Question about 2wire 2700HG-B Router (2700HGB)
Laptop not connectiong to wireless network
I have a 2Wire router and use DSL on my desktop. I run the laptop via the wireless connection. I tried to use the internet on the laptop today and it says no available wireless connections in area. Usually it can pick up other connections in addition to our own. I'm not sure if the Wireless light on the router isn't on because the connection isn't being used or that its not working.
  • Anonymous Mar 21, 2014
    I want to connect a toshiba windows xp laptop to a netgera40 wireless router byt the laptop does not pick up the available connection
When i put my wireless switch on i still can't get online and it's a new laptop.
Posted on Jun 05, 2009
    Scholar:
  • 130 Answers
Is there a switch on the laptop either in the power management software or an actual switch on the laptop case (or a button) that turns the wireless on and off? That's probably the problem, not your router.
Posted on Aug 18, 2007
SOURCE:
2wire 1701 hg dsl connection drops when laptop is connected via wireless
This is a known issue with this model.. The power supply is not large enough to handle the extra current that is needed when the unit broadcasts on wifi.
May 05, 2017 | 2wire Computers & Internet
Can't add my new laptop to my at&t 2wire DSL.
Have you done a network search with the laptop? Is wireless activated on the laptop? Have you reset router? Plug the actual network cable to configure the laptop first then, once you do that, it should be recognized by the router, some router models requiere you to do this before you can connect to them wirelessly...
Aug 19, 2011 | 2wire (2701HG-B) Wireless Router
Connect two computers to internet thru AT&T DSL
You can install a either a 4 jack wireless router( cost about $25). This will allow you to either cable 4 PC's or connect your PC's via the wireless feature. The instructions that come with the wireless router will give you installation instructions (it's fairlly easy). Make sure you secure your network with at least WEP security.
Let me know if you need more help.
Dec 10, 2009 | 2wire (1000-400108-001) Router
Connect the Laptop to the router with ethernet cable
Verify the wireless LAN
  • Open a browser and type http://gateway.2wire.net; the Home page opens.
  • Click the Home Network tab.
  • Verify the wireless status located on the right panel (Status at a Glance) is Disabled.
  • When the status is disabled, then enable the wireless LAN .
May 27, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire wireless connection problem
Make sure that the wireless switch on your laptop is on. Click on view wireless network by right clicking on the network icon on your system tray. Locate the name of your modem ( SSID ) & enter the wireless encryption key ( WEP ) or password
Apr 08, 2009 | 2wire HomePortal 1000HW DSL Modem and...
I have a 2wire router from AT&T, all lights are green, except the "wireless" light. It's not on, how do I become wireless?????
Hi dilex
The 2wire router wireless light comes only when a system is connected to it wireless.
Please post the system that you are using and also what exactly when you try to connect via wireless.
Thank you
Rakesh
Dell Laptop Expert
Jan 06, 2009 | 2wire 2700HG-B Router (2700HGB)
HP Laptop does not connect to internet unless directly
Hello dstoller,
You description is very confusing to sort exactly what is or isn't happening.Let me try to sort out what you have:
You have a Laptop
You have a Desktop
Desktop has a printer attached
You have a DSL modem with a wireless router
Laptop via ethernet: Good
Laptop via wireless: Not Good?
Desktop via wireless: Good
Not sure exactly what you are needing help with...
- Vincent
Still not sure what
Nov 22, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
2WIRE wireless router/DSL from AT&T
unless this is a wireless enabled or lan RJ45 connectable printer you cannot, the pc that the printer is connected to must be on at the time of the printing.
Wireless printers have their own arial and allocated ip address, Lan RJ45 connective printers can be connected to the router.
Sep 15, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Connecting 2wire router with desktop pc and laptop
hi! try to check the settings on your 2wire modem, you can do this by going to gateway.2wire.net, run the system setup wizard, when you get to the ppp authentication page, check the username & password on it, it should be the one that you setup for your ISP account. as for the wireless on the desktop, it depends on the brand of the wireless adapter, be sure you have installed the drivers for this adapter. you may need to go to the client utility manager or the wireless adapter shortcut/icon on your computer screen then configure it to "see" the 2wire network. make sure wireless encryption is turned on in the 2wire modem's MDC, you can do this by going to homeportal/management, or go to gateway.2wire.net/mdc.
Apr 11, 2008 | 2wire (1000-400108-001) Router
2wire 2700HG-B Router (2700HGB) Logo
355 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ekse
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
