Question about Sony PlayStation Portable (PSP) Console
Internet connection error
Can not connect to internet through linksys wireless hub
  • 14 more comments
  • Anonymous Nov 10, 2007
    I have the wireless vodafone 3g broadband. When connected into the usb port it says no ethernet cable inserted..Wat does this mean
  • lateshia Nov 29, 2007
    i was going by the network setting infrastructure mode i just don't know how to put the net work help
  • Dieter King
    Dieter King Nov 30, 2007
    i had a good connection yesterday but today i'm getting the error code 80410415. Any ideas why?
  • dominic james Nov 30, 2007
    how do you get on to search the internet when you are all ready on
    how do you get on internet
  • hopeton Dec 15, 2007
    i have problems with sharing games and doenkoading wallpapers
  • aukase Jan 03, 2008
    wireless internet won't connect...says DNAS error has accured.
  • doony01 Feb 19, 2008
    if i try to connect to internet my psp sats internal connection error and gives a code. so whats the problem plz
  • candycool Mar 09, 2008
    i am geting internet problem when i scan i get only 20% of internet found
  • Anonymous May 18, 2008
    i click scan,and was able to use internet before ,but now wen i click it it says "connection to acsess point was not found.''wat do i do?
  • anwarz Jun 01, 2008
    im havn problems getn on the internet usin my psp went to network setting and did what it told me to do and when i tested the connection there was an error message. what am i doing wrong????????????????please help.
  • Anonymous Jun 02, 2008
    when i go on the network settings and do everything its all right till then. but afterwards when i check the connection,it doesnt connect
  • Anonymous Jul 16, 2008
    my psp says that the communication with th server faild a dns errorr has occurred ? what does that mean
  • FeannaAon Jul 23, 2008
    Okay I set up my network connection properly through the PSP, making sure the SSID and the WEP key and everything match just perfectly. And then I run a test of the connection and it finds the network pretty well, around a 50 or 60% signal. But at the end of the test, it says that the internet connection has failed. Any ideas of what may be wrong? Could it be the router instead of my PSP with the problem?
  • Anonymous Dec 25, 2008
    the access point
  • Anonymous Dec 28, 2008
    the settings are all right, every thing is fine, but at the end of the connection, it says it timed out and the router is open!
It say it says it right underneath were it reads were it reads select an access point to be used. and underneath were it says security
Posted on Jan 16, 2012
How do u get a internet on ur psp
Posted on Sep 21, 2008
  • looneyemf Jan 16, 2012
    My psp is saying not supported .why is it saying that?
When i scan my psp for a network it shows me 'AN internal error has occurred (00000001)'
Posted on Apr 08, 2008
**** a ****!!!!!!!!!!!!!!!!!! lol...
Posted on Mar 19, 2008
Is it possible if you connect usb from psp to pc using the enternet?
Posted on Dec 16, 2007
    Problem Solver:
  • 5 Answers
Simple steps: 1. Push "up" the WLAN switch by the left side on your PSP 2. Go to "Internet Browser" 3. Go to "Address" 4 Type in your web address and pres "start" 5 When prompted with internet connection settings, choose new connection and Scan for Wireless access points. 7 Choose connection with no security and good signal strength, save your settings (Press "=>" all the way). 8. Select your newly made connection and there you go!
Posted on Aug 24, 2007
SOURCE:
I am connected from the service provider to a linksys hub and then I connected a cable to the wireless router Dlink -601. I do have internet wireless in the house but I CANNOT connect myself to the hub by...
Improve the Fixya.com experience for everyone by voting!
The solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
Let's see if I can help you.
Begin by turning on your computer and your router
? Open Internet Explorer;
? Click on 'Tools';
? Click on 'Internet Options';
? Click on 'Connections';
? Click on 'Setup'
? Click on 'I want to set up my Internet connections manually . . .';
? Click on 'Next';
? Click on 'I connect through a local area network (LAN);
? Clock on 'Next'
? Click on 'Next' [This is not an error];
? Click on 'No';
? Click on 'Next';
? Click on 'To connect to the Internet immediately . . .; and,
? Click on 'Finish'.
That should have you online
All the best
Ben
May 29, 2011 | D-Link DIR-600 Router
I want to add a LINKSYS workgroup switch EZXS55W behind my wireless routher LINKSYS BEFW11S4 v2 via uplink cable connection. When hardwiring my anything to the switch port 1-4 does not get internet access
Are those 4 ports in different Vlan ?
If you connect your wireless access point to the 1st port are you able to access the internet through 2nd port or 3rd port ?
Are the ports 1-4 admin down ?
Dec 23, 2010 | Linksys Bundle: BEFW11S4 802.11b Wireless...
I have a netgear ds116 hub and i want to set up a linksys router
Here's what you can do. Don't connect the Linksys router yet to the hub. Connect 1 computer directly to the Linksys router. Access the router's setup page of the Linksys router thru http://192.168.1.1
It will prompt you for username and password. No username and password is admin.
Look for Local IP Address or LAN IP Address. Change the LAN or Local IP Address of the Linksys router to 192.168.5.1 then click on Save Settings at the bottom. Right after saving the settings, unplug the power of the Linksys router, connect it to the hub and it should be good to go.
Oct 06, 2009 | Linksys Wireless-G WRT54GS Router...
No internet linksys connected to catalyst 2900 XL
check the vlan settings of the port on the switch to where the AP is connected, and check the vlan of the AP
Sep 13, 2009 | Cisco Catalyst 2908 (WS-C2908-XL)...
How do I connect a LInksys NH1005 hub to a wireless router? Do I have to connect directly to the dsl modem first? change the ip address and then connect the router?
If you have a port in the back of the wireless router open which you should just run a CAT 5 (network cable) from the back of it to the Linksys hub. That should do it. This way the wireless router won't have to be messed with and you shouldn't have to change a thing.
Feb 28, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
Can get ip address from PPoE Linksys Wireless-G WRT54G Router
If you receive that error message from the status page of the Linksys router, it only mean one thing the router shouldn't be set to PPPoE , the internet connection type of the router should be set to Automatic configuration/DHCP then do a power cycle on your modem and router...
Oct 25, 2008 | Computers & Internet
Internet connection-Linksys Wireless B
Did you move the router out of range of the computer? It sounds like you put it back where it was but I just thought I'd ask.
Otherwise, use your wired connection to check the router settings. It is possible that the wireless settings defaulted due to the disconnection. You can either set the router to match your wireless computer if you can remember, or just set up a fresh wireless connection between the two.
Sep 06, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
Internet connection
Connect a computer to one of the lan ports 1-4.
Connect the adsl modem to "internet" or "wan" port of hub.
Open the hub's configuration page in your browser, usually this is http://192.168.1.1 Under Setup->Basic Setup, set the configuration for "Internet Connection Type " to "Automatic Configuration - DHCP". Under Network Setup, enable the hub's internal DHCP server so your lan hosts can get their ip's from the hub. Each local computer should have DHCP enabled. Your adsl modem must support DHCP for this to work, some do not. If it still doesnt work, try setting "PPPoE" instead of DHCP.
May 14, 2008 | Linksys Wireless-G WRT54GL Router
Password settings
i'm not sure about the network connection u have. As I understand the wireless router is connected to the linksys Hub and computers getting wireles connection from wireless router.
Here nothing we can do on the hub for secured wireless connection.
Please folllow he instructions below:
- If you want to configure the wireless router for secured wireless
please check this link, so you can get some idea.
http://www.portforward.com/english/routers/wireless/routerindex.htm
In this above link, you can check whether your wireless router model is available. If it is, click on it, then you can see step by step wireless configuration about your router with screenshots.
If you don't find any model , please mention your wireless router model, so I can help on that.
please feel free to ask, if you need more help on this.
-Laxman
Nov 27, 2007 | Linksys (NH1005) 5x10/100 Mbps Networking...
Sony PlayStation Portable (PSP) Console Logo
286 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
