Question about DeLonghi DCG39 Electric Blades Grinder
How to select grind courseness for a DeLonghi DCG39 grinder
I bought one of these however it was the display model and the last one they had so it didn't have a user manual with it. I can't figure out how to adjust the machine for course, medium or fine grind. Any help will be greatly appreciated!
  • 1 more comment
  • Anonymous Dec 27, 2007
    I have the same problem, I purchased a demo. Is is possible to get a copy of the user instructions?
  • coffeekim Mar 23, 2008
    I have the same problem I bought this machine and I am unable to select how course I would like my beans I did not get any instructions with it and I cannot get it to do what it is suppose to do
  • Anonymous Dec 28, 2008
    I have the same problem!
    Champion:
  • 279 Answers
Go to delonghiusa.com. customer care. manuals. They have yours to download.
Posted on Sep 18, 2009
Is there a “ grind size” for coffee grounds in a de longhi expresso maker
Depending on the model. You can find the instruction manual here:
https://www.delonghi.com/en-meia/customer-support/user-instruction-manuals
Nov 12, 2018 | Coffee Makers & Espresso Machines
DELONGHI ESAM 5500 WON'T MAKE CAPPUCCINO SAYS GRINDS TOO FINE, BUT WILL GRIND AND MAKE REGULAR COFFEE
have you tried cleaning it as described in your user manual,, can you hit the button for regular grind? there are alternatives, a coffee grinder if failry cheap at 10 dollars US,,
Jun 07, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Coffee grinder only grinds to course no matter where grind adjuster is set
From what I've read about this grinder, you should be happy that it worked well as long as it did.
I say chuck it & buy a new one!!
Apr 13, 2012 | Coffee Makers & Espresso Machines
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
My DeLonghi KG79 coffee grinder has stopped working after one grind. When the on button is pressed nothing happens. I tried changing the plugs fuse... any thoughts? cheers Kev
I should imagine one of the safety switches are not closed. The lid of the maker must be on and the filler has to have its cap on and inserted in the machine.
Mar 19, 2011 | DeLonghi KG79 Grinder
DeLonghi Esclusivo Magnifica grinder cogs have stopped spinning while the hub turns, thus no grinding is done! Help
u need it all set back up///needs grinder tanken out . if lugs are broken u need to put new grinder in....
Jan 25, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Overloaded grinder no longer turns after puff of smoke!
the shear pin, which goes through the grinder blade base and the motor shaft has 'sheared' off the protect the motor from overload. The metal bits of the pin need to be removed from both the grinder part and the shaft, a new one inserted. It is a 'pressed fit', so it will be hard to remove.
After the bits are removed, a common 'roll pin' of the proper diameter should be a suitable replacement
Feb 04, 2010 | DeLonghi DCG39 Electric Blades Grinder
Coffee machine Delonghi Magnifica grinding function not working
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
Jan 13, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Mazzer luigi super jolly
Easiest way to set the grind on the super jolly is to remove the beans, turn towards fine until you can barely move the middle stem in the grind chamber, then turn towards course about 12-14 notches on the grinding adjuster(not numbers but notches between numbers). If you still cannot get a fine grind and it is not a brand new grinder replace burrs.
Feb 28, 2009 | Mazzer Coffee-grinder SUPER JOLLY Electric
Won't come on?
I just bought a brand new unit and as recommended I unscrewed the top bean hopper and the coffee ground container-cleaned and wiped.After that I screwed back everything and tried to grind some beans.The timer was ticking away but the grinder just refused to start.I switched off the main and unscrewed the hopper and carefully screwed it back.Halfway through,I noticed and felt that you must balanced and screwed it with a smooth movement until the the whole piece is in place.The grinder just started without a hitch.This grinder has a protection circuit whereby if any part is not properly installed it will not start.
Mar 07, 2008 | DeLonghi Retro DCG59 Electric Burr Grinder
DeLonghi DCG39 Electric Blades Grinder Logo
317 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
