Question about Epson Stylus Photo R320 InkJet Printer
Epson r320 printer will not read any memory cards
I won an Epson r320 Printer and fron the day we bought it has never been able to read any type of memory card. Can someone tell me why this is happening?
  • Epson Master
  • 705 Answers
Does the green light come on when you insert a card? Most likely that if it can not read the cards, and it is just not your PC failing to communicate with the card reader, then the mainboard is probably faulty. If it's in warranty get Epson to replace it. If not, you could see if you can source another R320 from eBay, (or similar) that has a different problem and swap the mainboards. You would also need the service utility to do this as you MUST change the print head ID on the new mainboard. Another alternative is to simply buy a cheap card reader and plug it into the USB input port on the printer. If the mainboard is faulty, this may not work though. Still you could then just plug the reader into your PC instead.
Posted on Sep 16, 2007
6ya staff
SOURCE:
Printingfrom Kodak memory card
The card may be too big or unsupported format for the card reader, thansfer your files to another card which works on the printer and print your pictures.
Jun 27, 2008 | Epson TM-T88III Thermal Printer
R320 PRINTER CANNOT CLEAN HEAD
manualy clean it using cotton and alcohol
Nov 27, 2008 | Epson Stylus Photo R320 InkJet Printer
Why am I having trouble with my Epson Stylus Photo Printer R320 reading the new SD card that I recently purchased. Printer says that card cannot be used with this printer. ?? Is my printer now obsolete?...
At the time your printer was manufactured, it incorporates/uses what technology is available.
Things to consider, memory cards now comes in different capacity and speed. Your printer's memory card reader can't read cards that uses newer technology.
You can however use your computer's card reader if there is one or purchase a USB memory card reader to download the photos and print them from the computer.
This actually how I print photos since I can do a lot more before sending it to the printer. I use Picasa (free) for quick photo fix and effects.
Nov 10, 2008 | Office Equipment & Supplies
I just bought a Dane-Elec 8 GB SDHC memory stick. Put it in a Belkin card reader [a few years old but the stick fit in] but kept saying not responding My program is XP I tried to put in my Epson Photo...
SDHC cards are secure digital cards, and may not be supported by some hardware. Please check your manual for the card reader and printer. If the card reader is a few years old it may not support it. The printer on the other hand could be a limit on card size. I have seen a lot of equipment that only supports up-to 2GB cards.
Jul 10, 2008 | Computers & Internet
EPSON RX600 PRINTER
Below is a chart of memory card capacities that have been tested by Epson. Testing was done before the products were released.
Please use this chart as a general guide line.
MEMORY CARD TYPE MAXIMUM CAPACITY TESTED
Compact Flash 4 GB
Secure Digital 1 GB
Sony Memory Stick 1 GB
MagicGate Memory Stick 128 MB
xD Picture Card 512 MB
Smart Media 128 MB
Any size of card other than that which is indicated above may work, but is not supported or guaranteed.
sorry for this one :(
Apr 18, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Only prints 4x6
Check the printers console settings for correct page type and size.
Mar 27, 2008 | Epson Stylus Photo R320 InkJet Printer
Micro SD card
Open your computer scan w/ anti virus that SD card /try insert again to your printer .
Jan 05, 2008 | Epson Stylus Photo® RX620 InkJet Printer
Compactflash memory cards
If it will not read ANY type of flash media it would suggest the reader or main board is faulty.
If it reads some type but not others, look down into the card slots with a torch and check to see if any of the pins are bent over. This is a common fault most notably encountered when the machine fails to read CF type cards. You will see two rows of pins in the slot. Chances are one of the pins is bent or been pushed inwards. If you are REALLY steady with your hands you can use a very small (jewelers) screwdriver to straighten the pin. If the pin has receded, it almost impossible to fix it.
Aug 18, 2007 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R320 InkJet Printer Logo
113 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
