Question about Patton Electric 2603 Router (2603/k/ui)
Configuring Router I want to know the default ip address of the device by which i can open it and then configure it according to my own settings????? How will i do that?
    Scholar:
  • 130 Answers
It is most likely 192.168.1.1 or something like that. To find it, connect it to your computer, and figure out the IP address that it gives your computer. To do this, open Control Panel, go to Network Connections, double click on Local Area Connection, and click the Support tab at the top. This page will show your Default Gateway. Type this into internet explorer to open your router's configuration.
Posted on Aug 18, 2007
    Problem Solver:
  • 12 Answers
Not only will you need the default IP but you will also need the default username and password as well. This particular unit has default settings that don't support port 80 management. (until you turn it on after setting up) Hence no default IP will respond. I will provide the information you requested but there's a 90% chance you will be required to connect via the console port. IP:192.168.200.10 U:superuser P:superuser Again my guess is if it's defaulted, going to that IP won't produce results. Also if you aren't getting handed an IP put your computer on .anything just not .10 Use hyperterminal settings :9600,8,n,1 if you find yourself having to console in. Hope this helps a bit. (go here for user guide) http://www.arcelect.com/2603_and_2620_qs.pdf
What is router
Basic steps to configure your router:
  1. Set Up IP Address and Sub-net Mask for their router.
  2. Now open the router Web Page by 192.168.0.1 in the browser URL.
  3. Login with your User Name and Password.
  4. For Manuall Configuration and Set-up router according to your ISP.
Router have different configuration according to Model. for more router support http://support.dlink.com/ and any router related technical support D-Link Router Support .
May 26, 2014 | D-Link Computers & Internet
I'm plugged in all the cable correctly (based on the manual) when i got to the 6th step when we have to make sure all the lights are flashing, the WAN lights is on but the light is in ORANGE color, i...
Step 1 Verify physical connectivity by checking for solid link lights on the device. If you do not get a solid link light, try using a different cable or connect to a different port on the device if possible. If the computer is turned off, the link light may not be on.
Step 2 Disable any internet security software running on the computer. Software firewalls like Zone Alarm, Black Ice, Sygate, Norton Personal Firewall, etc. might block access to the configuration pages. Check the help files included with your firewall software for more information on disabling or configuring it. Note that in some cases just disabling the firewall/antivirus software may not help, you may need to uninstall and reinstall the software.
Step 3 Configure your internet settings. Go to Start > Settings > Control Panel. Double click the Internet Options Icon. From the Security tab, click the button to restore the settings to their defaults. Click to the Connection tab and set the dial-up option to Never Dial a Connection. Click the LAN Settings button. Nothing should be checked. Click OK. Go to the Advanced tab and click the button to restore these settings to their defaults. Click OK out to the desktop and close any open windows.
Step 4 Check your IP address. Your computer must have an IP address in the same range of the device you are attempting to configure. Most D-Link devices use the 192.168.0.x range.
If you are attempting to configure a D-Link router, then make sure you take note of your computers Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be 192.168.0.1.
If you are attempting to configure an Access Point or Print Server, you may need to configure your computer with a Static IP Address in the appropriate range.
To set your computer with static IP address:
Windows2000/XP: Control Panel > Network Connections > Local Area Connection > Properties > Internet protocol TCP/IP > Properties...
Windows95/98/ME: Control Panel > Network > TCP/IP protocol for your Network Adapter > Properties...
IP address: 192.168.0.2
Subnet mask: 255.255.255.0
Gateway: 192.168.0.1
DNS: 202.129.64.198 (or whichever your provider is using)
Step 5 Access the web management. Open your web browser and enter the IP address of your D-Link device in the address bar. This should open the login page for your the web management. Use the instructions provided with your product to login and complete the configuration. There are several more FAQs that cover the configuration of the different D-Link Gateways, Access Points and Print Servers.
I got this from their support page. Hope this works out for you :D
Jul 18, 2011 | D-Link Wireless N 150 Home Router 4Port...
The router was reset. So, our AP does not work with it anymore. I reset the AP to restore it to its factory default settings and tried to follow the steps I made before in configuring the AP. but i can't...
Before you configure this device, note that when the AP is configured through an Ethernet connection, (via RJ45 Network Cable) make sure the manager PC must be set on same the IP network. For example, when the default network address of the default IP address of the AP is 192.168.1.1, then the manager PC should be set at 192.168.1.x (where x is a number between 2 and 254), and the default subnet mask is 255.255.255.0.
Open Internet Explorer 5.0 or above Web browser.
Enter IP address http://192.168.1.1 (the factory-default IP address setting) to the address location. Please refer here to the Latest User Manual for Encore ENRWI-G Page 9 onwards describes the login details.
Hope this Helps!
CreativeTECH
Jan 01, 2011 | Encore WIRELESS LAN EXTENDER
Hope this Helps!
CreativeTECH
Jan 01, 2011 | Computers & Internet
I recently got a Mac desktop and my Linksys router disk will not open up. Do I need a router that is made for Macs or is there a way to configure the Linksys?
Hi, You are correct. The CD is not compatible with Mac. What you have to do is Configuring the Router Manually using the Web Based Configuration panel.
How to:
  1. Open your Web Browser
  2. Type http://192.168.1.1 in the Address Bar and hit Enter
  3. If you have changed the address somehow you have to enter that (Router's IP - Default Gateway)
  4. Here is a small guide to Fine your routers IP address in case of that you are unable to access
  5. Enter the user name (default user name is blank- means no user name. Just leave it blank), Default password is admin.
  6. Now you can configure the Router using the Menus.
  7. Make sure that you have Saved your settings before Exit the Web Based Setup.
  8. Make sure that you have changed the Default Password.
  • If you can’t access the router’s web-based setup page, please check the following: cable connections, router’s LEDs, IP address, and connectivity.
  • Connecting Devices Together
  • Ensure that you have an Active Internet Connection and connect the modem to the router’s Internet port and the Mac to any of the four Ethernet ports.
  • Checking the Router’s LEDs
  • After connecting your modem and Mac to the router, check the lights on the front panel of the router.
  • Checking the Router’s IP Address
  • To find a Linksys router’s Local IP address, you have to check the IP settings of the Mac
  • Checking the Mac’s Connectivity with the Router
  • Ensure that the Mac is properly connected to the router.
You can download the Manuals from here to learn how to do Advanced, Customized Configurations.
Note: Please select the appropriate Hardware Version.
Thanks for contacting Fixya! Feel free to ask any questions if you face trouble with the setup. Please rate the answer as well!
Jun 22, 2010 | Linksys Wireless-G WRT54GS Router...
Wireless router won't connect to my laptop
1. check your network adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 just check the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
Hope this will help
Nov 24, 2008 | Arris WR850G Router (DHWR850G)
Cant find my routers Gateway Site..?
First you must make sure that the Ip address 192.168.2.1 is your routers ip address.
Click on Start, Run, type cmd, then click OK. Type ipconfig /all and hit the enter key. You are looking for the Default Gateway address. Use that address in your web browser. When you set up your static Ip address on your computer, use the first three numbers of your default gateway's address, then for the fourth number, add one. For example. If your default gateway address is 192.168.2.1, then your static ip address should be 192.168.2.2.
Try this and let me know what happens.
May 31, 2008 | Intellinet Active Networking Intellinet...
IP address
Yes. There is no http:// just 192.168.0.1
RCF
May 24, 2008 | D-Link AirPlus DI-524 Wireless Router
Access configuration
Step 1 Verify physical connectivity by checking for solid link lights on the device. If you do not get a solid link light, try using a different cable or connect to a different port on the device if possible. If the computer is turned off, the link light may not be on. Step 2 Disable any internet security software running on the computer. Software firewalls such as Zone Alarm, Black Ice, Sygate, Norton Personal Firewall, and Windows XP firewall may block access to the configuration pages. Check the help files included with your firewall software for more information on disabling or configuring it. Step 3 Configure your Internet settings. Go to Start > Settings > Control Panel. Double-click the Internet Options Icon. From the Security tab, click the button to restore the settings to their defaults. Click the Connection tab and set the dial-up option to Never Dial a Connection. Click the LAN Settings button. Nothing should be checked. Click OK. Go to the Advanced tab and click the button to restore these settings to their defaults. Click OK out to the desktop and close any open windows. Step 4 Check your IP address. Your computer must have an IP address in the same range of the device you are attempting to configure. Most D-Link devices use the 192.168.0.X range. Click here to find your IP Address on your computer If you are attempting to configure a D-Link router, then make sure you take note of your computer´s Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be 192.168.0.1. If you are attempting to configure an Access Point or Print Server, you may need to configure your computer with a Static IP Address in the appropriate range. Step 5 Access the web management. Open your web browser and enter the IP address of your D-Link device in the address bar. This should open the login page for your the web management. Use the instructions provided with your product to login and complete the configuration.
Feb 16, 2006 | D-Link AirPlus DI-614+ Wireless Router
Can´t I access the web-based configuration
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Patton Electric 2603 Router (2603/k/ui) Logo
123 people viewed this question
Top Patton Electric Computers & Internet Experts
Alun Cox
k24674
Are you a Patton Electric Computer and Internet Expert? Answer questions, earn points and help others
