Question about Epson Stylus Photo R320 InkJet Printer
Compactflash memory cards
My epson r320 will not read any memory cards. Why?
  • Epson Master
  • 705 Answers
If it will not read ANY type of flash media it would suggest the reader or main board is faulty.
If it reads some type but not others, look down into the card slots with a torch and check to see if any of the pins are bent over. This is a common fault most notably encountered when the machine fails to read CF type cards. You will see two rows of pins in the slot. Chances are one of the pins is bent or been pushed inwards. If you are REALLY steady with your hands you can use a very small (jewelers) screwdriver to straighten the pin. If the pin has receded, it almost impossible to fix it.
Posted on Oct 10, 2007
It wont read the cards
A: Make sure you're using a supported memory card. See the table below for specifications:
Memory Card Type Maximum Capacity CompactFlash Card
(Type I and Type II--3.3V only) 8GB Microdrive (3.3V only) 4GB SD (Secure Digital) 2GB MultiMediaCard 1GB
If you connect a compatible CompactFlash (CF) adapter that can read 8GB memory cards, you can also use the memory cards listed below (with a capacity up to 8GB):
  • Memory Stick
  • Memory Stick Duo
  • Memory Stick PRO
  • Memory Stick PRO Duo
  • xD-Picture Card
  • SmartMedia Card (3.3V only)
Mar 26, 2014 | Epson PictureMate Photo Printer
When i insert sd card it comes up on screen difficulty in reading card nothing wrong with card works ok with my epson
Here's the list of memory cards that works with the Lexmark P915 printer:
CompactFlash I & II
SmartMedia Card
Sony Memory Stick, Memory Stick PRO
Secure Digital (SD) Card
MultiMediaCard (MMC)
Microdrive
4 Built-in Card Readers
xD Card
Sony Memory Stick Duo (with adapter)
May 12, 2011 | Lexmark P915 InkJet Photo Printer
I do not know where to put the memory card into epson rx 425
There is a little panel on the front left, you can download the user guide fro Epson here:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=nKGrQtfEm6mIr17BBoUTdZr5V9BVmX64&tc=5#10
Loadable memory card
This product features three memory card slots.
The types of memory cards loadable for each slot are shown below.
Slot
Card
a
Memory Stick/MagicGate Memory Stick/Memory Stick Duo*/
Memory Stick PRO/Memory Stick PRO Duo*/SD Card/miniSD Card*/MultiMediaCard
b
SmartMedia/xD-Picture Card
c
CompactFlash/Microdrive
r_space.gif * An adapter is required.
Mar 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Memory card.
Supported Flash Memory Cards: CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo
Your phones card is a RS-MMC type not combatable, wont fit, no eject on printer, card too small for slot, wrong type
Power off carefull tweezer hunt or bluetac on a match, happy hunting
Oct 19, 2007 | Office Equipment & Supplies
Epson r320 printer will not read any memory cards
Does the green light come on when you insert a card? Most likely that if it can not read the cards, and it is just not your PC failing to communicate with the card reader, then the mainboard is probably faulty. If it's in warranty get Epson to replace it. If not, you could see if you can source another R320 from eBay, (or similar) that has a different problem and swap the mainboards. You would also need the service utility to do this as you MUST change the print head ID on the new mainboard. Another alternative is to simply buy a cheap card reader and plug it into the USB input port on the printer. If the mainboard is faulty, this may not work though. Still you could then just plug the reader into your PC instead.
Aug 18, 2007 | Epson Stylus Photo R320 InkJet Printer
Formatting CompactFlash storage card
Make sure you're using an ATA-compatible CompactFlash memory card. Other cards may not work with PhotoPC 850Z.
Sep 13, 2005 | Epson PhotoPC 850Z Digital Camera
Make sure you're using an ATA-compatible CompactFlash memory card. Other cards may not work with PhotoPC 650.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
What else can I do with CompactFlash
You can copy images to a CompactFlash card from the camera's internal memory or copy images from the CompactFlash card to the camera's memory. Also, if you have a PCMCIA adapter and a computer with a Type II PCMCIA slot, you can access images stored on a CompactFlash card directly from your computer.
Sep 13, 2005 | Epson PhotoPC 600 Digital Camera
Make sure you're using an ATA-compatible Type-I CompactFlash memory card. Make sure you've installed the card correctly. The card's label should be facing the front of the camera, and the arrow(s) on the label should point in.
Sep 12, 2005 | Epson PhotoPC 3100Z Digital Camera
Sep 12, 2005 | Epson PhotoPC 3000Z Digital Camera
Epson Stylus Photo R320 InkJet Printer Logo
683 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
