Question about SanDisk SDMX1-1024-E18 MP3 Player
My SDMX1 Won't let me format it. Plz help!
My mp3 has stopped letting me put files on and off. Personally i thought that the files on it were currupted because i couldn't listen to them at the time, so i tried to format it.The format would load to 100% and then say failed to format. I've spent days trying to fix it ,researching, playing around with it. plz help!
  • scottie3 Nov 20, 2007
    can't format sandisk, even if I click on icon in my computer icon
  • SanDisk Master
  • 10,543 Answers
Reformat using FAT instead of NTFS.
Posted on Feb 15, 2018
SOURCE:
ThaMp3Doctor
  • 8596 Answers
SOURCE: My MP3 player won't regonize or play all my songs!
Renew Rhapsody subscription and resync
Posted on May 24, 2008
SOURCE: i need help with my mp3 it wont let me listen and i already tried to format it and
Thanks a lot Devious . It worked
Posted on Jun 06, 2008
johnychel
  • 796 Answers
SOURCE: Sansa c150 MP3 player hung
try to format the player and see whether the system detects it ??
else try to detect through scan hardware changes...
Posted on Oct 06, 2008
SOURCE: my sansa e260 stopped working after unsuccessful formatting
I have guys, I just spoke with the Sansa representative. Even if you have Windows Vista, you do not need a drive for e260 given that Vista carries that drivers for it. If you have tried the steps above, but you Sansa still did not format successfully after using the recoverty tool. This is what you do:
Set you Sansa e260 in recovery mode
- set it to hold
- hold rec
- connect to computer while you are holding rec
- device should be now in recovrey mode
- go to my computer
- go to the folder 16B format
- you will see a text file
- don't worry about
- add a new folder and name Sansa.fmt
- wait up to 2 minutes
- message on your device should say formatting
- wait a few minutes for formatting to take place
- stop the device by removing it safely using windows Safely device removal tool on bottom right corner of your screen
- disconneting your Sansa and you should see a message upgrade finished, Sansa has been restored or something like that
- Power your Sansa on, and Bwala!!! your Sansa is back to normal.
Good luck
Dante
Posted on Oct 07, 2008
SOURCE: sansa mp3 shaker
First, don't plug the shaker into the computer, go get an SD card reader available pretty much anywhere, I use a Targus reader that turns an SD card into a USB thumb drive, before I got it (it was $8.88 at wallyworld(Wal*Mart)) I used a multimedia reader.
First thing you do, format the card, and make sure the MP3 files you put on the card are at least 128bit, Constant Bit Rate (CBR) [DO NOT USE VBR, IT WILL CRASH THE PLAYER], High Quality, Stereo, Original.
You can get these settings with the LAME encoder that adds on to AudioGrabber when you rip a disc. (Both AG and LAME are FREEWARE)
I have not ever had my shaker connected to my computer(s), just the cards, and I use mine daily at work to keep me sane, and I switch the cards a lot.
I do hope this helps!
Posted on Dec 30, 2008
It keeps on restarting and after switching it on it does not proceed i dont know how to update firmware on it pls help...
i had this also. just delete all files and folders. and do a full format. worked for me anyway.
Aug 22, 2010 | SanDisk SDMX1 MP3 Player
My SDMX1- 256MB can turn on but doesn't play and turn itself off
dont know what "hall" is, and im guessing the battery isnt dead---might need to format it
Aug 12, 2009 | SanDisk SDMX1 MP3 Player
Goodman mp3 player
be sure that the music on your itunes is on mp3 format. most music files on itunes are on aac, check this on the file properties. when you connect your mp3 player to your pc using USB cable try to go to my computer and you will see a new drive in there usually it says removable drive. just copy and paste the music file to that drive.
Feb 11, 2008 | SanDisk SDMX1 MP3 Player
SDMX1 problems.
http://www.sandisk.com/Assets/File/tech/docs/dap-user-guide-v2.0.pdf
Sep 21, 2007 | SanDisk SDMX1 MP3 Player
SanDisk sdmx1
Try formating it. got to my computer, right click on the sandisk and pick format. Let me know if it helped. D.
Apr 02, 2007 | SanDisk SDMX1 MP3 Player
Sandisk mp3 files got copied
Have you tried formating the unit try that and reinstall you music.
Jun 21, 2006 | SanDisk SDMX1 MP3 Player
SanDisk SDMX1-1024-E18 MP3 Player Logo
79 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
