Question about Samsung PCJ522R 52" Rear Projection Television
Can't change channels!!!!
Gets good picture and sound. got it 2 days ago worked fine programed a 1for all remote and one hour later the remote or the buttons on the front of the tv stopped working. just stays on, and on one channel unless i unplug it, but as soon as i plug it in it turns back on the same channel. cant put it on channel 3 or any video source because the buttons or remote dont work if you can help that would be great.
    Scholar:
  • 173 Answers
Take the batteries out of the remote...now check if you can change channels manually on the big screen. if so the remote is stuck on one signal that channel u said. get a new remote. if still same trouble on big screen look hard at the buttons and make sure none are jammed. also try to get to your setup menu and auto-program the channels it should search everything and then try changing channels. new stuff alot times plugs come loose, goes back to the factory workers...not pushing them tight have a tech check that at your home.
Posted on Aug 18, 2007
SOURCE:
Tv will not change channels. Batteries are new. It worked fine 2 days ago.
If the remote you are using will control several devices (TV, DVD player, cable set top box, etc.), make sure you have pressed the TV button, before you try to change channels. Sometimes another device button gets pressed by mistake, so the incorrect codes could be sent to the TV.
Mar 15, 2016 | Televison & Video
My Comcast Proscan HD TV has a small screen on non HD channels.
I have 2 pro scans Comcast hd. On Comcast remote small button ( for me Its small circular button bottom right) HD ZOOM. (enter above it)
Aug 30, 2012 | Televison & Video
I only get channels 2 through 22, 23 on up - nothing
this is not a problem from remote control. You must adjut the TV program go to the MENu, run the scanner, for add the program TV.Try to reach you supplier TV cable for explain then, if there are not problem witht the receiver box.
however if you need to reset the code program go for free download:
www.fitness.manualsonline.com or www .remotecodelist.com
sincerely. God bless you
May 07, 2012 | Televison & Video
On one channel...PBS we do not get any sound. Sound is ok on other channels and works on the other tv in the house
This television must have the ability to broadcast channels in SAP. Look for an SAP or MTS or AUDIO button on your Sylvania remote. The audio menu might be the place to find this setting as well. You want to remove the SAP and have the tv in either mono or stereo.
Sep 01, 2011 | Sylvania Televison & Video
How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Mar 27, 2010 | Vizio GV42L 42 in. LCD Television
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Re: 322 DTV Receiver - snowy screen on tv 2
Lets check the modulator set up at the main location TV 1. Press menu - 6-1-5 this will display how the TV 2 IS SET UP. It should say 22 air and if not use the arrow keys on the remote to change that info. Once you are done click done and go to the TV2 and see if it is working. It should be if you are set to view air or antenna channels on the TV2. If not there needs to be a few more things done to isolate the issue. Let me know and we will go from there. Thhanks for using Fix Ya.
Apr 11, 2009 | DISH Network 322 DTV Receiver
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
Ghosts?
re- program...................................................
Jan 25, 2008 | RCA F32450 32" TV
Channel Reception
It sounds like a defective tuner or a IF module as well. It may also be a defective capacitor(s) or cold solder joints inside the tuner circuitry. I woud suggest to use a VCR or a TV convertor connected to an Audio/video input to change channels instead of fixing it.
Good Luck.
Jan 21, 2008 | Sony KV-27V42 27" TV
Samsung PCJ522R 52" Rear Projection Television Logo
115 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
