Question about Datalogic D100 Handheld
D100 PROBLEM Camera will not turn on .....battery is charged but no luck.
    Problem Solver:
  • 19 Answers
Do you currently have hand-held inventory scanners?
Although you may not be familiar with Legacy's Technology Services, we may already be servicing your barcode scanners, barcode printers and even POS hardware. Many sellers of extended maintenance contracts have used Legacy for years to perform service on devices covered by their contracts.
Maybe you're looking for a specific hard to find part. Chances are I've got it!
We also carry refurbished equipment if you are in the market.
Give me a call for a quote and to discuss your current needs.
Joe Anselmo
Legacy Technology Services Inc
(847) 621-3300 ext. 418
Email: [email protected]
Posted on Apr 13, 2009
Please contact our technical support phone # at 1-800-547-2507. Thank you, Brian Conley Datalogic
Posted on Aug 22, 2007
SOURCE:
My D100 have not been used for 3 years and now there is no live signs,even whit full baterry
For a camera to sit for this length of time will require cleaning the battery contacts within the camera. Check to make sure the battery terminals are not corroded or the battery is leaking in any way The terminals in the camera may be cleaned using a good soft red rubber eraser on the end of a pencil. You can use a puffer to remove any rubber dust make sure these are shinny if corrosion is evident then a more aggressive approach needs to be made. if you don't feel comfortable doing this service/repair I would suggest taking the camera to a repair depot. however if you have a few items around home like the pencil you may be able to affix a small piece of sand paper to the pencil and clean the terminals gently. All this is only if the terminals are corroded (not shinny).
Going back to the battery, check make sure the battery is not leaking and after sitting for that long I'd suggest putting it back on the charger again and let is sit for about 20 minutes then take it out of the charger for 10 minutes and back in again this should give it the kick it needs to start the charge cycle.
I think what has happened the first time you charged the battery the charger couldn't "see" anything (absolute no power) and just went into standby mode. If the battery fails to take the charge you will have to purchase another battery. Once you have power the camera should work as it did before.
Jan 18, 2011 | Nikon D100 Digital Camera
What is the meaning of this massage on anikon d100 camera "E r r".( this usually happens when switch on my nikon d100 camera and when i try to shoot it dosent and the "E r r" massage persists.please i...
Err is usually a camera malfunctrion. Re,ove the batery,a aaaaaatuen camera switch off/on 2-3 times *as if battery still in), replace battery and try again. Read Owners manual or got to Nikonusa.com to download a manual (or to ask Nikon) and determine if your D100 has a hardware reset switch(my dc70 does) and utilize that. If tht does not solve the issue, then service by an authorized Nikon tech is advised.
Oct 26, 2010 | Nikon D100 Digital Camera
My d100 will auto focus but will not shoot
Having received no response in over a month, I assume this is no longer a problem.
May 28, 2010 | Nikon D100 Digital Camera
Nikon D100: Lazy mirror return.
The reason the mirror is acting up is because the Shutter is going bad under slow shutter speeds. > The motor which drives the shutter charge and the mirror up and down is the same .
Apr 07, 2009 | Nikon D100 Digital Camera
NIKON D100 LCD DISPLAY FLASHING CHA ERROR WITH ANY CF 1 GIG
I had the same problem and thought I had looked closely at the pins in CF slot but after finally taking it to a repair shop, the tech showed me a bent pin. It really wasn't that apparent first time around. He told me its a common problem as long as they use the CF cards. I had the pins replaced and my D100 is working great. Best of luck.
Mar 21, 2009 | Nikon D100 Digital Camera
Nikon D100 stuck in Auto mode
take out the battery and put them back in again then turn the camera back on. This should work it worked for me.
Feb 06, 2009 | Nikon D100 Digital Camera
Nikon D100 shows # of pictrues left - on the display -
This is normal. Page 17 of the D100 manual says when the main battery is inserted the display will show the number of exposures remaining. If no CF card is inserted it will show E.
Nov 25, 2008 | Nikon D100 Digital Camera
Nikon d100 locked
Have you tried to reset the camera? I seen this a few times .. and the camera reset did the trick. I've never heard of the motor noise though.
Oct 20, 2008 | Nikon D100 Digital Camera
Nikon d100 cf card not recognized
yes i know about this problem. basically its your sensor reading chip which has burnt out. it can be replaced at a cost of about £40/ so not expensive.
[email protected]
bye
Oct 05, 2008 | Nikon D100 Digital Camera
Continous shooting with D100 - it doesn't work...
Mine too. It's a worn-out selector switch. Jiggle it and it'll work again. Time delay same. Our college has four Nikon D100s with this problem. Poor switch contacts.
Dec 03, 2006 | Nikon D100 Digital Camera
Open Questions:
See all Datalogic D100 Handheld Questions
Datalogic D100 Handheld Logo
123 people viewed this question
Top Datalogic Computers & Internet Experts
Mike Story
Level 1 Expert
Paul Bade
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
