Question about Brother MFC 420CN All-In-One InkJet Printer
No dial tone
I just set up the machine and can't seem to get a dial tone. The line is working and get normal dial tone when I connect it to a phone. I have no splitters or connectors between the wall jack and the machine/phone. Any thoughts?
  • Pete2007 Aug 24, 2007
    Was connected to the wrong port - thanks!
  • Anonymous Apr 20, 2008
    brother MFC-885cw. Fax working fine but no dial tone in headset.
    It turned out that the phone line was pliged to EXT. I pluged it to LINE and the problem solved!
  • 78 Answers
Do you ahve the Cable connected to the LINE socket and NOT the EXT Socket? M
Posted on Aug 21, 2007
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
Bell Studio 4500 DECT phone with answering machine: just out of warranty, this phone does everything properly up to entering a number, then dialling, BUT not producing a ringing-tone or getting through to...
I gather you have the setting for tone and pulse set to tone? Also are you aware the ringing tone is generated by the phone company? When you dial a number and it connects, the phone provider sends the ring signal to the dial phone and the ringing signal to the dialing phone. Do you get a dial tone before dialing?
Jul 26, 2017 | Lands Phones
We are having problems receiving faxes but printing is fine we do not seem to have a ringtone signal
First make sure dial tone form wall is working, just plug in a hand set. If no dial tone, call phone company. If dial tone then make sure line is plugged from wall into fax port that says Line not TEL. Can you send faxes ok?
Apr 04, 2011 | Brother Office Equipment & Supplies
No dial tone on phone connected to ext port on epson dx9400f
Buy a double adapter so both cords go to the LINE port. Set your answering machine to 6 or 7 rings so the fax picks up first. Your fax machine will know the difference between voice and fax calls,
Jun 22, 2010 | Pitney Bowes 9920 Plain Paper Fax
Modem problem
Disconnect the phone line from the modem and connect a normal phone to this phone line. Lift the handset and check it you have a dial tone and see if you can dial out.
If you don't get a dial tone then there is a fault with the phone line and it needs to be repaired before you can use your modem.
Apr 14, 2009 | Dell Latitude C640 Notebook
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
Panasonic KX-FM220 fax machine does not have a dial tone
is your line provider ok.connect your line to ordinary phone to check if there is really a dial tone from the line provider.if there is a dial tone please let the analog board be cheked by a technician near you
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
Fax function doesn't work
check your phone lines.then connect it to the machine.press on hook dial.if dial tone is not there you may need a service engineer.
Apr 05, 2007 | Ricoh Aficio 2018D All-In-One Laser...
Incoming telephone calls
Refer to your manual. It may be under RX(recieve settings). Go disable FAX/Tel SW and make sure it is fax mode only
Jan 11, 2007 | Canon FAX-B820 Plain Paper Bubblejet
Brother MFC 420CN All-In-One InkJet Printer Logo
162 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
