Question about Creative Labs Nomad Jukebox Zen Xtra MP3 Player
Hard Drive problem
I recently turned on my mp3 player, it worked and than it reset and the trouble menu popped. I hear the hard drive ticking (softly) and it goes into the rescue mode. While I tried tapping above the menu buttom, nothing happened. Can It be true? Did my Nomad break? I appreciate your input.
I just had the same problem (Nomad Zen 20GB), the hard drive was stuck. Tapping while it boots didn't help so I took off the back cover and removed the cover of my hard drive (5 screws), then helped the drive to start spinning when the player was booting. Now it works again just fine. Make sure you take it apart in a clean environment (no dust) and don't touch the disk itself, only the center hub. Just be careful, if you damage something then the drive is gone.
Posted on Sep 25, 2007
Put in new hard drive it is just a notebook hard drive.i had 40 gb and made it a 60 gb.
Posted on Sep 11, 2007
My Hard drive ticked just the same as yours...but try tapping it on the right side upon boot up...like in the problem posted within these pages 'My MP3 player has a hard disk problem and won't...' the Menu option did'nt work for me but tapping it did.... thanks a bunch
Posted on Aug 26, 2007
    Scholar:
  • 130 Answers
If it's making cliking noises then that's a sure sign of a dead hard drive. Probably the best thing you could do is get a new one, or call Nomad tech support and see what they have to say about it.
Posted on Aug 18, 2007
6ya staff
SOURCE:
What do I do to Eclipse fix mp3 when it diplays "Disk Error!" upon attempting to play music?
Presumably the error is caused by a hard disk drive? In which case the hard disk will need to be checked. If there are options to do this use them. Otherwise the drive might need to be replaced.
If you bypassed the normal way of putting music onto the drive, then it might have corrupted the drive.
If there is an option to reformat the drive that might work. Or if there is a factory reset, that might correct it.
If you have music stored on the drive, which is not found anywhere else, then I think it will have been lost for good.
May 27, 2017 | Eclipse Audio Players & Recorders
My ipod is nt gettin on....the apple symbol blinks and it pops out.this happens even wen charging.for a few seconds the light comes wit the apple symbol then suddenly it goes off with a popping sound
Your Hard Drive for this iPod has gone bad. The popping is the sound of your Hard Drive trying to read. The inside of a hard drive is like a record player, what would be an arm and needle on a record player is similar inside the Hard Drive, Most likely the Arm is broken.
Feb 11, 2011 | Apple iPod MA446LL/A MP3 Player
My ipod classic 80 gb wont restore and keeps clicking
Listen to the iPod when it is connected to the computer. Do you hear repetitive clicking sounds from the hard drive? If so, your hard drive is broken. It's not too hard to replace the hard drive yourself. Here is an iPod Repair Guide that shows how to open an iPod. Parts are easily available on Ebay. If you want somebody else to do it for you go to iPad Repair
Oct 01, 2009 | Apple iPod MA446LL/A MP3 Player
IPod Errors
Distinct clicking, right? Your hard drive is about to crash completely. Other than the ticking, your problems are probably because the hard drive is not giving out the information it needs to because it can't. You need either a new Hard drive or a new player. once you get it all of you problems should go away.
Feb 14, 2009 | Apple iPod classic MP3 Player
Only playing video, no music
It sounds like a problem with your hard drive. I know it sounds strange when everything else is working but in my experience and I've fixed thousands of iPod videos. 95% of the time, if the logic board is actually functioning, if you have a fault it's the hard drive.
Nov 04, 2008 | Apple iPod MA446LL/A MP3 Player
Creative zen
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
Booting straight to the Recovery menu
I decided to open it up to check out the hard drive to see what kind I would need so I could try replacing it. The data plug that attaches to the hard drive itself was partially unplugged. So, I pushed it back in all the way, put it all back together again, and turned it on just to see if something different might happen. (I had it set in my mind that the hard drive failed and I would need a new one, so I didn't expect anything different to happen) And to my surprise, it worked just like new again.
Before you go off and invest in a new hard drive, I suggest opening it up and make sure that plug is in all the way. Since you'll be opening it up in any case, it wouldn't hurt.
Jan 20, 2008 | Creative Labs ZEN V Plus MP3 Player
IPod will not start - hard drive making clicking noises
I had the same problem, took it to Apple store, they suggested I trade it in for a new one. With no other options, I opened up the ipod and found that the hard drive off center. I popped it back into place and it worked like normal after that. Opening your ipod will void the warranty. Hope this helps.
Nov 20, 2007 | Apple iPod MP3 Player
Ticking noise
The ticking noise is the arm inside the hard drive swinging back and forth in an effort to find the first sector of the drive. Best guess is a stuck spindle on which the platters ride. Another common name for this condition is called "stiction." If you feel comfortable, you can take the hard drive out and remove the cover off of it. Then, gently take your index finger and touch the edge of the platter and attempt to turn it. DO NOT touch the surface of the platter or play with the servo arm. You must do this in a dust free environment and as quickly as possible. Otherwise, you can take it to someone who is familiar with hard drive repair. Once it is working, you will need to a backup of the drive. Also, you will need to replace the drive because it will stick again. Good luck.
Jun 18, 2007 | RCA Lyra RD2763 MP3 Player
Phillips HDD1630 6GB mp3 player
It sounds like your hard drive is broken
Jan 10, 2007 | Philips HDD1630 MP3 Player
Stuck on read system files
i think your hard drive is dead. im not an expert but the same thing happened to me and i got it sorted with a new hard drive.
Dec 17, 2006 | iRiver iHP-140 MP3 Player
Creative Labs Nomad Jukebox Zen Xtra MP3 Player Logo
275 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
