FixYa.com
Tags:
Sharp Aquos LC-42D62U 42 in. HDTV LCD Television
Brightness control (by 9 users)
posted by yukismom on Aug 18, 2007
I bought a the Sharp Aquos 42 inch from Sears in March. I noticed that the brightness would flicker from dark to light (back and forth)during a night scene. It's bad enought that it makes me dizzy and when it's dark I can't see anything. Sears tried to repair the set but couldn't, and then replaced it with the same model. The second set is doing the same thing. I called Sharp and they sent me an authorized repairman. He took the TV into the shop and the next day I was informed that unfortunately that's how this model is and there is nothing they can do. I can't accept this form a $2,000 TV. They said that's from the brightnesss control which unfortunately can't be turned off. When I turn on the OPC feature the screeen just goes dark and dull. The technician from Sears and from Sharp agreed thet the picture was too dark and they both saw it flicker from dark to light and back to dark (over and over), yet they said that no one else has complained. I find this hard to believe. Is there anyone else out there with this problem? I know it's not just me--my family, friends, and 2 technicians saw the problem. If someone out there has a solution--great. Otherwise I have to start fighting with Sharp and Sears on Monday. I wish I bought a Samsung.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
8 Other Users Have The Same Problem
Comment by Guest, posted on Jul 28, 2008
i had the same problem but the technician did not accept it, and said it is normal. i regret why i didnot buy a sony X model.
Comment by Guest, posted on Jun 07, 2008
i'm having the saaame problem.  ridiculous. nauseating! i did the 'hack' but that's ridiculous that i'd have to jimmy my TV into working.
  • OPC = Off -> dims in and out.
  • OPC = On -> almost too dark to watch.
anger! rage!
i'm having the saaaame problem. it's retarded.  the 'hack works" but what a joke. i shouldn't have to jimmy this TV into working.
Comment by jc2007, posted on Dec 29, 2007
I bought a 42" but the 43u version and I'm having the same problem. It even flicker when changing channels.
I love the TV and I don't want to be forced to return it. Help.
Comment by mikegreenz, posted on Dec 17, 2007
I have the same issue - they said to disable the OPC function (menu- picture - OPC on/off) but i think i've tried that and it hasn't helped.
i get a headache trying to see low-light scenes.
Best Solution
posted on Nov 18, 2007
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Had the exact same issue.
How stupid is that?? darkening dark scene and brightening light ones, it probably makes contrast ratings go higher but the viewer can't see anything!
Anyway, the solution should be to put the av mode to "user". In this mode, opc is disabled by default, and it is actually enforced, whereas in other modes it is always on.
Rating Locked! (?) yukismom has rated this solution as FixYa!
Solution #2
posted on Dec 30, 2007
FixYa! (100)
Guest
Guest
Rating: 0%, 0 votes
Looked at page 37 of the operation manual. Think this feature is called "enhanced picture contrast". Depending on the AV mode selected, feature is on or off. Selecting movie, game, pc, user will turn this feature off. OPC looks at the light in your room. By the way, with opc on, my cable remote control won t let me change channels due to interferences!!! Weird....
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
posted on Jan 26, 2008
FixYa! (100)
Guest
Guest
Rating: 0%, 0 votes
SOLUTION:
just played around with it and figured it out:
Go to
>>>Menu
>>>Picture
- Select your Backlight settings (mines at 16, brightest) and turn OPC ON! I REPEAT, OPC ON.
next, go to
>>>Advanced (still under picture tab)
>>>Range of OPC
----Turn both tabs as far to the RIGHT (making it brighter) as you possibly can. This should fix everything!
j.fisher
Solution #4
posted on Oct 13, 2007
Helpful (85)
Guest
Guest
Rating: 0%, 0 votes
DO NOT BUY ANY SHARP TV
Solution #5
posted on Nov 20, 2007
Helpful (85)
les_l0n
Rating: 85%, 1 votes
i have a 46" aquos and i had this problem on the first day i called and everything! but everyone said just to return and exchange but im pretty sure i will ge the same result i played around and i turned OPC "on" and it stopped flickering and stays stable butttt its really dark during night scenes. i love this tv so even though the night scenes are garbage im keepin it!
Solution #6
posted on Sep 20, 2007
Helpful (85)
Guest
Guest
Rating: 0%, 0 votes
My Sharp LCD tv also has the same problems you are experiencing. A sharp technician was able to minimize the brightness problems (but not eliminate it) by accessing the service menu on the TV. As your local Sharp tech if he can do the same for you.
Solution #7
posted on Apr 19, 2008
Not Rated (0)
mishaisis
Rating: 0%, 0 votes
there in NO OPC Solution, No tech nor Sharp will be abel to do anything. Any one who bought Sharp TV, expect very poor service and no solution to OPC problems on any size SHARP. Face it folks Sharp sucks!!! SONY is the best bang for your buck.
Solution #8
posted on Jan 05, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
try going to the advanced menu and switch off the active contrast control. that should help alot
Solution #9
posted on Oct 29, 2007
Not Rated (0)
djerrard
Rating: 0%, 0 votes
I used to have the same brightness problem.  I have Bell Express Vu (Hi-Def) and would replay the same piece of recorded video to see if the issue always happened at the same spot.  It wouldn't.  It doesn't seem tied to the video source.
It seems I no longer have this problem as the screen now just goes to black.  The power is still on.  I get nothing from the other video source I have connected either.  I also tried to pull up the menu since it shouldn't require a video source at all.  Still nothing.  This problem is intermittent as well.  Sometimes it's only out for a few seconds, sometimes for minutes.
Can you Help with these Flat Panel Televisions problems?
Sharp Aquos LC-42D62U 42 in. HDTV LCD...
How do I get the volume to work...
How do I get the volume control... Answer This...
lc-32da5u
Hi, There is a problem with the... Answer This...
screen shuts off
i have an sharp lc-42d62u and... Answer This...
On Screen Display Menu
All of a sudden the tv is... Answer This...
my sharpe lcd tv 42 inch keeps ...
my lcd tb shows other pichers... Answer This...
8 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Dec 11, 2007
I have the exact same problem. Sharp 42" LCD 1080P 60MHZ, 4MS response. I just got my set and am giving it back!!!!!!!!!! pissed.
You can use me as a reference: cybersalim@gmail.com
Salim Janmohamed, Vancouver BC
Comment by Guest, posted on Nov 18, 2007
I bought Sharp Aquos 52 inch in Costco in September. Picture is great but night scenes are too dark and it is flickering up and down. I haven't complained yet, thinking it can be adjusted, but can't do anything. Any advice?
I bought Sharp Aquos 52" in Costco. Picture is great, but night scenes are too dark, sometimes completely black and the screen is flickering up and down. I haven't complained yet thinking it can be adjusted, but it seems I can't do anything. Any advice?
Repair Service
Find Flat Panel TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
