Question about Zebra P210i Thermal Printer
Printing problems card will begin to print then in the middle of the magenta panel print, it will stop, kick out the card and part of the magenta ribbon color will be stuck to the card.
My printer is off line what do i do
Posted on Feb 02, 2009
Sounds like the heat is set too high.
Posted on Aug 21, 2007
SOURCE:
I have a Konica C250 machine which cannot print red color at all. I had changed the toner and image unit but still cannot print red color. How can I solve this problem?
Recommended that you have a tech come out and look at it might have a bad LED assy. for the Magenta Image unit. All other color print OK? Can you print gradation test pattern for each color in service mode? Meter count, details, stop 00 stop 01 Test Output Gradation pattern select magenta. If you open the side cover after printing a document with the color magenta try to catch a print of paper do you see the color magenta on the transfer belt if yes the drum is ok could be the transfer belt magenta 1st transfer roller on the belt replace the belt assy.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 28, 2015 | Konica Minolta BizHub C252
My printer hp psc 1315 stops in the middle of printing cd labels or anything thicker than regular bond paper. It prints the design perfectly on regular bond paper. I already set the PAPER TYPE to PHOTO and...
It's not a printing problem ' it's your networking' try using the cable provided with your printer via usb' if it prints ok' then you need to reconfigure your printer settings' updates or clean re install.
Oct 13, 2017 | HP PSC 1315 All-In-One InkJet Printer
My printer is hp laserjet cp 1515n. After printing some documents it writes "printing cool down mode" and begins working very slowly. Please help me
1515n - I have the Magenta colour 'shadowing' the blue test. A mirror image of the blue text. [slightly staggered] Black is fine. Applies to all Word docs when printing in blue - can you help please?
I only use genuine cartridges.
Thanks
Jules Radstock
Jul 23, 2010 | HP LaserJet CP1518 Printer
PRINTER (not web camera!) HP Deskjet 712c Printer began printing mostly blackPrinter began printing mostly black & magenta so I replaced the color cartridge. Color did not improve and then black...
First run the CLEAN HEADS and see if that helps. If you don't use your printer at least once a week the Print Heads get dried out and will not allow the ink to pass through to the paper.
Go to control Panel and click on Printess. Then when the window comes up, CLICK on Properties TAB and then in the next window, CLICK on CLEANING.
You may have to replace your PRINT HEAD if that doesn't work.
Hope this is of some help. Bud
Feb 06, 2010 | Computers & Internet
I have already printed more than 1000 cards on my printer. Now often it started some problem like it prints the yellow & magenta layers, then skips printing cyan & black (with screeching noise as...
I think all you need at this point in time is servicing the card printer, with some of the hardware components like the ribbon been replaced. try get a technician that will help you with this.
I wish you best of luck.
Dec 30, 2009 | Fargo Persona C30 Thermal Card Printer
Card Jam 02:16 Error in Magicard Rio 2E Printer
Check the front rollers all turn when the cleaning button is pressed with the top open.
Check the front pinch rollers on the thin metal shafts are pulled down onto the cards by their springs. Check that the ends of the pinch roller shafts are retained in the plastic cam followers. The card is not being gripped to drive it back to print the Magenta panel.
Sep 23, 2009 | Magicard Avalon Duo Thermal Card Printer
Printer sat idle for a year. Now the colors won't
try cleaning the copper contacts on the print cartridges and then thry printing....see if it helps....
Jun 24, 2009 | HP cp1700 Color Inkjet Printer
Magenta Ink Streaking
that printer color cartridge is a problem... buy a new one.... color ink
Jun 16, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Zebra P210i Thermal Printer Logo
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
