You need o have the battery installed in the radio in order to be charge. For the most part, the radio can be on and will charge you batteries. However, if you can, let it charge overnite... this usually is the recommendation given at the manual.
I agree with BillB-SA...
Let us know how it goes!
Joe-k4jga
The BC72XLT is a battery-operated scanner, and your power supply is a battery charger, not a battery eliminator. You must have batteries in the unit for it to operate. You can install rechargeable batteries and use it in conjunction with the power supply, or you can run it on non-chargeable alkaline batteries.
What model Uniden scanner is it? All scanners that I have seen require batteries to be added before they will charge or operate. They do not have a built in battery pack in most cases.
