Question about Panasonic PV-GS35 Mini DV Digital Camcorder
PV GS 35 wont play tapes from other cameras
Hi I bought a panasonic PV GS35 filmed some stuff and made little iMovie videos with it. Everything seemed fine. Then, I borrowed another little handheld camcorder made by Cannon and filmed with it. I gave that camera back and tried to use my PV GS35 to review the tape but the sound cuts in and out. I tried to capture the video onto iMovie and while playing the tape through my PV GS35 several frames were completely omitted. I also tried using tapes fimed in a Panasonic 3CCD camera. The same thing happens. All of these cameras use the same mini DV tapes. Is there a reason why the PV GS35 only plays tapes fimed on the PV GS35 or is this camera messed up? Thanks Paul
  • 3 Answers
Perhaps it has to do with the SP and LP settings, I know certain video editing programs won't capture video recored in LP.
Posted on Nov 13, 2007
Can't tell if tape is recorded.
Well thanks that you found out. i was going to tell you to do exactly what you did because the timecode rreads where it is tapes and does not where it's not.
Nov 23, 2011 | Panasonic PV-GS35 Mini DV Digital...
I lost the disk for my Panasonic PV-GS35, where can i get the software from that disk?
You can download it from the below link:
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/MiniDV-Camcorders/Drivers-Downloads/model.PV-GS35.D
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Mar 09, 2010 | Panasonic PV-GS35 Mini DV Digital...
Blue lines on panasonic camcorder playback mode
Mine is doing the same thing. It looks like the film holes on a 35 mm film camera or and old 8 mm video camera. It plays fine just can't get rid of the blue marks. Anyone with a suggestion?
Feb 09, 2010 | Panasonic Palmcorder PV-GS120 Mini DV...
Panasonic PV-GS35 will not connect to iMac, so can't upload video from mini DV cassettes into iMovie. when I connect with my USB cable, nothing shows up on the iMac saying that the camera or a "N0_NAME"...
So if it's miniDV and you have a firewire cable, it should work. Have you followed this sequence:
If your battery is sufficiently charged to run the cam for an hour's worth of tape, fine, otherwise connect cam to AC power. With cam OFF, connect Firewire cable to Mac and cam. Open iMovie, name your project and create so that the viewer screen comes up. Turn on the cam. At this point, your Mac should, within moments, say "camera connected". Cam needs to be set on "playback" mode for capture. Then click "import" button and your Mac will control the cam.
If you still get a "no camera connected" you have to consider the possibility that either the firewire cable is bad or the firewire port on cam or Mac is bad. If you have more than one firewire port on your Mac, try switching. An Apple store should be able to help you determine if you have a bad cable or cam port, if you take both in to try on their Mac. Hope this gets you on track.
Dec 07, 2009 | Panasonic PV-GS35 Mini DV Digital...
Panasonic pv gs 180 can't import into imovie
Hi, I managed to down load mine by connecting with a firewire and setting the camera to playback mode (not PC), opening imovie, turning the camcorder on and selecting file -' import from camera". a screen came up then I started playback on the camcorder and was able to select import from the screen on the imac.
Sep 28, 2009 | Panasonic PV-GS180 Mini DV Digital...
Playback problems - timer stays at zero
Firewire transfer problem with PV-GS320. HAd bought the PV-GS90 and ran into significant transfer issues importing to Mac (iMovie and Fincal Cut Express HD both had problems). Upgraded to GS320 as Macworld rated it highly. Same problems: video plays back perfectly with no computer connection. once connected, video and audio stutter, go out of sync, sometimes just stop and/or crash the program.
I've used a borrowed Canon GL with this Mac before with no issues, so I suspect the camera. Have tried reset button, trashing preferences, restarts, the works. still can't get clean video to transfer from a brand new camera. Any Ideas?
Feb 09, 2008 | Panasonic PV-GS320 Camcorder
Can I have a driver for panasonic pv gs35 driver vista?
You don't need a driver. Just connect the camera using the cable provided with it; turn the camera on and set it to play movies. The first time it will upload the necessary drivers. THen, use Windows movie maker (it's included in vista, my version at least) to import the movie (if you don't find it, click on the start button and type "movie" on the search box). It's much better than the crappy software provided by panasonic anyways.
Oct 10, 2007 | Panasonic PV-GS35 Mini DV Digital...
No power; can't eject cassette
Pete Check your Battery Contacts and see if they are Corroded or dirty,plus if there is a Memory batt pull it then keep both batt off for 30 mins Charge the one in your Charger if your charger is eqipped with refresh,Enable it but first Clean contacts with Pencil eraser ttech Hope that helps ttech
Jul 24, 2007 | Panasonic PV-GS35 Mini DV Digital...
Open Questions:
Panasonic PV-GS35 Mini DV Digital Camcorder Logo
274 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
