Question about GE WHRE5260E Top Load Washer
Washer make clicking sound
My washer works fine At 12 ,9 min,but makes clicikg voice at 6min.on quick rinse it makes the same sound for some time at final spin. plz.help
  • 30 Answers
First locate were the sound is coming from. put your ear very close to the timer and listen for this clicking sound. remember a timer will make a clicking noise which makes the timer go around. Timers can get noisey with age. The sound might be coming from below also .I would run your washing machine until the part fails. They might also have a motor controller in this unit which is seperate to the timer which will make a high pitch clicking noise.
Posted on Aug 18, 2007
Rinse plus and quick wash will not work bosh washer WAE20060UC
does not sound like they can be used at the same time perhaps just one or the other
Aug 31, 2015 | Bosch WAE20060UC Washer
My maytag washer when i start it it fills then the cycle starts the timer will count down til it get to 13 min then jumps down to 3 min then shuts off it skips the wash cycle and the rinse cycle befor
sounds like you have a problem with the main control board. you can order a new one from appliancerepair.com and if it turns out not to be the problem they allow you to return it for a full refund. great company!
May 26, 2014 | LG Washing Machines
Whirlpool washer duet sport ht MOD # WFW8300SW02
did you try to diconnect it from wall?
try to disconnect it.... wait for 5 minutes and try to connect it again and try if same problem still occurs....
Jan 13, 2014 | Washing Machines
Samsung washer reset
sound like module problem try to remove all the conection connecting the module and connect maybe after 30 mins.
Nov 06, 2013 | Samsung WF218AN Front Load Washer
Front loader machine stuck before spin cycle
This is an issue with the pressure switch, it is having issues detecting the water level.
Mar 11, 2012 | LG Washing Machines
The times seem to have changed on the settings for soil levels. For instance, the quick is 50 minutes and the normal is 84 minutes. That does not seem right. Is there any way to set them different?
Answer to your question "Is there any way to set them different?" Short answer is no. The Maytag Neptune like many other washers that display a time of cycle first start with an estimated time this relays a lot on the last cycle ran. But, more importantly it also takes into consideration other washing options. For example, lets say that your quick wash cycle used to only display 35 min. now if you select an extra rinse option the time will increase from that 35 min. to a higher amount of time. This is due to the longer time it takes to go through a second rinse cycle. The MAH5500 if I'm not mistaken also has a heater in it so there are options such as sanitize which takes 120 degree hot incoming water (suggested temp. for hot water heaters) and heats it to approx. 165 degrees. And as you can imagine this takes a washer some time to do this (increasing wash time). If you would like to lower washing time check the washing options and remove any that are not needed at that time; pay close attention to extra rinse cycles and the soil levels that are selected. Hope this helps. Cheers.
May 16, 2011 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Hotpoint bwm129 making huming noise
Sounds like the rinse water can't come. Maybe the solenoid for cold water got stuck or a water filter needs cleaning? If the humming is louder, perhaps the drum motor (or drum) needs a little care or cleaning.
If all else fails, download the user manual and check the trouble checklist index. (Or; try learning your kenpo succession move sparring against laundry to clean it.)
Apr 14, 2008 | Hotpoint BWM12 Front Load Washer
Washer stops and make clicking sound
sounds like the timer needs a little assistance to get "over the hump". perhaps many cam switches must be switched at his point of cam rotation. if machine is getting old, then attempt to lubricate the electric motor that turns the timer mechanism. also lube the shaft bushings for the timer cam plate as well if possible.
Aug 17, 2007 | GE WHRE5260E Top Load Washer
GE WHRE5260E Top Load Washer Logo
168 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
