Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
USB i recently installed service pack 2 on my computer. As XP doesn't need any USB drivers i didn't install any. But the system refuses to open the USB drives directly & asks to install software for it.What would be the driver i need to install ???
  • Anonymous Sep 16, 2008
    i have the same problem, my pc doesn´t acept all the usb port, i don´t know why.
Hello sir
               my computer have usb-uart problem.please solve this problem.my email id sud_rao143@yahoo.com
Posted on Oct 19, 2008
  • 883 Answers
Checked my XP via control panel: usbhub.sys usbohci.sys usbport.sys usbui.sys good luck...may be difficult to force drivers...when system asks to install software, insert the original XP cd. The driver did not change with SP2, as far as I know.
Posted on Aug 18, 2007
  • Marty marty Sep 03, 2007
    was sp2 an upgrade or first time?
    do you still need help with this?
  • Marty marty Sep 13, 2007
    hello....you still there?...how was this NOT HELPFUL?
SOURCE:
My window xp2 is not installing window installer 3.1 help me
Windows Installer 3.1 Redistributable supports Windows 2000 with Service Pack 3 or later, Windows XP, Windows XP Service Pack 1, Windows XP Service Pack 2 and Windows Server 2003. Windows Server 2003 Service Pack 1 contains Windows Installer 3.1 and therefore can't be installed or upgraded by this redistributable.
Read the above, Windows Installer 3.1 already in in SP2. Why do you need to install it?
Jul 14, 2010 | Microsoft Windows XP Professional
Prob
what windows did you install (xp service pack 1 or service pack 2). becouse service pack 1 doesn't fully support all the usb port types.
Jun 16, 2009 | Intel D845GVSR Motherboard
How to install usb
After you install Microsoft Windows XP Service Pack 2 on a computer that is running Microsoft Windows XP, the universal serial bus (USB) drivers do not appear to update. CAUSE After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers... loadTOCNode(1, 'cause'); After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers appear with the earlier version numbers, even though the files have been updated. uparrow.gifBack to the top RESOLUTION To resolve this problem, install Windows XP SP2, and then update the drivers for... loadTOCNode(1, 'resolution'); To resolve this problem, install Windows XP SP2, and then update the drivers for the USB devices that are connected to your computer. To update these drivers, follow these steps:
  1. Click Start, click Run, type devmgmt.msc, and then click OK.
  2. Double-click the type of device that you want to update.
  3. Double-click the specific device that you want to update.
  4. Click the Driver tab, and then click Update Driver.
  5. Follow the instructions in the Hardware Update Wizard.
  6. Repeat steps 2 through 5 for each USB device.
Note You can also install Windows XP SP2, and then disconnect and reconnect the USB devices that are connected to your computer. By doing this, you start the Plug and Play utility. The Plug and Play utility updates the version numbers for the drivers.
May 08, 2009 | Microsoft Windows XP Home Edition
I have problem with reading my PQI 1GB Mini I-Stick i810 2.0 USB Flash Drive.Computer doesn?t read it at all. Can?t recognise a new drive. Please help
If you are using Windows XP, please check if you have install service pack 2 or later,
or check if proper driver is installed..
Mar 26, 2009 | Computers & Internet
Usb port not functioning
Windows XP is not compatible with USB 2.0 ports. Could you confirm you have Service pack 2 or 3 installed. If not, you should install SP2, so they should work.
Jan 12, 2009 | Toshiba Satellite A100-S8111TD Notebook
Need help downloading and installing driver for hp photosmart C3100 printer said required section usbstor.inf not found xpsp3
Search your computer for the USB inf file usbstor.inf. Is this the first USB device you have ever used? What is the operating system on your computer? It appears as though it is searching for the Microsoft Service Pack 3 for XP, and can't find the file within the service pack, or the service pack. Have you recently installed MS updates?
Nov 19, 2008 | HP Office Equipment & Supplies
PNY USB 2.0 Flash Drive not recognized by my computer (operating software installation not recommended as it's not "digitally signed" by Windows for use in XP, although the Flesh cover states...
just go to system properties in control panel and in that hardware tab select device manager see any question mark or exclamation mark in yellow colour appear when u connect u r USB 2.0 flash drive if it appears then u should install driver for that or else
on windows xp what service pack r u running just check it i.e,
Right click on my computer go to properties if it is Service pack 2
then problem will not come if it comes just install drivers or else
if it is Service Pack 1 then upgrade to Service Pack 2
u can find Service Packs in Microsoft.com in downloads
Jul 31, 2008 | Computers & Internet
Frequent Computer Crash
I think that you are mistaken something, I could'n find pvm900 at viaarena, no results at all.
If you use SP2 upgrade pack...well don't, some old peripherials refuse to work with the upgrade pack, instead install from full OEM cd or stick to SP1, I have some customers that still work with win98 and xp SP1 very well.
Try this: first update your DirectX software from microsoft, link: http://www.microsoft.com/downloads/details.aspx?FamilyId=2DA43D38-DB71-4C1B-BC6A-9B6652CD92A3&displaylang=en
Hope you are a genuine windows user because you need to be to get it, download and install.
If it did not solve the problem...enter windows in "safe mode" (F8 while loading computer), press "yes" to the question asked,
start-->control panel-->system-->hardware-->device manager-->open the + at the "display adapters" right click over the display and choose uninstall, do the same at "sound,video and mult..."
log off while shutting down the computer, turn on, windows will prompt for the device driver (once for display and once for sound), point to place where the display or sound card drivers are, if there are not recognized as valid drivers, maybe they are not compatible with OS, search for compatible soft at driverguide.com
May 05, 2008 | Computers & Internet
Usb 2.0
this is a common error with operating systems and devices.
If you go into my Computer/system/device manager. And remove the installed USB devices. shutdown the computer, and reboot it. then try putting your USB device in.
What general happens, is that if you have had an older device in the USB port at any time, the port configures itself to this setting. options are to try another port on the computer ( some older ports only support usb1.1 )
ensure you have up to date drivers on the connecting device and on the connecting computer.
Hope this helps Mike @ Compurepair.
Feb 22, 2008 | ASUS M2A-VM (0610839149438) Motherboard
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
202 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
