Question about Intel Pentium 4 1.7G, 1.7 GHz (p41700400256sk478) Processor
Pc is not starting up
Hi today when i operating my pc, it automatically turned off. only the cpu power light and the cd-Rw drive light is glowing when i restarted it again. i checked my RAM whether it loosen or not, but it seems to be ok. i removed the processor fan to check the processor temp. the processor is not getting heated at all. only the main power light of cpu and the cd drive light is glowing. before this my pc used to hang a lot. but suddenly today it never get started again. so kindly give me some solutions for this.
  • ranjini_Hm Aug 21, 2008
    hi
    my pc is not starting, it rarely starts up, but when it doesnt starts only the cpu power light and the cd-Rw drive light is glowing when i restart it again. i checked my RAM whether it loosen or not, but it seems to be ok. i removed the processor fan to check the processor temp. the processor is not getting heated at all. only the main power light of cpu and the cd drive light is glowing.
    Scholar:
  • 173 Answers
Check them bigger transitors heatsinked in solder to mother board should find a 12v a 5v with your test meter. sounds like you lost 12v to the cpu. 12 and 5v , -5v -12 start at the power supply....i would take the plugs loose and see if voltage comes back up if not change your power suppy, 400 watt ps would be nice. there is sometimes one separate plug with 2 wires that runs down by the Processor this powers only the CPU ,check that if you see it.all universal ps now have this extra plug.
Posted on Aug 18, 2007
  • Anonymous Sep 14, 2008
    solution 2 has a good point too!
  • 102 Answers
I'm sorry to tell you but your cpu has probably fried. Your pc hanging a lot probably meant something was overheating and the fact that you say your cpu is not hot when you have the cooling fan off of it means it is probably the cpu. When you first turn your system on without a cpu cooling fan, the cpu should be slightly warm, although I do not recommended running a cpu at all without a cooling fan or even touching it when it has power.
SOURCE:
My pc Shut Off Automatically after few min(5-6),when pc is in boot screen options or booting from O.S. CD"
I missed your question, anyways. as it seems there might be the reason of over heating. I would suggest just remove the heatsink apply proper heatsink paste on CPU and replace your heatsink and fan. heat must radiate properly.
Nov 28, 2011 | ASUS P5G41-M Motherboard S775 Intel G41...
Only 5 of 8 brain burn athena
Hi THERE, This model is now discontinued.
The replacement is DUP-DP-AS3-11B.
*NOTE: Item is not compatible with LG GH22LS30 (Directron part number DVR-GH22LS30)
Now you can easily build a Blu-ray duplicator with the Athena SATA Blu-ray controller. SATA interface simplifies cable management comparing to IDE with narrower cables and smaller connectors. SATA interface supports cables as long as 90cm without sacrificing data integrity and system reliability. Hence Athena SATA controller can be installed on the top drive bay even in an 11-target tower duplicator. Maximize your productivity and efficiency today with Athena SATA Blu-ray controller.
Features:
  • Standalone, no PC required.
  • DDR2 Technology allows up to 8x Blu-ray duplication.
  • SATA Advantages - Thin cables for easy routing and improved cooling inside the duplicator chassis, increasing product reliability.
  • Dynamic Hard Drive Partitioning automatically adjusts hard drive partitions based on the size of your master disc.
  • Master Error Proof prevents duplication failures caused by disc errors. Simply exchange the failed master disc with a working disc without interrupting the duplication process.
  • Dual-Level Security provides separate Startup and Setup passwords for complete restriction and protection against unauthorized users.
  • Advanced Diagnosis Mode troubleshoots and sets adjustment for optimal performance.
BACK TO TOP
Specifications:
  • Operating Type: Controller only
  • Internal Interface: SATA
  • Targets: 11
  • Reading Speed: 18x DVD-ROM
  • Maximum Writing Speed* (*Actual write speed depends upon media and drive specifications) : BD-R SL: 8X BD-R DL: 4X BD-RE SL: 2X BD-RE DL: 2X DVD+RW: 8X DVD-R: 20X DVD-RW: 6X DVD+R: 20X DVD+R DL: 8X DVD-R DL: 8X CD-RW: 32X CD-R: 48X
  • Supported Disc Formats: BD ROM, BD-R, BD-R DL, BD-RE, BD-RE DL, DVD ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, CD-DA, CD ROM, CD-R, CD-RW, Multi-session Photo CD, CD-I, Video CD, CD ROM XA, & CD Extra (CD Plus)
  • Supported Recording Discs: 12cm 25GB BD-R 12cm 25GB BD-RE 12cm 50GB BD-R DL 12cm 50GB BD-RE DL 12cm 4.7GB DVD-R/RW 12cm 4.7GB DVD+R/RW 12cm 8.5GB DVD+R DL 12cm 8.5GB DVD-R DL 12cm 80min / 700MB CD-R 12cm 74min / 650MB CD-RW 8cm 1.47GB mini DVD-R 8cm 24min / 210MB mini CD-R 8cm 50MB Business Card CD-R
  • System Buffer: 128 MB (Optional upgrade to 512 MB)
  • Hard Drive Supported: Up to 1TB (optional)
  • Power Adapter: Input: 100 ~ 240V AC Output: +5V DC, 3.8A
  • Operating Temperature: 40oF ~ 95oF
  • Operating Humidity: 20% ~ 90%
  • Regulation: FCC, CE, RoHS
Aug 27, 2011 | Athena SATA CD/DVD/Blu Ray Duplicator...
I just bought Logitech Clearchat Premium PC, how do I get it to work?
Assemble it: connect the data cable from the monitor to the CPU, Connect the mouse and keyboard to the CPU, connect the power cables for the CPU and for the monitor, press the CPU power button, and the monitor power button. If the computer doesn't work, then it came without an operating system.Get the operating system disk and insert it into the DVD or CD ROM/RW drive. Turn the computer off, and turn it on again. Check the monitor carefully and when it prompts for pressing any key to boot from the cd, do so very fast. The process of operating system installation will start. Follow the procedures and instructions it gives you till the end. If you are not sure of any step, ask or consult any person who can assist.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 12, 2011 | Computers & Internet
My drive is disabled and I don't know how to enable it
Do you find the green light glow if you press the eject button ? If No, First step is to Turn off the PC and disconnect the power cable from wall outlet and you will have to open the CPU Tower Cover and check the cables and firmly connect them again. this must be because of loose connection. Do Not attempt to do this if you are minor and for others, Do it at your own risk if you can.
Regards,
Ron
Feb 23, 2011 | NEC ND-6650A DVD RW Dual Layer Burner
I have a sony VGN CR-220E which re upgrade to vista ultimate that i could not install the webcam driver ?
According to the spec. it should be OK. Don't forget to download the drivers from Sony.com otherwise it won't work correctly.
Learn more about the Sony VAIO VGN-CR220E/P Model BrandSONY SeriesVAIO CR Series ModelVGN-CR220E/P General ColorCosmopolitan Operating SystemWindows Vista Home Premium CPU TypeIntel Core 2 Duo T7250 2.0G Screen14.1" WXGA Memory Size2GB DDR2 Hard Disk200GB Optical DriveDVD Super Multi Graphics CardIntel GMA X3100 Video MemoryShared memory CommunicationModem, LAN and WLAN Card slot1 x ExpressCard /34 Slot Dimensions13.2" x 9.8" x 1.25-1.67" Weight5.5 lbs. TechIntel Centrino Duo Mobile Technology CPU CPU TypeIntel Core 2 Duo CPU SpeedT7250(2.00GHz) CPU FSB800MHz CPU L2 Cache2MB Chipset ChipsetIntel GM965 Display Screen Size14.1" Wide Screen SupportYes Display TypeWide XGA Resolution1280 x 800 LCD FeaturesXBRITE-ECO technology Operating Systems Operating SystemWindows Vista Home Premium Graphics GPU/VPUIntel GMA X3100 Video MemoryShared system memory Graphic TypeIntegrated Card Hard Drive HDD200GB HDD RPM4200rpm HDD InterfaceSATA Memory Memory2GB Memory SpeedDDR2 667 Memory Spec1GB x 2 Max Memory Supported4GB Optical Drive Optical Drive TypeDVD Super Multi Optical Drive InterfaceIntegrated Optical Drive SpecDVD+R DL Write: 4x max
DVD+R Write: 8x max
DVD+RW Write: 8x max
DVD-R Write: 8x max
DVD-RW Write: 6x max
CD-R Write: 24x max
CD-RW Write: 16x max
DVD±RW: Yes (DVD±R DL/DVD±RW/DVD-RAM)
CD Read: 24x max
DVD Read: 8x max
DVD-RAM Write: 5x max
DVD-R DL Write: 4x max
DVD-RAM Read: 5x max Communications ModemIntegrated V92/V.90 Modem (RJ-11) LAN10/100Mbps WLANIntel PRO/Wireless 4965AGN Network Connection (802.11a/b/g/n)
Jan 01, 2011 | Sony VAIO VGN-CR220E/P Notebook
Computer not getting switched on
appears that ur RAM is struck....
some power is left in the ram...so do this
take out all power supply and all power cables from the CPU BOX, press the power on button on the PC and keep pressing for few mins....
do on and off for a few times....WITOUT POWER...
re-connect the cables and start...
if the above process does not solve.....
do the above process after removing the RAMs(RAMS are 1 inch by 4 inch circuit boards with 4 or 8 ICS in them) from the slots inside the PC(guess u know how to do that)
then reinstall the RAMS...the RAMs go in only one direction....put back the clicp that hold them....
put back the cables and start it...
Dec 18, 2009 | Computers & Internet
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Tony.
Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
Replacing cd-rom
u need open the cabinet and there should be a serew and remove it and connect teh new one and make sure teh power and date cable the red side of teh power as well as the red side on teh data cable should face same side and start the pc>and put the cd and install soft ware and start using teh dvd and cd>rate me solved if its helps thx
Nov 16, 2007 | HP Compaq dc5100 PC Desktop
I need help getting dvd+rw drive operating
hi
go to nearer computer sales and support centre purchase a DVD R/W and if u have CD drive dis connect power cable and data cable then remove screws from cd drive then remove it fromyour cpu cabinate in same place insert your DVD R/W fix all screws,data cable and power cable.then connect all the data/power in backside of cpu if you r removed before otherwise again check all the cables and power on your cpu/moniter.after booting sucessfully your computer insert your nero cd which is given with your DVD R/W,cd automatically open then setup it one by one by soing instructions.after setup complete your DVD R/W is ready to read write CD/DVD.
thanks
Nov 12, 2007 | Computers & Internet
Intel Pentium 4 1.7G, 1.7 GHz (p41700400256sk478) Processor Logo
94 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
