Kenmore 96212 / 96214 / 96219 Electric Kitchen Range Logo
Posted on Aug 18, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oven burners can turn oven on to preheat oven. can hit cancel button which will turn off the display back to the clock and no lights are on, but the heating element will not turn off.
Anonymous
Level 2:
  • Expert 126 Answers
  • Posted on Dec 13, 2007
Anonymous
Expert
Level 2:
Answers
126
Questions
0
Helped
54469
Points
195
Bad electronic board
3answers
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
GE Model J S968S0F4SS. During bake display goes bake, oven turns off.
Oven Does Not Heat, But The Burners Heat - GE Appliances
products.geappliances.com/appliance/gea-support-search-content?...
Range - Oven Does Not Heat, But The Burners Heat. To minimize the ... Turn yourrange OFF and either remove the fuses or turn the breaker OFF. Then unplug ...
How To Fix Oven With Little or No Heat When Baking ...
Troubleshooting Why Your Oven Won't Heat ' PartSelect ...
? 2:54
https://www.youtube.com/watch?v=ketJHf3rrSk
Sep 14, 2011 - Uploaded by PartSelect
In this video you'll learn why your oven may not be heatingproperly. ... Neither the bake or broil elements ..
Thermador oven preheat light will come back on during cooking session. The clock has also stopped working.
There may be a fault with the control board.
http://appliancejunk.com/forums/index.php?action=dlattach;topic=9146.0;attach=5091
My power went off today and when it came back on, my Kenmore oven shows error code "PF 5 AB". None of the buttons work that I press. Burners turn on, but can't turn on oven. Suggestions?
Could that be PF power failure 5AB in the Sabbath mode. That's a new one.
Your model number is useless. Sears has a big 3 digit product code followed by 8 digits.
But let me dig up my 5AB notes:
Here is what I have:
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
Hope this helps
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
My Maytag oven was shut off when a breaker was tripped. We turned everything back on however the clock says " 5ab" and none of the buttons work to reset the clock. Without this function, we can't...
That is the sabbath feature, to get it or defeat it:
ARROW pad.
"3".
shut-off.
Thanks for using Fixya, let me know.
I wanted to change the time hour. I pushed clock and up arrow at a time and the clock is showing 5 AB. The screen is frozen. I can't use any options. How could I get it back to normal? Thank you for your...
To
ARROW pad.
"3".
shut-off.
Other Displays:
stay on USE.
2helpful
Clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
1helpful
2answers
Whirlpool gs475lems range oven problems
my oven was converted to LP gas we move overseas.It worked for about a year then all of a sudden the oven stopped working. The burners work perfectly but the oven just keeps clicking after preheat is finished. We replaced the upper electronics board so what could it be now
Oven display won't work
rmedrano, Try pressing and holding the stop-time and cancel pads together for 5 seconds, see if it comes back to life. If not, try the cancel and clock keypads together for 3 seconds. First is the control lock-out funtion and the second is the display blank mode. If these fail to work, you are going to have to test for power at the board. The clock (ERC) has a 3 year warranty incase you have to call for service. Catriver.post back.
Top Kenmore Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
