Question about Polaroid PDM-0711
Icecream spilled? My niece spilled chocolate icecream all over the place where you put disc in, and it got inside. Anyway to clean it and it'll play again? What do i clean it with?
    Problem Solver:
  • 12 Answers
To do this properly I would suggest highly that you take it to a service center. The reason is this: In order to adequatley clean the unit so that a)no damage occurs and b)the unit is fully clean and operational, you need to take it apart. The safest way to clean an electronic device is to disconnect the part being cleaned from any of the neighboring components and electric signal as well. If you want to go this alone, get an area setup that's approximately 3 square feet in size and is flat and dry (table with newspapers, etc) Get a container to house your screws, etc. that you may need to remove in order to provide access to the soiled components. If you feel comfortable removing the cover and cowling then you can do that, although being a portable player it's most likely fully exposed when you open the lid for the drive. As far as cleaners go, you can use a paper towel and a mild solvent. (such as a diluted bottle of dish soap) Avoid harsh or dry solvents such as rubbing alcohol as they can corrode, discolor and damage the optics. I'd recommend that you use q-tips in order to clean the drive and optics area but again this entire procedure isn't something I'd suggest to a novice if you happen to be. As well even if you open the drive lid, there's a great chance the spill worked it's way down past what you can see and into the main compartment. That's another reason why it should be disassembled. If you know anyone who is mildly familiar with electronics they can do this for you. It's about a 3 or 4 on a 1-10 scale (10 hardest) of difficulty. It shouldn't take more than 30-40minutes to properly perform. Hope that helps.
Posted on Aug 18, 2007
SOURCE:
I got icecream in my headset mic can it be fixed?
Try very carefully take off the plastic or whatever is covering the mic (you don't have to, just makes it a little easier). Get a toothpick (I recommend wood), and carefully scrape the ice-cream (is it chocolate?).
Jul 28, 2011 | Video Game Consoles & Games
Why does my Icecream not freeze but my ice does freeze?
water has no air bubbles (insulation) so is able to freeze quicker than ice cream,which is full of air,although icecream,if left too long in the freezer WILL freeze solid.
Nov 21, 2010 | Bosch Evolution 500 B20CS50SNS
Simac gb8000 dule icecream maker need the padles tht churn icecream
I have a magimix le glacier 1.1 litre and have lost the manual please help?
Nov 19, 2009 | Ice Cream Makers
We put things(meats,water,veg.) anything but
check the cold deflector door for proper operation, then check the cold control itself as it may be defective
Nov 01, 2009 | Freezers
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Directions and recipe
i have a rival 8704 4 qt icecream maker,,when i made ice cream fior the first time,,the manual does not tell me what to add to my maker before it starts to churn,,i need to find a way to have someone show me exactly what to add for ingrediants and show me step by step how to make my icecream.like>>none said to add milk or cream to icecream mixture
Feb 03, 2008 | Rival 8704 4 Quart Ice Cream Maker
Polaroid PDM-0711 Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
