Question about RCA F27665 27" TV
Have sound and OSD but no picture
On my RCA F27665 I have sound, but I get no picture from the cable channels. The OSD which is used to setup and configure the TV, does display. Using component cable or S-Video I cannot get a picture from my DVD player either. Eventually the OSD displays an "unusable signal" message after trying to toggle the input to view a DVD.
    Novelist:
    Champion:
  • 236 Answers
You may have a problem with the video switching IC. Stargazer
Posted on Aug 29, 2007
Sound but no picture How do I fixx it
If you are using RCA cables be sure that the colored cables go with the corresponding input plugs, after checking the cabling try powering off then powering on your unit. Some units require a quick channel search and setup, which is usually found under the menu option.
I’m happy to help further over the phone at https://www.6ya.com/expert/darnell_06979bec4e109662
Dec 30, 2014 | Proscan Televison & Video
Harman kardon avr 245
See what connectors you have on TV, easiest way to connect is using RCA or composite. About the sound, connect a surround system to the receiver.
Sep 03, 2008 | Audio Players & Recorders
TV Flashing from Channel to Channel Non-Stop. Problem with the RCA F32689 32" TV My TV started jumping from channel to channel non-stop. There's no picture or sound - only channel numbers changing...
If still under guarantee take it back.
If not this sounds like a workshop job. If more than five years old (the TV, not you!) and you can afford it, junk this set and get a new one.
Sep 21, 2011 | RCA F32689 32" TV
How do u add and delete channels on a rca 24F512T
1) Make sure that the current input is TV. Then press Menu on either the TV or the remote.
2) Press Ch+ or Ch- to highligh Setup then press OK.
3) Press Vol+/Vol- to highlight TV or CATV as needed for the channels you wish to add or erase.
4) Then use Ch+/Ch- to highlight Channel and then press Vol+/Vol- to enter the channel number that you want to add.
5) Press Ch+/Ch- repeatedly to highlight Add/Erase then use Vol+/Vol- to select whether to add or erase the channel selected above (step 4).
6) Press Menu repeatedly to exit the OSD (or wait until the OSD closes after a period with no key presses).
Then use the Ch+/Ch- buttons to scroll through the channels in memory to see the change.
The manual for your 24F512T is available here: http://support.ttetech.com/RCATV/Assets/pdfs/24F512T_1641309F_IB_e-06.pdf . See page 13 of the manual for extra information on manual tuning and page 15 to add and remove channels from the channel list.
I hope this helps.
Mar 27, 2011 | RCA 24F512T 24" TV
Cant get any station other than chanel 3.It wont outo program and says there is no signal but channel 3 comes in.
Its likely the t/v has been programed to work with a cable
box , you can go to menu and settings and try to reset
it , or unplug it for a half hour or more and reset up the t/v
to scan channels.
Sep 02, 2010 | RCA F27665 27" TV
There's pictures on my tv but doesn't have sounds...
FIRST CHECK SPEAKERS OR SPEAKER CHANNELS, ,AUDIO OUT PUT DRIED JOINTS . .REPLACE AUDIO OUT PUT AMP.
Nov 06, 2009 | RCA F27665 27" TV
Instruction manual for RCA F27665
here is the link for the User Manual for the RCA F27655 Entertainment Series PIP
http://support.radioshack.com/support_video/54161.htm
Jan 13, 2009 | RCA F27665 27" TV
RCA P46924 64" Rear Projection TV
disconnect the wii it will eventually ruin your tv game systems can't be used on rear projection because of problems caused you may need to hook everything up at the bottom of the panel and switch back and forth using your remote we had to do that on ours
Oct 22, 2008 | RCA P46924 46" Rear Projection Television
New setup
do you get anything on screen, like the menu or channel number?
Feb 05, 2008 | RCA L42WD250 42 in. LCD HDTV
No display
Press the DVD button on the Philips remote. Make sure the yellow part of the RCA cable is plugged into Output/CVBS/Out on the back of the Philips, and that it is plugged into a yellow input of your TV. Change your TV channel to Av1, av2, video 1, video 2, aux, aux 2, or whatever the correct video channel is on your TV. Then press setup - you will get your picture.
In order for the coax connection to work on Ch. 3 of your TV, you will have to get an additional piece of equipment - an RF modulator. It's better just to stick with the RCA red, yellow, white cables.
Sep 02, 2007 | Philips DVDR3455H/37B
RCA F27665 27" TV Logo
347 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
