Question about Philips 60P8342 60" Rear Projection Television
Convergence Hi. I'm a tv technician, and I need instructions on how to converge the color thru the service menu. Thank you.
  • 2 more comments
  • denis11 May 28, 2008
    hi guys my red line up and down is about 3 inches from the centre and is all waiey how do i fix that i tried ditial set up and can only move the side to side line help please
    denis
    sorry i have a zenith lqc60h95w
    i have read all of tv teck but do not know how to get into service mode
  • nonnienume Sep 18, 2008
    i need help with my tv convergence color
Guru is very good. No doubts about it.
Posted on Dec 16, 2007
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
Touch-up Convergence adjustments Enter the Digital Convergence Mode (DCM) by entering 0-6-2-5-9-7-(Status or Index) on the Remote control. The following menu will appear: Select an active channel or Aux Input. A signal must be applied to the set when performing convergence. If any Customer Adjustments need to be made, the Menu button can be used to toggle between the Customer Menu and DCM. The MPOSD ADJUST is used to center the Customer Convergence grid. A highlighted cross will appear along with the Convergence alignment grid. The highlighted cross should be centered onto the center of the Convergence grid. To perform a Touch Up Convergence, highlight SELECTION and press the right cursor button on the remote. The following menu will appear: Selections STORE, RESTORE FACTORY, and RESTORE DEFAULT are not shown after selecting SELECTION. Press the cursor down button on the Remote for these selections to appear. RESTORE FACTORY loads Convergence defaults from the Factory Loaded section of the Convergence Memory IC. RESTORE DEFAULT loads Convergence defaults from the sets software. To perform a Touch-up Convergence: 1. Enter the Convergence Mode and select RED TO GREEN or BLUE TO GREEN. Do not select GREEN (Green Geometry) without placing a Template over the screen. To perform Green Geometry, refer to the Complete in-depth Convergence. 2. Use the Cursor buttons on the Remote to Navigate from one adjustment point to another. Press the Status or Index button on the Remote to select ADJUST. Use the cursor buttons on the Remote to adjust the Red to Green or Blue to Green. Press the Status or Index button again to navigate to the next adjustment location. 3. After Convergence alignments are complete, press the Menu button on the Remote to return to the SELECTION menu. 4. Highlight the STORE selection and press the right cursor key on the Remote to save changes. 5. Use the GREEN TO RED or GREEN TO BLUE selections to perform convergence when the Green CRT has been replaced.
Posted on Aug 23, 2007
  • tan keong Feb 09, 2011
    is old model and new model is same
To much yellow
Posted on Mar 02, 2008
2 Suggested Answers
SOURCE:
Slinteriors
  • 8617 Answers
SOURCE: Convergence
If the red isnt responding via the remote you will need to replace the STK392-110 Ics as the service menu adjustment will not correct it 100% due to the IC being faulty and the red and half the green is controlled by one IC and the blue and other half of green is controlled by the second IC so without changing both ICs the set will progressively get worse. Both ICs are stk392-110. You can get replacements at the following link along with instalation instructions
http://servicemanuals.vstore.ca/
Posted on Jul 25, 2008
Fixing color convergence red and blue lines
most TVs have an adjustment for convergence in your on screen menu, go into convergence of service menu & try to adjust; it it is still too far out of convergence contact a service technician as convergence issues can be very difficult to resolve unless you are very sure of what you are doing.
Dec 26, 2014 | Televison & Video
Picture not in focus
Devices: All projection TV's (HD or analog), especially Samsung
If its a Samsung HCN653W (or similar model), the first thing to try is the menu option named "Magic Focus", which tunes the set's focus.
Otherwise, it sounds like a job for a convergence. Perform a convergence procedure on your TV, and if the problem recurs within a few days/weeks, then your TV's 'convergence amplifier' board (aka "convergence amp board") is starting to fail.
This board may fail completely, in which case, your convergence procedure will fail to improve the picture.
A "convergence procedure" can be performed entirely by just using the appropriate setup menu option and your remote control.
This board may partially fail, in which case your convergence procedure will properly converge the Red, Blue, Green colors on just part of the screen, whereas a properly functioning convergence amp board will allow complete convergence of the colors across the entire screen.
Your TV's convergence procedure instructions will be found in your TV's Owners Manual.
At least one Projection TV manufacturer recommends that the consumer perform a convergence procedure every 30 days, but most TV owners find that excessive, and might only do one when (a) there's an evident color convergence problem in any part of the picture, or (b) once every 3-6 months.
How-to video: www.youtube.com/watch?v=esk4nYZKFcg
how-to instructions: www.ehow.com/how_2034880_perform-convergence--tv.html
cost to you: $zero
If the convergence amp board is bad, cost for a service call would be $300 (USD) plus $100 for a new board plus 50% markup on parts = about $450 (USD)
Cost to order a new board online: about $100 (USD) + shipping + sales tax.
Alternatively, if you can solder/desolder STK's (Power Amplifier Integrated Circuits), one can repair a convergence amp board for as little as $30 (USD) or so.
Dec 04, 2011 | Sony Televison & Video
Hi, i have 2003, 57 in" hitachi rear projection tv, model #57G500A. the problem is a thin wavy line across the top and bottom of the screen. could you tell me what would cause that.thank you for your...
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes,the tv convergence board have 2 dead convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Mar 21, 2011 | Hitachi 51F500 51" Rear Projection...
Green auto convergence
The master convergence settings have to be close for the Autoconvergence to work. If they are not you need a technician to go into the service menu and adjust them.This is a long job and you can't do it yourself.
Mar 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Apex GB43HD10 Convergence
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 10, 2009 | Apex Digital GB43HD09 43" Rear Projection...
Sony kp 51ws510 convergence problem
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Dec 19, 2008 | Sony KP-51WS510 51" Rear Projection...
Distorted Picture
  • Screen looks 3D
Aug 02, 2008 | Toshiba 65HDX82 65" Rear Projection...
Convergence
Jul 13, 2008 | Toshiba 55H70 55" Rear Projection...
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Hitachi 50" 50GX30B PJTV
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Using your original remote go-to the tv settings then goto the convergence or magic focus section
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Oct 20, 2007 | Hitachi 50UX57B 50" Rear Projection...
Philips 60P8342 60" Rear Projection Television Logo
911 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
