Question about FEC RKMV5 Custom Rackmount Kit for JVC RKMV5
Panasonic DVD playerS35 error H 07
I own a Panasonic DVD playerS35 and I have been getting the error H07 every time I load a dvd and try to play it... The dvds are in good shape and the system was working until yesterday... Nothing much happened to it aside from the fact that we connected it to another tv (note that connecting it to the old tv has not solved the problem either) Any idea what this means and how I can fix this?
  • 189 Answers
HELLO
H07 is the fault code for the disc motor and here is what you need to do to remedy it.
The cover of the player will have to be removed to do this. Locate the the actual motor shaft and where it goes into the motor itself, put a little drop of light oil or WD40. Let it soak in for a little while and try it again. I'm sure you will find it now works.
I had this problem on Panasonic NV-VP31 DVD/VCR unit and I have had no more trouble since!
HOPE THIS HAS HELPED - ENJOY!
Posted on Sep 05, 2009
SOURCE:
Panasonic DVD player RV62 H07 message - disc
You can try to clean the laser by opening the unit and wiping gently with a cue tip or cotton swab, but if you are getting a H07 errorit may be somethng more serious and require a replacementof the dvd drive.I hope this helps. Good luck.
Sep 03, 2010 | Panasonic DVD-RV62EBS DVD Player
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
Player stops. H07 appears.
This is a problem with the spindle motor,you can locate where the spindle goes into the motor and spray with wd40 leave for a few mins.
Nov 08, 2009 | Panasonic DVD-RV32 DVD Player
H07 error msg
This normally means the spindle motor is faulty
Jul 12, 2009 | Panasonic DVD-RV32 DVD Player
H02 Error after inserting a dvd disk
The trouble started with an error to close and open the DVD drawer. It indicated "close" when the drawer was open, or "no disc" when the DVD was inside, and I had to try many times before I get the right response and go on with the procedures.
But then it also started playing just a few MP3 tracks and stopping to work, showing again the inserted DVD data. Later H02, and then H07 and STOP. It doesn't even start playing stuffs, movies or MP3 tracks!
Aug 11, 2008 | Panasonic Televison & Video
Error message H07
The spindle motor is defective. Open the cover and see if the disc spins when it loads. If it doesn't, give it a spin in a clockwise direction immediately after loading the disc.
Apr 05, 2008 | Panasonic DVD-RV32 DVD Player
Dvd
I opened it up and sprayed silicone on the center where the disc snaps on. I also sprayed from a side angle to try to aim it towards bearings/works underneath. It worked!
Jan 24, 2007 | Panasonic DVD-RV32 DVD Player
Error Message H07
You can reset this fault by holding in the reverse, pause, and the on-off button, all at the same time. If it comes back then the spindle motor is the bad componet, and unless you know how to disasemble a mechanism for a changer I would let a pro handle it.
Jun 19, 2006 | Panasonic DVD-S35S DVD Player
Error Message H07 - what is it?
The last time I opened up my Panasonic DVD-CV52, I looked at the little white bush on the motor spindle, it has a small spring which presses against the side of the bush. I can see no purpose for this spring/bush other than to provide some drag to the motor. Anyway, I removed the spring, so that the bush would no longer drag against the shaft, that was a few years back, and I haven't had a problem since. Of course a temporary solution is to oil the bush!
The www.ledcar.com/pdvdh07/ link mentioned above provides an excellent pictorial guide to disassemble and reassemble the player.
Jun 09, 2006 | Panasonic DVD-CV52 DVD Player
Troubleshooting -- Displays H07 code
While stopped, press and hold REWIND and PAUSE on the unit and then also press and hold OPEN/CLOSE on the unit until Initialized appears from the display. Turn the unit off and on again. If it is still not working, Panasonic Consumer Support recommends having the product checked by an authorized Panasonic service center.
Dec 23, 2005 | Panasonic DVD-CV37 Multi-disc DVD Player
Televison & Video Logo
129 people viewed this question
Top FEC Televison & Video Experts
Marvin
Marvin
Are you a FEC Televison and Video Expert? Answer questions, earn points and help others
