I have Delonghi PACN100E. I installed it last night and after 1/2 hour of air conditioning the alarm light came on and I needed to empty the tank. I did this several times It is very high humidity levels outside While operating it cools extremely well. discharge line is not plugged nor kinked. Filer is clean.
You may have a blocked water line. Blow into it, it may free up any debris in the hose or tank.
It's doing what it is supposed to do. put a permanent drain on it.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
SOURCE: room temperature has not changed since hooking up new portable a/c
I bought mine last summer. Used it once or twice. Hooked up it today and it is a piece of ****. Been at 34celsius for the last 4 hours and still not even close to being cool .. and its in my bedroom
DON'T BUY DANBY portable a/c -----------
SOURCE: I have a portable air conditioner and the water
I would suggest putting a condensate pump in the reservoir, find the tube that empties the water into the reservoir and direct that into the pump. You can run tubing from the pump to a sink or any other drain in the house that is convenient. Putting the pump inside the reservoir is a safe guard in case the pump fails, the water will fill and turn the unit off instead of flooding the floor. It would actually probably trip your breaker once the water hit the voltage on the pump but always better safe then sorry. Check out these pumps at amazon, you don't need anything fancy.
http://www.amazon.com/gp/product/B000UVUW6Q
Good Luck
SOURCE: Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
SOURCE: kohler k582 runs poorly at operating speed.
ALWAYS CHECK THE POINTS!!! 20 years operating this engine and you'd think I would know better. The points were severely pitted. Spec said .020 but actual is .013. The cold weather had me suspecting a carb problem. DOH!
