Question about Philips 55PP9401 55" Rear Projection Television
HD Where is the HDMI output on this particular tv?
    Genius:
  • 1,153 Answers
Didn't know it had Hdmi output, only input
Posted on Aug 18, 2007
SOURCE:
Connect laptop to tv
Hi there
There are some things that may be causing problems:
  1. Make sure the output from the laptop matches the input capabilities of the TV eg 1080p HD or whatever.
  2. Make sure that the TV is set to read from that particular HDMI port.
  3. Make sure that the laptop HDMI port is activated - this is not always the default.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 22, 2015 | Televison & Video
I hook up a HDMI cable to my tv to ps3 and the audio sound is horrible. What do I do to fix this?
Hello... This is most problem due to the cables or your audio output settings. Ok, firstly try checking the cable's are in properly and no dust has built up. Then at the main menu, go to settings. Scroll down until you get to sound settings, choose audio output settings then HD-MI then auto. If that doesn't fix the problem, choose manual and select the most basic output. Any further questions please don't hesitate to ask. Thanks for using fix ya.
Dec 09, 2010 | Sony Playstation 3 (PS3) Console
Do you get HD quality by outputing to TV using
no ,but you will have a dvd quality picture. HD means
the picture size format usely 16:9, HDMI its a Hd
multimedia interface its HD quality to...
hope that help you..
Feb 18, 2010 | Sony HVR-A1E HDV Digital Camcorder
How can I hook my 754n to my TV [s-video or HDMI capable]. This PC has no TV out, not sure about VGA.
Desktops are not nearly as problematic as laptops in this area, so you are in luck.
Depending on your video card, and if you don't have an up to date card, it would pay you in the quality of your video output to obtain one, there should be outputs on the card.
There would be no TV out (composite video) unless you have either a tuner card or a high quality maxed memory card.
Rather than recommending a specific card, which depends upon your particular configuration of clock speed of your cpu and how much memory you want to share with your video, I will recommend a class of cards that might help you, and a particular manufacturer or two.
The ATI cards have been superseded in my esteem by Radeon, though either is a good bet.
One card that will do you good is the Radeon HD 3870 with a half a Gig of DDR2 memory, so that your system memory doesn't have to do the whole graphics job. PCI Express 2.0 and the AGP version has DVI and TV out, and has Dual Lin Dual DVI HDTV connectivity HDMi support along with VGA and Blu-Ray and HD DVD support and just happens to be the cheapest of the cards, currently listed in Tiger Direct's catalog [LCB] for only 49.95
Apr 07, 2009 | HP Pavilion 754n PC Desktop
Hooking up from hd receiver to hdtv ready projection tv. what cables do I use? vga or rca component red, blue, green and sync white/black? My hd receiver has output of :hdmi, rca component, s-video ,...
This particular television puts you in a tough bind - you can use Component cables in AV1, but you won't be able to get HD. Or you can use the Component cables in the right-most component slot, but since your HD Receiver probably doesn't have V/H Sync connectors, you may get a rolling picture. Try the component cables in the right-most slot (I'm assuming, perhaps incorrectly, that your actual model # is not really a 50P8341, which has no V/H Sync slot).
-Tha Mp3 Doctor
Mar 07, 2009 | Philips 50P8341 50" Rear Projection...
This particular television puts you in a tough bind - you can use Component cables in AV-1, but you won't be able to get HD. Or you can use the Component cables in the right-most component slot (AV-4), but since your HD Receiver probably doesn't have V/H Sync connectors, you may get a rolling picture. Try the component cables in the right-most slot - if the picture doesn't roll, you're in business.
Once again, I doubt that your model # is a 60pp9202, since that model doesn't have a VGA or DVI slot. If the picture rolls after trying the above, you will need to purchase a HDMI-to-DVI-D cable and hook it up from the HDMI output of your HD receiver to the DVI slot (that looks like a VGA slot) on the back of your Philips or Magnavox.
-Tha Mp3 Doctor
-Tha Mp3 Doctor
Mar 07, 2009 | Philips 60PP9202 60" Rear Projection...
HD Outputs
you mean inputs.
Press the TV/VIDEO button on the remote till the TV goes to the input you want.
Aug 01, 2008 | Sony KP-51HW40 51" Rear Projection...
1st time using component video connections on my onkyo
Yes, switch to the video input that you are trying to configure (i.e. video 1-4). Press the menu button on the receiver or the remote and cycle to video settings. There should be a setting that says "video output" or "output" - set that to component. You may also have to configure the Input for that particular setting. For instance, if you have an HD tivo going into component 2 but you want it to be Video 1. Select Video 1, hit the menu button and scroll to video setup. Select video input setup and cycle it to component 2. Next, use the menu to cycle to video setup, select video output, switch to component. This should solve your problem. As a sidenote, you may also have to configure the audio in/out if you're using digital coax or optical. Let me know if this works.
Feb 02, 2008 | Onkyo TX-DS787 Receiver
How to set up hd on this tv
Hi Brien,
You can hook-up your HDTV via the BNC inputs with the right equipment below.
Here is the link to a website that sells video transcoders for projectors and projection televisions. In addition, the link will take you to one particular transcoder that will work for your application.
http://www.curtpalme.com/RTC2200.shtm If you use this transcoder you will have to find a VGA to 5-BNC breakout cable to connect the output of the transcoder to your TV HDTV RGBHV inputs. The extra VGA input on this transcoder will not be used for your application. They sell another product that comes with the cable you need, but I did not see it listed separately. That product is their HDFury Basic Kit at the link below.
http://www.curtpalme.com/HDFury.shtm
Regards,
MyTvGuy
Jan 12, 2008 | Mitsubishi VS-80803 TV
Philips 55PP9401 55" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
