Question about Motorola Mobility V170
Net 10 phone just wont work
We lent our phone to our neighbor who was supposed to only have it for a day so we didn't give him the power cord. It took him a week to return it. We plugged it in to recharge. It said it was done charging pretty quickly. When you flip the phone open you get a black screen. Nothing..... Even when it is plugged in you can do nothing with it. We replaced the battery and charged it. Still the phone is black. No matter what buttons I push, nothing happens. Thanks
  • murrayboys Sep 02, 2007
    It doesn't look as though there was any water in it. It might be hard to tell, though. Would just dropping it break it?
  • 78 Answers
Does the inside of the phone show ANY signs of having been in water? Might be slight residue, condensation, corrosion? My GUESS - he dropped it in water and took a week to dry it!!!!
Posted on Aug 31, 2007
  • Austin Walters
    Austin Walters Sep 03, 2007
    Yes it cold have.
    Have you tried to power it up from the wall charger "without" the battery in?
SOURCE:
Samsung How To
I have a Samsung S30G Net 10 phone that keeps calling 911, we live in a small town witch they send an Officer to the house or wherever to check to make sure that everythingis ok. this is a big problem when you have to have a Officer taken off the job for something that cant be fixed, if this a problem with Net 10 they should send the costumers new phone since they wont fix this problem. My neighbor has the same phone and his phone called 911 25 times in one day. Net 10 you should have a recall on these phones if they cant fix this problem!
Nov 16, 2013 | Cameras
HP Deskjet 1056 supposed to be dual voltage...?
What does it say on the "brick" on the cord? Look for power specs on the cord transformer.
Dec 10, 2012 | Office Equipment & Supplies
How and where do i get music to download to my samsung gravity 3?
You will either need a USB cable( to move more than about 5 songs at a time) or you can just email the songs to your phone WITH OUGHT data charges. I usually use email to send ringtones/songs to my internet-less phone, because I don't want to buy a cord. You can buy a cord on amazon Here, though:http://www.amazon.com/Samsung-Gravity-T479-Data-Cable/dp/B003XIA4O8/ref=sr_1_3?ie=UTF8&qid=1306439716&sr=8-3
The way you would do this is by sending it to your text message inbox. Actually, when you buy your phone, the provider gives you an email adress to go along with it. So to send a message to your phone:
1.Open up your email
2.Where it says "To", type one of these numbers:
Alltel [10-digit phone number]@message.alltel.com
Example: [email protected] AT&T (formerly Cingular) [10-digit phone number]@txt.att.net
[10-digit phone number]@mms.att.net (MMS)
[10-digit phone number]@cingularme.com
Example: [email protected] Boost Mobile [10-digit phone number]@myboostmobile.com
Example: [email protected] Nextel (now Sprint Nextel) [10-digit telephone number]@messaging.nextel.com
Example: [email protected] Sprint PCS (now Sprint Nextel) [10-digit phone number]@messaging.sprintpcs.com
[10-digit phone number]@pm.sprint.com (MMS)
Example: [email protected] T-Mobile [10-digit phone number]@tmomail.net
Example: [email protected] US Cellular [10-digit phone number]email.uscc.net (SMS)
[10-digit phone number]@mms.uscc.net (MMS)
Example: [email protected] Verizon [10-digit phone number]@vtext.com
[10-digit phone number]@vzwpix.com (MMS)
3.Attach files just as you would a picture.
4.send, and you should recieve as a text message.
Hope this helps:-)
May 26, 2011 | Samsung Cell Phones
Netbook does not power up with or without power cord.
Please try removing the battery and connect only the power cord, and then try starting it.
If it does not power up even now, then remove the power cord, I am assuming that the battery is removed already, hold the power key down for 10 seconds continuously (this will drain extra charge inside your laptop).
Not try connecting the power cord and power on, see if it works
if not you can also try with a known good working power adapter for the same model (try borrowing it from your friend or neighbor who has the same model
If any of the above steps did not work then its time we called manufacturer to get it serviced.
Dec 10, 2010 | Samsung N120-12GBK Netbook
Pole chainsaw not working
No power could be a broken wire in the power cord, usually near the plug end. It could also be the switch, or the motor brushes. More rare is a broken wire in the motor or the saw case. Hope this helps!
May 10, 2010 | Remington Electric Pole Saw
HP dv7 simply stopped turning on. worked great
What you would want to try is to remove the battery and see if pluging in the power cord will power the laptop alone. All laptops have this capability and this shouldnt be an issue.
But by testing this and seeing if it DOESN'T work then that means there could be one of two things. Your AC power adapter is defective and should be replaced with one that is compatible with your system or that your connection jack is either loose on the inside or broken completely.
However I would stick with trying the cord first before trying to resoder the joint inside the system. I'd leave that to a pro, going back to the battery if you leave it out for a day that should give it plenty of time to discharge any energy it may have in it and you can plug it back into the laptop to try and charge it again either with the same AC power adapter or a new one. If the battery wont hold a charge and you know it isn't because the jack is loose or the AC power adapter isnt defective then you now know you need to replace the battery. You can google compatible batteries and power adapters online or search specific places like Newegg.com or Amazon.
Hope this gives you a better understanding of what may need to be done to fix this!!
check me out at http://ctrlr4repair.webs.com
May 06, 2010 | HP Pavilion dv7-1020us Notebook
I work with the local telephone company a customer is having problems with their call display do you have an 800 # which she can call or a suggestion which I can give her to check the actual phone she has...
Here it is Nexxtech contact details: Contact Us: Phone - 888-319-9464
Hours of Operation - 8am-12am CST, 7 Days a week
Closed - Thanksgiving Day and Christmas Day
Ryan
www.cobaltsys.net
kbretrieveimages.php?id=1899
Oct 13, 2009 | NexxTech 4318570 Corded Phone
Trunk wont pull shut.
You have a pull down switch that activates the pull down motor for the trunk lid to close. The manufacture of this part supplies this to Ford & General Motors vehicles. You can go to a Cadillac dealership & purchase this part far cheaper than at Ford. I use to work at a GM dearlership & my neighboring Ford dealer would order this part from me for the cost of mine where less than the cost from Ford. Figure those guys out at Ford. No wonder they don't need a goverment bailout
Frank
May 22, 2009 | 1996 Lincoln Town Car
Motorola Mobility V170 Logo
75 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
