Question about Sony (DWQ30AB2) DVD RW Dual Layer Burner
Problem is with iTunes
As of two days ago, iTunes stopped working. The program said it needed Quick Time and could nto find it. I reloaded both iTunes and Quick Time, and ever since, it won't work at all. Whenever I try, I get the following message: "iTunes.exe has generated errors and will be closed by Windows. You will need to restart the program. An error log is being created." I looked around and found that it might be the firewall, so I closed the firewall. Nothing. It was recommended to check the settings in the firewall, and I did, and there are no restrictions at all. The iTunes version is 7.3.2.6. I do not know how to make this thing work.
  • christophera Aug 18, 2007
    I didn't put it under DVD, that problem is over, I changed burners. Everytime I went to the FixYa site, though, it took me back to that page, so I used it. I'll try what you suggest here and see what happens.
    Scholar:
  • 85 Answers
Hi try this: The intention is to remove all iTunes and Quicktime software references. The following steps remove the software traces and worked on my machine. 1. Using add/remove programs uninstall Quicktime (click on Start ?> Settings ?> Control Panel ?> Add/Remove Programs) 2. Using add/remove programs uninstall iTunes 3. Right click on My Computer, use Search and remove all programs named Quicktime 4. Right click on My Computer, use Search and remove all programs named iTunes (except your iTunes download, so you won?t have to sit through another long download session). 5. Left click on Start, click Run, type ?regedit?, go to HKEY_LOCAL_MACHINE, click on SOFTWARE, and remove the Apple Programs folder (you may want to check in case you have other Apple applications, but all I had were iTunes and Quicktime in my Apple folder). Steps 1 through 5 should remove all traces of the software and now you can install iTunes. make sure you install all the latest updates from apple hope this will work for you :)
Posted on Aug 19, 2007
The top quick access buttons stopped working 2 days ago. The bottom buttons still work but, we can't punch in a custom time. The only thing that will work is the 1 for 1 minute 2 for 2 minute...etc.
One of two things is happening, either you have broken connections in the membrane switches of the keypad and should replace the keypad(which is most likely) or your main control board has failed in a way that it can no longer read signals sent by the keypad.
Aug 04, 2013 | Microwave Ovens
EVERY TIME I TRY TO UPDATE ITUNES OR UNINSTALL OR REINSTALL I GET THE SAME MESSAGE. IT'S LOOKING A FILE ''WINDOW/SYSTEM32MSIEXEC.'' ALSO ''OLD VERISION OF QUICK TIME CAN NOT BE REMOVED. CONTACT YOUR...
Go to the "Control Panel" of your computer, then "Add/remove programs". Look for quicktime and uninstall it from there. Then reinstall quicktime again.
May 31, 2010 | Apple iPod nano
When trying to open itunes from desktop the following error message is recvd: "Quick Time failed to initialize (error-2096) Quick Time is required to run iTunes. Please uninstall then re-install iTunes"...
Go to...
My Computer
C:\
Program Files
Quicktime
On Quicktime.exe
right click and select propities
Un- select read-only.
Click OK
Go back into Program Files
Go to iTunes Folder
Go to iTunes.exe
Select properties
Go on the compatability tab and de-select all.
Dec 31, 2009 | Dell Inspiron 1720 Notebook
Error 2330 running quick time and ituens
The above Error refers to corrupt file.Are you sure you have properly uninstall it?
Go to My computer>Drive C > Program Files
There would be a folder for itunes. Delete that. Restart the computer and then try to install the itunes.
Let me know the update!!!
Thanks.
Jul 02, 2009 | Apple iTunes
My P5PE-VM sound card suddenly stopped working.
if you cannot reinstall it or it is installed correctly that means that your sound card is in fact broken =(. you will need to replace it. soundcards are generally inexpensive depending on what you will be using it for.
Jun 05, 2009 | ASUS P5PE-VM Motherboard
Headlights will not turn off
have you replace the switch. you may need to check the censers.for day time runner light. be sure to check the fuses . have a nice day
Apr 10, 2009 | 1998 Ford Explorer
My itunes screen has frozen!! HELP!!!
The same thing happned with me and i clicked on Help and Support on my computer, typed "force quit" and many solutions came up...one of them was "Exit a program that is not responding" and that's the one i clicked. It suggested i go to Task Manager, so i did, and then on Task Manager i clicked on the Applications tab, found iTunes, clicked it, and then clicked "end task" at the bottom right corner of the page. (you can also go directly to Task Manager)
Oct 31, 2008 | Apple iTunes
Accidentally deleted quick time and now Itunes will not work without it. how do i get quick time back
Okay. So, Windows can still find it, but it is not there. There is a part of the program that is still installed. Go to the Control Panel and see if there is an icon of Quick Time there.
Aug 25, 2008 | Computers & Internet
ITunes and Quick Time will not load and work together
well you have to re-install your windows on your pc...
or try re-installing the software of QUICK TIME 6.0.
it's the best i have used...
reply soon..
Dec 01, 2007 | HP Pavillion a818n Desktop PC (Refurb)...
update your anti-virus program, it's quite apparent that your system has been infected with a trojan.
Aug 18, 2007 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
Sony (DWQ30AB2) DVD RW Dual Layer Burner Logo
293 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
