Question about Smart Technologies SMART Board 580 (SB580)
Video Problems with Windows Media Player
While playing a DVD on the computer and projecting onto a SmartBoard SB580, the windows background and video player shows on both the computer monitor and the SmartBoard. However, the DVD video playing does not display on the Smartboard although the player and Windows background are displayed.
  • Doob Aug 21, 2007
    I had to wait until I got to work this morning to try the suggested fix; therefore, I did not know how to rate the suggestion. Now that I have tried the fixes and they didn't work, I can rate it as thanks for trying.
Why is the projected video black in the Player? If you can see the Player, but the Video and Visualization pane is black, this usually indicates that your video card is not configured correctly. You can usually correct this problem by changing the video acceleration and/or overlay settings for your video card. To change video acceleration, do the following: 1. In Windows Media Player, on the Tools menu, click Options. 2. In the Options dialog box, click the Performance tab. 3. In the Video Acceleration area, move the slider to adjust the video-acceleration capabilities of your video hardware. Drag the slider to Full to use all available video acceleration. Drag the slider to None to use basic video-acceleration settings that work with most video hardware. To change overlay settings, do the following: 1. In Windows Media Player, on the Tools menu, click Options. 2. In the Options dialog box, click the Performance tab. 3. In the Video Acceleration area, click the Advanced button. 4. In the Video Acceleration Settings dialog box, under Video Acceleration, clear the Use overlays check box.
Posted on Aug 18, 2007
SOURCE:
As a novice I wish to download an instruction video to a dvd disc. How would be good!!!
If you just want to put the video on a disc that will be played on a computer, you can simply copy the video file onto a disc as data. Windows has basic disc burning capability built in, but other applications give you more features. I use CDBurnerXP, which is free. Another free burner is InfraRecorder. Also, many computers come with versions of programs like Nero or Roxio preloaded. With one of these programs, you pick the "create a data disc" option, drag the video file into the appropriate window, tell the program to burn the disc, and you're done. Again, this would only play on a computer using a player like Windows Media Player, WinAmp or VLC.
If you are looking to make a DVD that would play on a regular DVD player, life is a little tougher. This is especially true if you want to add any features to the DVD like menus. You need a DVD authoring application for this, and the really easy-to-use ones are commercial versions that aren't cheap. There is a good, free program called DVDStyler that I use. It's a bit tough at first because the documentation is weak, but there are several YouTube videos and other sites that can help. The program lets you make your own menus, add background pictures and music, converts the video files to the format needed to make a DVD, and allows you to preview the disc before you actually burn it. The result, though, is a DVD that works like the ones you buy at the store.
Hope this helps get you started. Thanks for using Fixya!
Nov 12, 2010 | Computers & Internet
Tip
Easy way to burn WMV video to DVD and play on a DVD player
One of the most popular video formats used with computers and found on the web is WMV. WMV is wide compatibility with Windows PCs. it short for Windows Media Video. And it is the name of the video encoder that was created by software giant Microsoft. The advantage of WMV is that Good compression and quality. WMV movies are played with third party media player programs such as "Windows Media Player, "RealPlayer" and "VLC player". A lot of people saved WMV clips onto compute and want to make WMV to DVD for playback on a DVD player watch videos on TV screen.
DVD ( Digital Video Disc ) is an optical data storage device which can hold large capacities of digital data like high quality video and movies. A VOB ( DVD Video Object or Versioned Object Base ) file is a container format for DVD video files. An explanation of VOB files is beyond the scope of this article, but a study of the software part of the DVD format is essentially a study of the VOB container file format. With CD’s or Compact Disc’s becoming virtually obsolete with the emergence of high capacity storage HD DVD’s and Blueray disc’s, more and more video editing tools are geared to conversion between these two highly popular media formats, WMV to DVD.
How to convert WMV file to DVD?
Before we go to detail steps, there are some Pre Requirements: A blank DVD disk (DVD +R, DVD-R, DVD+RW or DVD-RW), rewritable DVD-ROM, A WMV to DVD Converter. Most DVD burning software can easily burn WMV files to a DVD as data. Here we use Daniusoft DVD creator. It can burn WMV Video files to DVD directly.
Step1. Import WMV videos
The first step is to import WMV files that needs to be burned onto a DVD may reside on the local hard drive or on an external device such as iPod. If it is not on your computer, copy the WMV file onto the local hard drive first and then Select/drag the WMV file into the main interface of D DVD creator. You could check the video size on the measure bar on the bottom. Make sure the space doesn't exceed the total DVD capacity.
Step 2. DVD menu making
Click "Menu Template" to create DVD menu. There are different styles of built-in templates, frames and buttons for your choice. To apply a template, frame or button, you can just double click it. You can even add text, background music and background image to customize the menu.
Previewing WMV video
Just for make sure everything goes as your plan you could have a video preview before burning it to DVD.
Step 3. Convert WMV to DVD
Now you can burn WMV to DVD disk. Go to set TV Standard (PAL/NTSC) on "Setting" option and output Aspect Ratio (4:3/16:9) on "DVD setting bar". Click "Burn" and then select your DVD drive (if you have more than one DVD drive on PC) and Click "Start" to burn your project.
Tips: The volume of DVD use is shown on the bottom side. You can select DVD type of "D5" or "D9". If the video size is exceed the DVD capability you can reduce it by setting output quality. E.g. select "high quality" instead of "Best performance".
That it, with Daniusoft DVD Creator, you can convert WMV to DVD and even make your own DVD menu in 3 steps. And the application also can burn other common files like MKV WMV M2TS MPEG AVI FLV MOV, etc to DVD and fully compatible with Windows 7 (DVD Creator MAC version is also available). Now, just enjoy watching your own made WMV movie on home DVD player.
Related guides:
How to convert and burn MOV to DVD?
How to convert and Burn MKV to DVD for playback on DVD Player?
on Jun 10, 2010 | Computers & Internet
Tip
Enable Dreamscene
Windows Vista Ultimate has a great feature of putting video as your desktop background. A lot of windows XP and windows Vista (non ultimate) user wanted to do the same. Here is how it can be done using a free and popular software. VLC player.
To set and play a video as wallpaper in Windows XP, Windows Vista Home Premium, Home Basic, Business, Enterprise and Starter edition:
  1. Download and install VLC Player for Windows.
  2. Run VLC Media Player, go to Settings -> Preferences, expand Interface and click on wxWidgets. In the bottom right corner of “wxWidgets interface module” window, click on “Advanced options” to show advanced settings. Then uncheck the Taskbar check box in order to remove VLC Player title from the taskbar while the program is running. Check Systray icon if you want to enable Systray (system tray or notification area) icon instead.
  3. Next, expand Video -> Output Modules and then select Direct X. In bottom right corner of DirectX Video Output window, check the Advanced Options check box in order to see all the settings available. directx-video-output.jpg
  4. Check and tick the “Enable wallpaper mode” check box.
  5. Then, select Playlist and then check or tick the Repeat current item checkbox.
  6. Press “Save” button when done.
  7. Open and play any video that you would like to set as motion wallpaper in VLC Media Player.
  8. If the video hasn’t yet been set as desktop background, right click on the video and click on “Wallpaper”.
  9. The video or movie will be set as if it’s DreamScene motion desktop background wallpaper.
If you do not configure VLC Player to repeatedly play current media in loop, you can still do so after playing the video. Simply click on View then select Playlist. Highlight the video media content that is playing and click on Repeat One or Repeat All button as shown below to loop the video for non-stop video wallpaper.
Looping the animated wallpaper
Note that the video must be encoded in a video format supported by VLC Player such as MPEG, AVI, MP4, WMV, FLV (Flash Video) and etc. Else you will need to convert the video clip to the supported format.
on Feb 06, 2010 | Computers & Internet
My LG DVD palyer will not play Windows Media 7
Hi,its obvious from your problem that both windows media 7 and mpeg video formats are not compatible with your dvd player,as you know,the windows media 7 is a very recent media player which is compatible with only very few dvd players so its not a defect with your dvd player,however you can go through your manual to see the list of video formats supported by your dvd player.
Thanks and take care
Apr 16, 2010 | Televison & Video
DVD Jumper digital copy is wmv -loaded on mosaic,
your player seems not to support the .wmv video format,
to watch it on pc try another video.player like KLMcodec, update the windows media-player codecs or useother freeware videoplayer software.
some programs give you the chance to change
the video formst of a film,
change the format of file from .wmv to .avi and reupload onto player
Jun 13, 2009 | Creative Labs Zen Touch MP3 Player
I want to download my VLC videos onto the Windows media player 11
vlc plays all sorts of videos
but wmp doesnt recognize most of the videos
what you have to do is convert the videos to .dat or .wmv or something using total video converter or something like that and then try
you can download total video converter from the net
Jun 09, 2009 | Microsoft Windows Media Player
VIDEO FILES OF CANON SX10 IS NOT PLAYING IN WMP
H264 is a "mov." file. Windows media player11 and Power DVD 9 do not support this type of file. If you don't like QuickTime, there are many free media players that will support it (VLC is a good one). You could convert the mov. file to an avi. file with a video converter program. Then your avi. format movie will play in WMP
Apr 10, 2009 | Canon PowerShot SX10 IS Digital Camera
Shaky sound and video
To solve this:
1- Check if you have more than 1 DVD player program installed. If yes, uninstall any you don't use (being careful not to uninstall the one you use or that's needed for the recording part of what you do)
2- Check if you have more than 1 Media player software like VLC media player, Microsoft Media player (automatically installed) etc.
Because it also affects video played saved on your computer (assuming AVI or video you play using Windows Media Player or another player) and DVD playback, its usually a program that is conflicting with another of the same type (plays media Audio/Video). If the above solution did not work, try performing the "system restore" and choose a date of when you definitely remember it working without chatter. If this is not an option, proceed below.
If your computer has been performing regular updates and you happen to be using a new Windows Media player, do you remember if it happened during a computer software update? If yes, the fault lies with Windows Media player having performed an upgrade to itself. You may want to "demote" media player by going to Control Panel and "add or remove programs" list (making sure "show updates" is checked) and scroll down until you see Windows Media player. Then uninstall the latest update it has performed.
If you installed another media player/DVD player program(s) and it coincides with your problems, uninstall it. Multiple DVD/Media players have their own settings, file changes/updates and they can affect one another if installed simultaneously on 1 system.
Let us know how it goes and rate us. :)
Dec 03, 2008 | Dell Inspiron E1405 Notebook
Transfering Videos to my computer?
Sounds like you have conflicting file associations, which means that some types of files open in one player and others in another. However, this isn't your main problem.
To play the DVD file on the pc you need to have the .ifo, .vob and the .bup files in the same directory as well as the video_ts files etc. Easiest way to do it is to copy ALL of the files from each disk to a folder on the pc, then you can play them from there and format your disks ready to be re-used.
If you'd like further help with converting the format and sorting out your file associations please post again but the above information should cure your immediate problem.
erch.
Mar 15, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Smart Technologies SMART Board 580 (SB580) Logo
847 people viewed this question
Top Smart Technologies Computers & Internet Experts
Ekse
Alun Cox
Are you a Smart Technologies Computer and Internet Expert? Answer questions, earn points and help others
