Question about Acer Aspire 3100-1405 Notebook
Screen freaks out when i move it
I got my sisters laptop from school and she left it on and now the screen freaks out when i move it. its become very sensetive. how do i fix it?? P.S. its a acer aspire 3500
  • Acer Master
  • 12,061 Answers
Sounds to me as though the Cabling going through the casing from the screen to the main board may have been damaged somehow? This is a common problem I have seen quite a bit.. If it is this then to fix it is a bit of a mission.. ya have to get a new "Correct" Cable from ya PC parts supplier, then disassemble the Lappy, reinstall the new cable and reassemble the Lappy.. Otherwise it is off to the PC repair shop for a "Quote" on the repair and an explanation of what they found..
Posted on Aug 18, 2007
SOURCE:
Screen is orange and pink where it should be white
Try updating graphic drivers from the HP website.
HP has a lotta tools inside, maybe one lets you run an updater HP Pavilion dv6405us Notebook PC Drivers Download
Feb 28, 2014 | HP Pavilion DV6405US Laptop
Install oovoo
Changing the screen size on an Acer computer, whether it is a laptop computer or a desktop computer, is a simple task.
You can adjust the screen size to be larger or smaller.
If your eyes hurt from concentrating on tiny letters all the time, you should make the screen smaller.
If you have to scroll left and right to read sentences in a document on your computer, you should make the screen larger, at least to the point where you do not have to scroll left and right to view the entire window.
Go to the desktop of your computer and right-click the screen.
Click the last option, which is "Properties."
The "Display Properties" window will now show up.
Click the "Settings" tab in the "Display Properties."
Adjust the meter under "Screen Resolution."
When you move the meter to the left, the screen becomes smaller.
If you move the meter to the right, the screen becomes larger.
Click "Apply" to save the settings once you are finished adjusting the screen resolution.
http://www.marthas-web.com/display.htm
Jul 13, 2013 | Acer Aspire One PC Notebook
My laptop is suffering alot .the first problem is that when it shut down it restart again with out my knowledge and as aresult the battary run out of power . as time went i began to experince ayellow...
The Hp pavilion dv6 laptops overheat from my understanding and experience. My sister had one and the same thing has happened. I opened it up and did a reflow, which is pretty much fixing the connections. This is a very hard process. This laptop's gpu likes to over heat pretty much. You should either try to have a professional fix it or just back up your files and sell it.
Mar 01, 2011 | Heating & Cooling
I purchased the Toshiba A665-S6086 approx 1 month ago. The battery on the computer seems very loose. Should it have "give" in it or should it be more stable? Also, the sound vibrates when you...
- The battery should fit snuggly. Have that checked.
- As for the sound problem, most likely, you have the "Hard drive protection utility" installed and enabled.
When you move the laptop, the hard drive protection kicks in and the read/write heads go into park position freezing the laptop for a fracture of second. Apparenlty this causing the sound to statter.
You can disable the hard drive protection for a while and see if it fixes the problem.
Also, try reducing the movement detection sensetivity in the hard drive protection utility.
Dec 31, 2010 | Toshiba Satellite A665-S6086 Laptop
I need help fixing my sisters with my sisters laptop enter button
You're going to have to replace the keyboard... The Liquid has burned out the contact pad on the Enter button..
It could have as well ...reached the motherboard .. you should have it looked at, it will cause further damage.....
If Left On Motherboard... It Will Blow Capacitors And IC Chips, It eats away at the Solder...
Nov 28, 2009 | Samsung NC10-14GW Notebook
My hp pavillion dv2000 screen isnt working PLEASE HELP
when you power up press F8 key then enter in enable vga mode .
Tehn go to control panel and then dispaly property then change screen resolution to 1024*768
then apply and ok.
Jun 22, 2009 | HP Pavilion dv6000z Notebook
Eeek droped in school crack from bottom to top but it still works but is so ugly and way to fix?
my father had to this for my sister once on her ipod. what you'd have to do is gently pry each piece off one-by-one and then buy a new screen, and then glue the new screen on.
hope this helps and good luck ;-)
Apr 03, 2009 | Apple iPod touch
Acer Aspire 3000
dont panic, to get the operating system loaded, simply buy a cheap usb mouse and that should take over from the touchpad, i can't believe you were told to reinstall windows to solve a simple thing like that, uninstalling the touchpad in control panel in 'mice and pointing devices'; and restarting the notebook would have solved that one.
Aug 23, 2008 | Acer Aspire 3000 Notebook
My camera screen is broken!!!
How broken- more detail if it is cracked - use tape. If it no longer works- checkout a repair at Sumsung customer support the price will be more than half the cost of reeplacing the camera
Sep 13, 2007 | Samsung Digimax S500 Digital Camera
Acer Aspire 3100-1405 Notebook Logo
104 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
