open cassette door and hold until it eject(around 5 sec). If "'02" have it service by the company. If you do the job change motor bracket assembly(mode motor). Good luck.
Mar 01, 2010 | JVC GR-D271U Camcorder
Cassette jammed after camera dropped
I think your ejecter motor is not working.temporarily open with any tool.
Dec 10, 2008 | Sony Handycam CCD-TRV107E Camcorder
Tape eject door will open but tape will not eject
got door open and looked in and saw what looked like the tape head sitting very slightly proud of tape and believe it or not inserted a very thin and pointy bladed knife up as far as the head then pressed it down on top of the head very lightly and the head slid down its shaft to its original position switched camcorder back on and tape then ejected as per normal and it has worked normally since and as i did'nt touch the head (face?) no damage was done and it can record and play with no problems, a little unorthodox perhaps but it worked for me and saved me a probable fortune
Apr 09, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
Error Code C:32:11 Tape does not eject
try removing the button cell battery, main battery, and any other power source from the camera and let it sit for one hour. THen using only the AC adaptor, see if the camera works, if it doesn't then you may have to take it to a repair shop, cause the cassette door has malfunctioned.
Mar 23, 2008 | Sony Handycam CCD-TRV37 Camcorder
Cannot eject VHS tape from Sony SLV-X811
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
Feb 29, 2008 | Televison & Video
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
CAMCORDER GR-DVL167EK
YOUR TAPE MAY BE DAMAGED IF YOU TRY TO OPEN THE CAMCORDER - HOLD EJECT BUTTON DOWN BEFORE ! YOU REATTACH BATTERY THEN READ THE ERROR CODE ? IF IT STILL DOES NOT EJECT .
Sep 10, 2007 | Video Cameras
Tape door will not open
the tape eject door will not open there is currently a tape in the camcorder (panasonic pv-l559)
Jan 09, 2007 | Panasonic PV-L559 Camcorder
Open Questions:
See all Sony Handycam DCR-HC30E Mini DV Digital Camcorder Questions
Sony Handycam DCR-HC30E Mini DV Digital Camcorder Logo
197 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
